Should I get K&N PERFORMANCE AIR INTAKE SYSTEM for my 2.7 2020?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by philsharyn, Jun 25, 2021.
  1. Aug 4, 2021 at 10:49 PM
    #41
    kauaihunter
    kauaihunter Well-Known Member
    Jay
    2021 SR Dbl Cab 4x4 and 2017 SR5 Dbl Cab 2wd
    Kicker speaker upgrade Tint Trimmed air dam Taco Tunes amp and sub 275/70/17 Wildpeaks
    Had a K&N on my 08 V6 when I bought it with 5k miles. First time I floored it I was like WTF? Put it on Craigslist to see if someone wanted to swap for a stock set up. Guy came right away and we swapped boxes and filters on the spot. Ridiculously loud!
  2. Aug 5, 2021 at 12:29 AM
    #42
    Sasquatchian
    Sasquatchian Well-Known Member
    For some reason my '18 Taco came with that damned TRD cold air intake - as if it was any different than the stock system. First thing I did was toss the oiled filter and replace it with the stock Toyota paper filter, which not only is the same size and fit but filters better and has more flow than that cotton one. They're marketed as "high performance" but no one will show you any actual numbers supporting that claim. I mean TRD claims that but they will NOT show you any numbers. What does that tell you. It tells you it's marketing hype, better known as bullshit.
  3. Aug 5, 2021 at 8:15 AM
    #43
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Those K&N cold air intakes can cause issues. Only thing their good for is intake noise unless you have work on the exhaust system. They kept setting off my check engine light on my 01 tundra by fouling the mass air flow sensor.
    GillyLink likes this.
  4. Aug 5, 2021 at 9:35 AM
    #44
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    You may not be using it correctly. It’s an air filter. It’s not going to increase performance but I’ve used them for years with no problems.
  5. Aug 5, 2021 at 10:11 AM
    #45
    Sasquatchian
  6. Aug 5, 2021 at 11:04 AM
    #46
    SRBenjamin
    SRBenjamin Well-Known Member
    Benny
  7. Aug 5, 2021 at 12:12 PM
    #47
    zoo truck
    None
    Idk about letting dirt through...that may be bs. Properly oiled the K&N filter element trapped plenty of crap from going in my 4.7 tundra engine when i washed the filter with their cleaning kit. I never saw any dirt, or debris inside the top of the air box. I used a K&N for well over 200k miles. Engine ran perfect when i sold it last year. Never touched a drop of oil.
  8. Aug 5, 2021 at 12:28 PM
    #48
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    For those claiming the K&N is an engine killer: I have had one of those K&N drop in oiled filters in my 07 FJ Cruiser for about 12 years now. Every 50K miles I take it out and clean / oil per the instructions. I have had zero issues using one for well over a decade now and that motor has 160,000 trouble free miles on it. They filter just fine if you use them right.
  9. Aug 5, 2021 at 12:35 PM
    #49
    Lphonzy09
    Lphonzy09 Well-Known Member
    Texas
    2022 Midnight Black Metallic SR5
    I think it’s more of people getting the idea that the throttle body will get dirtier from the oiled filters. Regardless, if you want to buy it, then buy it. Just keep up with the maintenance. Don’t over oil it. I think people may have had their MAF sensor get lubed up and giving them CEL cause of it. General statement for all cars
