should i get the rear 5100's too?
Discussion in 'Suspension' started by tooth sleuth, May 28, 2011.
  1. May 28, 2011 at 7:08 AM
    tooth sleuth
    tooth sleuth [OP] Well-Known Member
    Ben
    Maine
    Pyrite mica trd offroad
    5100's (front 1.75) all around, rear leaf TSB. Bestop supertop, OEM bed mat. Pioneer 3200 HU, Pioneer GM 9500f amp, Eclipse SC6900 Front, Rear Eclipse 5 1/4, Marv box with Arc 10 sub. Dampened all doors and back wall with BXTII and ensolite, Supertop, blacked out emblems, 2011 grille, bedmat
    Went to get 10K service and mentioned how the truck bottomed out pretty bad with a load in the bed. They looked and said they need to do the rear TSB. Been wanting to lift the truck and this is a good opportunity because they'll do the alignment for free because of the TSB and the 5100 install for free because i'm buying a minivan from them for my wife. Do I need the rear 5100s as well as the front? I'm gonna get bigger tires before next winter, but want the truck to sit level so I'm thinking of having the front 5100's set at 2.5.
  2. May 28, 2011 at 7:11 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    2.5" is too much with just the TSB leafs. You would want an AAL as well.
  3. May 28, 2011 at 12:11 PM
    tooth sleuth
    Ben
    Maine
    i'm still confused as to what the answer to the original question is
  4. May 28, 2011 at 12:17 PM
    JC47
    JC47 Well-Known Member
    British Columbia
    08 TRD Sport DCLB 4X4
    OME 885, 5100's, 1.5 AAL, DC2's, 265/75/16 Duratracs. Leer Cap, Debadged.
    With the rear TSB, set the front 5100's to 1.75 to be level. Installing 5100's in the rear won't give you any lift but will give you a nicer ride.
  5. May 28, 2011 at 3:45 PM
    tooth sleuth
    Ben
    Maine
  6. May 29, 2011 at 3:57 AM
    tooth sleuth
    Ben
    Maine
    so now i'm thinking to get the toytec aal to go with the tsb and 4 billy 5100's.
    will this cause any functional issues? (driveline or stability?)
    should i set the front billy;s at 2.5inches with that set up?
    also, will i be able to fit 285's at some point with this?
  7. May 29, 2011 at 7:35 AM
    JC47
    British Columbia
    There is a ton of info on this site if you search around a bit. If you get the toytec aal on top of the TSB leaf I think your best bet would be to install eibach or ome 885 coils in the front with your 5100's. This will give you 2.5" - 3" in the front and should keep it level with the back, and also give you a nicer ride. A lot of people run 285's with this set up. If you go this route you should look for new upper control arms as well to keep your alignment in spec. Keep in mind everytime you mess around with lift kits you could run into vibration problems and more wear and tear on parts, not to mention worse mpg's with bigger tires etc...
    (setting 5100's to 2.5 will work as well, the ride will be quite stiff though)
  8. May 29, 2011 at 7:39 AM
    RoyR
    RoyR Well-Known Member
    San Diego, CA
    Billies, TSB
