Should I get alignment now or later?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Darren.clark, Sep 16, 2022.
  1. Sep 16, 2022 at 10:34 AM
    Darren.clark
    Darren.clark [OP] Member
    Cement 2018 trd sport
    Just finished lifting my 2018 Trd sport. Don’t laugh it’s a spacer lift. Kept stock tires and stock wheels but my steering is off and I know I should get an alignment.
    gonna put new larger tires on soon.
    should I align now or wait until the new tires are on there? Would like to get steering straightened out and tires aligned but would it be dumb to align now? Will putting new tires on not affect alignment or would I have to do it again after the new tires too?
  2. Sep 16, 2022 at 10:35 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    You can do it now. Tires don't change the alignment specs, just the frequency of rubbing if you go wider/taller.
  3. Sep 16, 2022 at 5:33 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    I asked myself the same question after a simple 3/4" Spacer/1.375" lift. Did not have an alignment done and the tires wore really fast. When I did have an alignment done the Toe was 15/16" out. Do the alignment.
  4. Sep 16, 2022 at 7:00 PM
    Darren.clark
    Thanks guys. Got it done today.
    drizzoh and Chew like this.
  5. Sep 17, 2022 at 5:23 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    Just curious, was it out?
  6. Sep 17, 2022 at 10:33 AM
    Toycoma2021
    More importantly, how was it out?
    FL_TRD Sport[QUOTED] likes this.
  7. Sep 19, 2022 at 4:04 PM
    Eli0841
    Eli0841 Well-Known Member
    Elias
    2019 Cement Tacoma TRD Off Road
    Following this to see what OPs readings were
  8. Sep 19, 2022 at 6:38 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Bet the spacer lift is gonna bite you in the butt down the road. I'll laugh now, knowing for a few hundred bucks more you could have gotten a Bilstein 5100 Lift.
    18CHUÑO and Superdave1.0 like this.
  9. Sep 19, 2022 at 6:40 PM
    Bishop84
    Bishop84 Well-Known Member
    There's thousands of tacomas out there on spacers. Most are happy with them. Plus it sits higher than a 5100 lift, and to some rides better.
    pahaf and Darren.clark[OP] like this.
  10. Sep 21, 2022 at 8:37 AM
    Darren.clark
    Hey guys—— sorry it’s been a while since I’ve responded. My alignment went well. Steering arms needed a little adjustment and my tires were a little out of wack. I could tell by looking at it still up on the jack stands after the lift that itd need adjustment. Will post photo of the printout here in a bit.
    10thMTNgrunt and bulalo like this.
  11. Sep 21, 2022 at 8:42 AM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    The good thing is you were driving it with stock tires after the lift and there’s no vibrations/issues. It’s now easier to pinpoint issues (vibrations ) that occur after you get new tires installed .
    Toycoma2021 likes this.
  12. Sep 21, 2022 at 8:52 AM
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    Unless you thrash the truck off road there is nothing to bite him in the butt down the road. Good quality spacers are $60 on Amazon and if you DIY and know what your doing you don't need an alignment so have no other costs. Truck even had a complimentary alignment check whilst in for service and verified no alignment needed. Bilstein's are $300 plus labor for swapping springs or new springs if you cannot DIY plus alignment if needed. Easily $500+. I agree that 5100's are better as that is what I am on now but the hatred on spacers is misguided and antiquated.
    Darren.clark[OP] likes this.
  13. Sep 21, 2022 at 8:54 AM
    clg
    clg Well-Known Member
    2017 Off-road
    Not being able to tell if a vehicle is or is not performing well, isn't synonymous with it performing well.
    Reggie4x4 and Toycoma2021 like this.
  14. Sep 21, 2022 at 9:59 AM
    Darren.clark
  15. Sep 21, 2022 at 11:27 AM
    Toycoma2021
    I agree with take it slow and incrementally in modifying one’s vehicle. As pointed out earlier in a post above that doing one thing at a time helps with troubleshooting problems. Spacers are a good start and if the vehicle is going to stay on pavement with no on pavement thrashing then that is all one may need.
    In your experience you somehow got lucky and seem to not need an alignment. Most will not be that fortunate.
  16. Sep 21, 2022 at 1:05 PM
    CalcityRenegade
    2023 T4R ORP KDSS
    It all depends on what you want out of the vehicle and how deep your pockets are. Want to tear apart your brand new truck and throw $10k at it? go ahead and enjoy, I wish I could. For me in the beginning I was looking for more looks and the spacer did its job. Now that I wanted more out of the suspension quality I upgraded to 5100's I sold the spacer to recoup a coupe bucks. If it were not for wanting different ride quality I would have just stuck with the spacer.
  17. Sep 21, 2022 at 1:07 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    They did a pretty good job on that alignment. Hopefully they did an initial alignment and then destressed the suspension and performed a second. These trucks are super sensitive.
    It's weird to see caster that low since I'm used to the numbers for fitting 285's. I would be rubbing like crazy lol.
  18. Sep 21, 2022 at 1:31 PM
    Toycoma2021
    Precisely, too many people want to do it right right out of the box. I myself am only use to a straight axel and manual trans. This is going to take some getting use to.
  19. Sep 21, 2022 at 4:33 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Yes, as long as he does not go off roading....
    18CHUÑO likes this.
  20. Sep 21, 2022 at 7:24 PM
    AZPhys13
    AZPhys13 Well-Known Member
    2021 TRD OR DCLB - MGM
    Planning to install some 5100s up front this weekend. If I mark the alignment cams ahead of time and only plan to go to the second circlip location, any idea how out of whack things will be when I get the truck in for an alignment on Monday?
