Should I go back to stock and return 5100/5160 and should I sort of level it or not?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RaminMan, Nov 1, 2022.
  1. Nov 1, 2022 at 6:57 PM
    RaminMan
    RaminMan [OP] Well-Known Member
    Littleton Colorado
    2020 Super White Tacoma TRD Off Road
    Hey tacomaworld
    I originally was planning on leveling the truck to be able to fit a 275 70 17 on my 2020 trd off road tacoma, but have herd bad things about the process of leveling.
    Is the factory rake actually a good thing even if I dont tow anything? Will lifing the front about a half inch cause the rear to sag when I load it up with camping gear?
    I also herd that the ride quality is pretty rough on the bilatine 5100 on the second clip(0.65) clip setting. Is this true?
    Should I go ahead and return them since they have a 30 day return policy(got them at 4wp).
    Sorry about the indecisiveness, but I want to know if they will be better than stock since I really like the way the stock TRD off road drives and would like to know if they are worth it to keep!
  2. Nov 1, 2022 at 6:59 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    If you level it the rear end will squat like a full diaper once you put gear in the bed.
    na8rboy likes this.
  3. Nov 1, 2022 at 7:01 PM
    Bishop84
    Bishop84 Well-Known Member
    Yes it will squat with any load, I've leveled and regretted it.
    You can add a 1" block in the rear with no issues with 5100's, or add-a-leaf, or a leaf spring set. Choice is yours.
    The ride is fine until you go past 3rd clip, after that it becomes quite harsh. 1-2-3 all ride ok.
  4. Nov 1, 2022 at 7:04 PM
    RaminMan
    Littleton Colorado
    Ok thinking I shouldn't level now, should I return the shocks and stick with stock?
  5. Nov 1, 2022 at 7:05 PM
    Bishop84
    I say buy a 1" block, usually 100$ and it will counter the level. Get some lift and 275s!
  6. Nov 1, 2022 at 7:05 PM
    RaminMan
    Littleton Colorado
    does the one inch block change ride quality too much?
  7. Nov 1, 2022 at 7:05 PM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    What’s the urgent part?
    man, just do some reading. There’s so much info on here. Take a few minutes and figure it out.
  8. Nov 1, 2022 at 7:06 PM
    Bishop84
    Zero, its a very typical thing to do on Tacomas, even the factory TRD lift kit has a 1" block. It will sit higher, thats it.
  9. Nov 1, 2022 at 7:07 PM
    RaminMan
    Littleton Colorado
    Urgent is for I've tried looking around on multiple forms and reddit too but I only have 30 days to decide to keep or return them and I would need to do it before I put them on to be able to get the full return on them them
  10. Nov 1, 2022 at 7:10 PM
    908tacoma
    908tacoma Well-Known Member
    New Jersey
    2018 MGM
    OME, SPC, TRD
    Not a fan of 5100 myself..or block lift. Why not just spend a little more and get the 275 as well?
  11. Nov 1, 2022 at 7:10 PM
    RaminMan
    Littleton Colorado
    Will the 275 rub on factory suspension?
  12. Nov 1, 2022 at 7:11 PM
    RaminMan
    Littleton Colorado
    I've heard that there were some issues with the block lift not too sure if its completely safe, but I'll definitely consider it though!
  13. Nov 1, 2022 at 7:12 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Going to Reddit for info was your first mistake
    shakerhood, hiPSI and 908tacoma like this.
  14. Nov 1, 2022 at 7:13 PM
    Bishop84
    Leaf blocks are fine up to 1", like I said, Toyota uses one in their own kit.
    Front block lifts are the issue, they have many pros and cons. 5100's are a way better choice than a leveling kit with blocks.
  15. Nov 1, 2022 at 7:15 PM
    RaminMan
    Littleton Colorado
    Reddit was last resort since no one on tacoma had a definite answer, no one that I know has the 5100s, and youtube or any toyota forms had anything really
    Edit: The guys at 4 wheel parts said that they were definitely better but the only issue is that they all drive jeeps
  16. Nov 1, 2022 at 7:22 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Answers are here.
    shakerhood likes this.
  17. Nov 1, 2022 at 7:28 PM
    McFly'sRide
    McFly'sRide Well-Known Member
    Los Angeles
    2022 DCSB Off Road 4x4
    Icon RXT Leafpacks rear, TRD Lift front, 17 inch Methods, Wildpeaks, Heritage Grill, Leer 100XR, Blackout Package
    I have brand new TRD factory 1 inch lift blocks for sale if you're around LA. $50 and they're yours.
  18. Nov 1, 2022 at 7:42 PM
    RaminMan
    Littleton Colorado
    Sorry but all the way in colorado
  19. Nov 1, 2022 at 7:42 PM
    RaminMan
    Littleton Colorado
    Do the 275 70 17s fit on stock suspension, if so I might just go ahead and return because kinda need the extra cash for now.
    Might just save for the trd lift kit instead because of warranty type stuff.
  20. Nov 1, 2022 at 8:14 PM
    02Duck
    02Duck manuals make it better
    2018 4WD TRD Off Road 6MT
    TRD Exhaust, Mobtown bolt on sliders and aluminum tailgate reinforcement, Reverse lights changed to yellow turn signals, LED pods added for reverse, ADD W1 oil catch can, Total Chaos bed reinforcement, rear diff breather to taillight mod, 12" combo led bars behind lower grill wired to high beams, Toyota led bed light kit, 400 watt anytime mod, SSO slimeline front bumper.
    This and took out the part about anything higher than the third notch riding rough. I have experience with the 4th being fine. The spring rate doesn't change unless you change springs. That myth gets spread too often.
    VaToy likes this.
