Should I get these headlight bulbs?
Discussion in 'Lighting' started by beavis87, Dec 26, 2015.
  1. Dec 26, 2015 at 1:29 PM
    beavis87
    beavis87 [OP] Well-Known Member
    El Paso
    '10 Silver TRD OR
    These are fairly new but they look like a rebranded Philips LED H4 bulbs you can buy on xenondepot for much more. My wallet and i like these more. Have bought some other LED bulbs from this vendor and they are good quality. This design seems to incorporate two things I like more than other LED H4 bulbs, a cutoff for the beams that prevents light dispersion and removable heatsink for easier installation with our socket covers. May do it and see how it compares to jumpers LED headlight bulbs. I saw a comparison of Philips and Cree LEDs somewhere and I was impressed.
    http://www.amazon.com/gp/aw/d/B018S...Y330_FMwebp_QL65#immersive-view_1451162178072
  2. Jan 6, 2016 at 10:08 PM
    213sleeper
    213sleeper Active Member
    Los Angeles
    07' DCLB
    Basic fun stuff!
    I wouldn't personally. Alot of people are having issues with the cheaper LED headlights. I would recommend Phillips or Piaa as they're very reputable lighting manufactures.
    12TRDTacoma likes this.
  3. Jan 8, 2016 at 11:59 PM
    Blackout668
    Blackout668 Well-Known Member
    Massachusetts
    2013 Tocoma DCSB Off Road 4x4
    I ordered one from Amazon, check out Optz7 LED they have good reviews.
  4. Jan 27, 2016 at 3:35 PM
    shinobi808
    shinobi808 Member
    2014 Tacoma
    K&N cold air, Flowmaster 50series, Doug Thorley shorties, Grillcraft upper and lower, Bilstein 5100s front and rear w/AAL, Fuel Mavericks 18x9, General grabber AT 285/70/17
    Blackout668 did you already install the opt7 headlight bulbs already?
  5. Jan 27, 2016 at 3:39 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    I would stay away from those bulbs. While they may produce good light output (because it appears it has the proper shielding like a halogen bulb) the weather boot around the base of the bulb will not fit on those LED's. This will leave a large area at the back of your headlight housing exposed to the elements.
  6. Jan 27, 2016 at 3:42 PM
    shinobi808
    shinobi808 Member
    2014 Tacoma
    But what if I was to seal the gap up with some insulation tape will that affect anything?
  7. Jan 27, 2016 at 3:46 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    In theory yes, that is possible. Something else to consider is that the clips that hold the OEM bulbs in will not work with these LED's. That's another component that must be sort of jimmy rigged. When I had my VLED LMZ LED bulbs the clips were just kind of wedged in there. When I went on very bumpy roads the bulbs definitely jiggled up and down.
    While not as flashy, these bulbs discussed in this thread are awesome. Much better pattern and light output than the LED kit I had. https://www.tacomaworld.com/threads/the-ultimate-headlight-upgrade-not-led-or-hid.398066/
    crashnburn80 likes this.
  8. Jan 27, 2016 at 3:50 PM
    PaulK
    PaulK Life is hard. It's harder if you're stupid.
    Paul
    Pittsburgh, PA
    2013 Black Baja Access Cab
    I have the Philips LEDs, and these don't look anything like them. The Philips fit well, and put the light where it's supposed to be.
  9. Jan 27, 2016 at 3:52 PM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    What PVT Pablo says about the boot is true! I've looked for boots not much besides oem. I was thinking about the optz and LEDs or even hids, but cutting the boot to leave the back unsealed?
    On the other hand I've found the jdm astar to be very good LEDs, also I've been pleased with their products in general have a few parts from them on my ride.
    I have them in my tail lights, they don't make the truck do funky stuff like some of the others do!
    I've been running them for a few years now.
  10. Jan 27, 2016 at 3:55 PM
    shinobi808
    shinobi808 Member
    2014 Tacoma
    Pvt Pablo do you think that if I sealed it, it would affect the airflow?
  11. Jan 27, 2016 at 4:02 PM
    Blackout668
    Massachusetts
    I used my oem rubber boot cover entire bulb and the heat sink no water problem.
  12. Jan 27, 2016 at 4:04 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    Airflow isn't a concern. The OEM setup is 'sealed' anyway.
    This was something I could not do with the VLED setup. While I could get the boot over the bulb, I couldn't get the bulb, boot, and clip to all be where they were supposed to be together.
  13. Jan 27, 2016 at 4:08 PM
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Got a link to those?
    Sounds good.
  14. Jan 27, 2016 at 5:33 PM
    Blackout668
    Massachusetts
    Opt7 the heat sink is smaller and supposedly works better to cool off the light. I place the rubber boot to cover the entire units with no water issues that my concern. I have HIDs before the water keep going into my headlights lens. On Airflow concern, the small hole in the middle of the boots it enough to let the heat sink do their job. No issues so far. I wash my truck a lot in the winter especially undercarriage. Don't want any water problem.
  15. Jan 27, 2016 at 7:27 PM
    Blackout668
    Massachusetts
  16. Jan 28, 2016 at 12:35 AM
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Thanks those are the ones I was looking at also.
  17. Feb 18, 2016 at 1:11 PM
    jiujitsu77
    jiujitsu77 Well-Known Member
    ross
    lake jackson
    i ordered a set off ebay for $50. they work great. the brights dont shine higher like regular headlights but the white light makes everything more visible.
  18. Feb 18, 2016 at 1:45 PM
    Blackout668
    Massachusetts
    I looking the white signal and parking lights sets. Anyone have any pictures or brands that they recommend that match with my OPT7 white headlights.
  19. Feb 18, 2016 at 1:52 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Philips H4's have surpassed all of my expectations up to this point. I enjoy running them very much and very much enjoy the reduced eye strain/ fatigue.
    The last statement on your post is actually not true. I have owned 4 to 5 different LED bulbs thus far and ran them all in this truck, all different sizes and shapes and while you may not think that the weather boot will not, the fact of the matter is that they will no matter what. Some will be tighter fits than others but the boots will not have a problem fitting over these.
    While the clips can be a factor for mounting the bulbs, fact of the matter is that even I had to modify my clips and tweak them some in order for them to apply greater tension on my Philips H4's in order to keep them from wiggling around in the housing. When replacing stock for aftermarket LED's people should expect having to tweak the clips some in the first place simply because their design may be thinner or have the base machined/ designed a little differently than stock. If you don't have to than that is just one less thing to worry about.
  20. Feb 18, 2016 at 2:28 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    How are you fitting the retention clip and weather boot over the LED bulbs? There is no physical way that the retention clip can be used as designed with most of these LED bulbs, especially the ones with the large fans on the back.
