Should i get c load or e load goodyear
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 09tacomg, Jul 31, 2009.
  1. Jul 31, 2009 at 3:34 PM
    09tacomg
    09tacomg [OP] Active Member
    USA
    09 DC TRD Sport SW
    Leer 100R
    I am looking at the goodyear duratrac or the goodyear mtr.
    265 70 17. Should i get the 6 ply(C) or the 10 ply(E)
    Thanks
  2. Jul 31, 2009 at 3:36 PM
    RCBS
    RCBS Well-Known Member
    Harden your bark, there are storms on the horizon.
    difference in cost?
  3. Jul 31, 2009 at 6:20 PM
    4getful
    4getful Senior Junior Member In Training
    Dan
    Gilbert, AZ
    09 DCLB 4X4
    6" Pro-Comp Stage 2, 35x12.50x20 ProComp Xtreme All Terrain, 20" KMC Revolvers, 4.88 Gears, Banks Exhaust De-Badged
    I am thinking that most would say go with the 6 ply. The weight difference is probably pretty large? The cost would be less with the 6 ply. I am not a tire pro though!
  4. Jul 31, 2009 at 6:33 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    C is more than enough for a taco, but if u do lotta gravel roads the 10 plies might save you. E is 3300 lb +/- rated, think of 3/4 tons, C is more like 2200 lb +/-. E will be stiffer sidewall and heavier a bit less mpg at the same size, 265/75 r 16 can be had in E or C.
  5. Jul 31, 2009 at 6:38 PM
    TEX357
    TEX357 TX
    05 TACOMA
    285\70-17 BFGoodrich KM2's 17x8 Pro Comp 7089
    Yeah E is very heavy. You should go with C.
  6. Aug 1, 2009 at 8:18 AM
    dw77x
    dw77x Those are not my pants
    SE Wisconsin
    2009 Tacoma Sport LB
    5100's all 4 corners (front at 2.5"), rear tsb springs with 1.5" AAL, 265/70/17 General Grabber AT2's
    Do you tow much? The E rated tire will havd a stiffer sidewall and you will sway less while towing. Also may get a stiffer ride. I am putting tires on in a few weeks myself, currently leaning to the E rated tire.
  7. Aug 1, 2009 at 8:20 AM
    Uhaul-n-azz
    Uhaul-n-azz Well-Known Member
    fayetteville,AR
    4Runner Stock
    C is plenty.
  8. Aug 1, 2009 at 8:49 AM
    06Bluez
    06Bluez Well-Known Member
    Phoenix, Arizona
    06 4x4
    Icon Coil-overs, TC UCA, with Bilstein 5150 and Icon 3 leaf pack. 17" Moto Metal 951 4.5" Backspacing wrapped in 285/70/17 BFG AT's. Demello front bumper and Avid offroad sliders.
    If you are having such a hard time figuring out what ply just go with whats in the middle.. 8ply!!!! I have 10ply and its way to heavy I hate it.
  9. Aug 1, 2009 at 8:51 AM
    Tacoyota
    08 4wd
    255/85 r16 has my interest, can be had in load range D, also overkill on tacos though.
