should i get wheel spacers ?
Discussion in '1st Gen. Tacomas (1995-2004)' started by taco.cola, Dec 27, 2024.
  1. Dec 27, 2024 at 10:41 AM
    taco.cola
    taco.cola [OP] yota.cola
    Erik
    2004 Tacoma TRD
    Hello everyone, i’m having a slight problem so on my yota i put on some wheels that are a little to big for her. the wheels rub on the inside hitting the frame. The solution i have come up with is getting wheel spacers but i’ve heard it’s not a really good idea. let me know what you guys would do
  2. Dec 27, 2024 at 10:42 AM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    If its only hitting the frame at full lock then don't full lock it when turning - back off slightly. :thumbsup:
    taco.cola[OP] likes this.
  3. Dec 27, 2024 at 10:44 AM
    taco.cola
    Erik
    2004 Tacoma TRD
    your right but i also like the look of having some tire sticking out which is why i consider getting wheel spacers.
  4. Dec 27, 2024 at 11:03 AM
    steel wheels
    steel wheels Well-Known Member
    2020-ACLB-4x4-Sport-M/T
    what was the reason given as to why wheel spacers are no good ?
  5. Dec 27, 2024 at 11:29 AM
    TAZMINATOR
    TAZMINATOR Well-Known Member
    2017 Tacoma
    While wheel spacers are generally safe for on or off-roading, you should note that increasing your wheel's offset will; Place additional stress on the axle's studs. Make slow-speed turning more difficult. Increase the tire scrub radius, altering how your vehicle handles turns.
    So, it is up to you to get spacers.
