Should i get the TSB? '10 DCLB pre/sport
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jjbsocal, Oct 20, 2011.
  1. Oct 20, 2011 at 4:28 PM
    jjbsocal
    jjbsocal [OP] Well-Known Member
    Jeff
    So☆Cal
    2010 DCLB PreRunner TRD Sport
    Camburg MT; 4.0 Spindles and UCA's, Fox Extended Travel with Resi's all 4 Corners, All Pro Expo Leaf Pack, Method Standard's, BFG AT's, DTLT's, 1st Gen TRD CAI, Magnaflow Pro Offroad Exhaust..
    I currently have a 3-leaf set up.. Ives heard a lot about the TSB, but unsure if i should get it..
    The reason i ask is that for the short term, i was thinking of getting 5100's and/or Toytec pkg to level things out while i save money for spindles, SC, etc..
    I often carry loads in the back, camping gear, firewood, etc.. and other than a little rear end sag i dont notice much else.. although i will admit my truck tends to swerve easily with gear..
    What do you think guys?
  2. Oct 20, 2011 at 4:42 PM
    Tacoma Mike
    Southern Maine
    Worked great for me. I've done quite a few and have had no complaints from customers after.
  3. Oct 20, 2011 at 4:52 PM
    creeper
    creeper Well-Known Member
    Or you could get it because it's better than what you have now and it's FREE. Or you could go spend hundreds of dollars on a new leaf pack since you aren't even unhappy enough to know that you do want the TSB. But I'm sure I'm the crazy one.
  4. Oct 20, 2011 at 5:21 PM
    YotaMark
    YotaMark Well-Known Member
    Mark
    Mentor, Ohio
    08 Tacoma 4 cyl 5 speed 4X4
    Rear Gate security Mod (although I seldom take my eyes off it) "Harsh Ride" Shocks and Springs TSB performed by "Me" New Cooper Discoverer AT3s 265/75R16s (fit well) Front "Tacoma Mike" light mod! Rugged Ridge floor mats. Bought another set of D rings and installed them in my wheel well. Perfect! Just hit the big 6000 Miles 12/19/11, Installed an alarm system to go with my factory power door locks 1/21/12
    Im getting 4 new Shocks, read springs and all the hardware, Wheres the down side?
  5. Oct 20, 2011 at 5:34 PM
    creeper
    This. Don't waste your money on free upgraded hardware.
  6. Oct 20, 2011 at 5:42 PM
    jjbsocal
    Jeff
    So☆Cal
    Well i was thinking of getting a 5100 set up from either Toytec or DSM, both offer AAL or Leaf Packs.. Does the TSB change ride height? Im currently 22" rear and 20.5" front and no Lean, pretty standard for TRD's from what i read..
  7. Oct 20, 2011 at 6:46 PM
    tailwaters
    tailwaters Well-Known Member
    Brian
    S.W Michigan
    2011 Tacoma T/X TRD 4x4
    Sure seems to be a lot of mixed feelings and opinions on this TSB. Mine goes in next Tuesday to get it done. I tow a 4500lb boat and after pulling the boat one time I could clearly tell my old FJ towed much better. Service manager as well as one of the mechanics have had it done to their Tacomas and that had noting but good things to say. I guess I'll be the judge next week. I have a TRD so no shocks for me just springs.
  8. Oct 20, 2011 at 11:23 PM
    ruger1
    ruger1 Active Member
    Western NY
    2011 TRD OFFROAD
    rear tsb, bilstein 5100's all around, trd exhaust.
    I just had tsb done last week along with 5100's all around, very happy with the results.
  9. Oct 21, 2011 at 8:54 AM
    jjbsocal
    Jeff
    So☆Cal
    Did you add a AAL for the TSB? Is your ride level? Did you upgrade your front springs or keep the stock ones?
  10. Oct 21, 2011 at 8:55 AM
    rex99
    rex99 Well-Known Member
    TArdCOMAWORLD
    Proton Cruiser
    Rocket Boosters, Flux Capacitor, Escape Pod, Throttle Body Spacer, Homeroshi, ATRAC disable
  11. Oct 21, 2011 at 12:38 PM
    ruger1
    Western NY
    2011 TRD OFFROAD
    No AAL, and i used the stock springs. 5100's set at 1.75". My front is about 1/2" lower than the back but im ok with that. I haul crap all the time and I will be putting weight in the back for winter real soon and it should sit perfectly level then. pics in my gallery of the stance.
  12. Oct 27, 2011 at 8:42 PM
    jjbsocal
    Jeff
    So☆Cal
    Im thinking after much research here, that for now, I am going to put 5100's on all four corners set @ 1.75 in front and get the TSB done in the back.. Seems to be the best way to level out the taco without risking damage.. Let me know what you all think..
