Should I get a sunroof?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacoma1997White4x4, Jul 3, 2020.
Thread Status:
Not open for further replies.
  1. Jul 3, 2020 at 6:55 PM
    1997tacomav6
    Denver
    I say NO,
    1) one easy way to break into your truck would be through a sun roof.
    2) heavy hail would probably break the glass.
    3) replacement glass might not be so easy to find years from now.
    4) there’s always a chance for water leaks,
  2. Jul 3, 2020 at 8:09 PM
    Ccrowe323
    Ccrowe323 Well-Known Member
    Cory
    Florida
    2001 Tacoma 3.4 DC 5speed TRD OR
    Just cut the entire roof and replace with plexi glass and install a roll cage. Like a convertible but for off-road.
  3. Jul 3, 2020 at 9:42 PM
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    I have had several vehicles with OEM sunroofs (including my current '18 TRD Sport) and have never had a leaking or any other problem.
    However, have know of several others who have had "after-market" sunroofs and every one leaked at some point.
  4. Jul 3, 2020 at 9:48 PM
    HighCountryTacoma
    HighCountryTacoma Well-Known Member
    Colorado
    2017 DCSB TRD Off Road Quicksand
    Sunroofs are over rated, I never use mine. Might be kinda cool in a regular cab though.
  5. Jul 3, 2020 at 9:53 PM
    lambo
    lambo actually dumb
    Phil
    Lone Tree, CO
    2002 Double Cab TRD OR
    I have an OEM one on my truck and I love it. I never have any issues with sun beating down on me through it due to the tint. The additional headroom is nice, and the added "airiness" of the cabin with it is nice. And it's great to just pop open. I personally wouldn't trust an aftermarket one, though.
  6. Jul 4, 2020 at 3:46 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I have a Factory one in my 4Runner I forget about it because it never worked when I bought it never had the urge to mess with it.
    I had visions of having it open and never close
  7. Jul 4, 2020 at 5:39 AM
    Brahms
    Brahms Well-Known Member
    Houston, TX
    2004 Tacoma DCSB 4x4 SR5 V6 TRD
    No, I purchased my 2000 Tacoma with an aftermarket sunroof.
    1. No proper drainage because it wasn’t engineered for it
    2. Wind noise from old and cracked gasket
    3. Water leaks
    3. Hard to find replacement parts years from now
    4. Constant sun beating down on you
  8. Jul 4, 2020 at 6:39 AM
    Brokebrute
    Brokebrute Well-Known Member
    Joe
    2004 Tacoma TRD
    Grey wire mod and 2 low mod
    Extra head room? The factory sun roof on my 96 Tacoma took at least 3" of head room out that truck. My head hit the roof on bumps, less than an inch of clearance. The rest of the Tacoma's I have owned 95.5, 97, and 04 all have 3 to 4" of clearance.
  9. Jul 4, 2020 at 11:36 AM
    lambo
    lambo actually dumb
    Phil
    Lone Tree, CO
    Must be your seating position because where I sit, my head is directly under the glass. A pane of glass is thinner than any combination of sheet metal and headliner, hence why I have more headroom.
  10. Jul 4, 2020 at 12:11 PM
    Madjik_Man
    Colorado Front Range
    Sounds like your mind is already made up and you're just countering any advice given.
    So I'm not sure why you're even asking for advice/opinions?
  11. Jul 5, 2020 at 4:26 PM
    Tacoma1997White4x4
    Tacoma1997White4x4 [OP] America First
    West Covina, California
    1997 white 4x4 auto 4cylinder Singlecab, 2001 auto rwd 2.4l single cab flatbed
    Km3’s 31’s,Lift,Sliders,rear ARB air locker,on board air, armor, hi shell
    cus i want to hear peoples advice........
  12. Jul 5, 2020 at 4:27 PM
    Tacoma1997White4x4
    if you dont like it gtfo here
  13. Jul 5, 2020 at 4:29 PM
    Madjik_Man
    lolwut?
    Dial back the ft-lbs, Conan.
    TheCochese likes this.
  14. Jul 5, 2020 at 4:31 PM
    Tacoma1997White4x4
    Were discussing it, its my thread you come in like a dick, gtfo here you bum
  15. Jul 5, 2020 at 4:39 PM
    #35
    Madjik_Man
    I, along with everyone else, gave you sound advice.
    I’m not being a dick. Dial back the sensitivity.
    I just pointed out that every bit of advice that was suggesting “no” was quickly countered by you.
    So it appears as though you already have your mind set.
    Good luck with whatever your decision is.
    TheCochese, joe25rs and Abeyancer like this.
  16. Jul 5, 2020 at 4:42 PM
    #36
    Tacoma1997White4x4
    Get outta here, bye weirdo
  17. Jul 5, 2020 at 6:46 PM
    #37
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Now nobody gets to play
Thread Status:
