Should I go back to an OEM exhaust or is there a better aftermarket?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TimTeabag, Apr 17, 2025.
  1. Apr 17, 2025 at 8:09 AM
    TimTeabag
    TimTeabag [OP] New Member
    Should I go back to an OEM exhaust or is there a better aftermarket? I have a 2012 tacoma, PreRunner trim with the 4.0 V6 in it. When I first got it I was just getting into working on my own vehicles and at the recomendation of a friend I swapped the exhaust for a Flowmaster 717881 FlowFX Cat-back Exhaust. It was a fun, cheap, and easy swap but after a couple of years I've realized its kind of annoying volume-wise and the tacoma's engine doesnt seem to have that great of a sound. What do ya'll recomend I do? (First time using the forum so sorry if this isnt the best post)
  2. Apr 17, 2025 at 8:35 AM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Stock or you could get one of the non-loud Flowmasters like I think the 70 series?
    BTO likes this.
  3. Apr 17, 2025 at 8:56 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    A) Most 6 bangers don't sound pleasing to the ear when amplified.
    B) I'm not aware of any aftermarkets that have mass-produced a reliable helmholtz chamber - which is absolutely needed if you intend to run loud without the fart-can drone sound. I am aware of one fabricator that makes them custom. Actually, I never even heard of helmholtz until I started reading up on exhausts for four cylinder cars.
    Go stock or look up dirtydeed's fab shop.
  4. Apr 17, 2025 at 8:59 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    I don't think I could ever make myself go back to a stock exhaust, but it sounds like a good time to sound deaden the cabin :). Depending on the exact noise you are trying to get rid of, adding a resonator might also help.
  5. Apr 19, 2025 at 7:44 PM
    tacokarl
    tacokarl Big Blue
    Karl
    Connecticut
    2008 Pre-Runner SR5 DCLB
    Just go with an aftermarket option — it’s cheaper, and any exhaust shop can weld it in for a pretty low cost. I’ve got a Flowmaster 40 Series Delta Flow on mine. It sounds great, definitely louder than stock, but not obnoxious. If you go with anything higher in the series than the 40, you’ll probably be really happy with it.[​IMG]
  6. Apr 19, 2025 at 8:18 PM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    I grew up with V8s. You can't do anything that will make a V6 sound as good...at least under 7k RPM.
    Besides, these days, you get very little benefit from aftermarket exhausts anymore.
  7. Apr 19, 2025 at 8:25 PM
    Steves55
    Steves55 Well-Known Member
    Palm Desert, Ca
    2023 TRD Off Road
    Aftermarket exhaust on a Tacoma sounds like shit. Go stock or buy a V8 Tundra
  8. Apr 19, 2025 at 9:51 PM
    tacomavan
    tacomavan Well-Known Member
    Oregon
    the only V6's that sound good are flat 6's
  9. Apr 19, 2025 at 10:23 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Stock oem
    They cost 600+ but it will fit right and last a long time without rusting out
    JAGCanada likes this.
