Should I go to synthetic?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoMan1911, Jan 29, 2013.
Synthetic or Conventional
  1. Synthetic
    72 vote(s)
    80.9%
  2. Conventional
    17 vote(s)
    19.1%
  1. Jan 29, 2013 at 4:30 PM
    TacoMan1911
    TacoMan1911 [OP] Well-Known Member
    LA
    2015 TSS DCSB Black DENALI EATER
    My truck currently has 35,000 miles on it and I am running toyota conventional 5w-20 oil. Should I go to a synthetic or heavier weight oil like 10w-30.
  2. Jan 29, 2013 at 4:34 PM
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
    I started full synthetic when I bought my truck and it had 41k on it...
  3. Jan 29, 2013 at 4:58 PM
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    You're in LA. Synthetic in the drivetrain is mostly beneficial in cold weather places. It's essential in cold weather environments, IMO. Nevertheless, synthetic would work fine for you. Synthetic has longer change periods, so you'll have to do a cost ratio. Don't go to 10w-30 for sure.
  4. Jan 30, 2013 at 1:47 PM
    TacoMan1911
    LA
    Ok, I just thought that 5w 20 was a little light for hot climates. I guess 5w 20 conventional is fine for where I am. Just was worried about engine wear and all that stuff, because the 5w 20 seems pretty thin to me.
  5. Jan 30, 2013 at 2:38 PM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    several things to consider with oil weights. I run Castrol conventional 5-30. Climate is one buy one of the main things is tolerances within the engine. Some have tight tolerances and require lighter oils. With today's engines it is probably best to err to the light side. As far as synthetic I think it is more about how often do you want to hangs it. Lighter oils also improve mpgs.
  6. Jan 30, 2013 at 3:02 PM
    RJ MacReady
    RJ MacReady professional trousersnake charmer
    RJ/Mike Hauncho/HeavyHands
    US OUTPOST North 31-Mayday Mayday! We've found som
    00 4Runner 4WD LTD - Cheatin' Bitch Build 2
    Cheatin' bitch build 2: All stock for now... 99' Tacoma 4wd TRD Cheatin' bitch build 1: BG44K additive, motul 5w40(always), deckplate mod, K&N washable air filter, 2.5" flow master(cut thanks to Airdog), king fronts 2.5", all pro standard leaf pk, stainless steel rear ext brakeline, 5125's 10" travel rears, 4-jasper offroad 6" pod LED spot lights, secret compartment for small bottle of wild turkey, cobra CB, Hi-lift jack w/locking bed mount, hi lift curved bumper lift & road base plate, smittybuilt X20 winch, wab fab F&R bumpers w/ hitch receivers, smittybuilt 4in1 recov tool, 10gal mini flamethrower, 11 lbs dynamite sticks, 13 4-hr snowflares, .50Cal full auto mounted machine gun w/ RPG unit & a shitoad of death metal to fuckstart your brain...everything you need for first contact with a shape-shifting alien entity frozen for over 100,000 years reanimated & immitating all life it engulfs.
    ALL very good points, however once your motor hits high mileage like mine @ 208K, i would highly recommend synth n quite possibly thicker grade such as 5W40 or 10W30.
    *If you're in traffic a lot which is most of LA, also check your water pump for leaks n watch your coolant level.
  7. Jan 30, 2013 at 3:45 PM
    Bullfrog
    Bullfrog "I think I know more than I do."
    McLaren
    North Bend
    98 V6 4x Limited Ugly Canadian Green.
    Accessory Box with CB attached. Alpine Type S front and back. LineX. Bedline SKidplates. In progress: Bilstein 5100s with BFG mudterrains 33x10.5 A/C compressor to Onboard Air compressor mod.
    I think this topic has been burned into the ground. Someone asks everyday.
  8. Jan 30, 2013 at 5:49 PM
    dmaxryan10
    dmaxryan10 TACAMO
    western nc
    02 tacoma "tacamo"
    lifted with mickey thompsons with 33's, wrapped in mossy oak break up, trd e locker with grey wire mod, CB with big @$$ antenna.
    do it. 5w-30 synthetic is what i use.
  9. Jan 30, 2013 at 6:07 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Been running synthetics in all the vehicles I've ever owned.
    This tacoma got it at new...1500 miles.
  10. Jan 30, 2013 at 6:35 PM
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
    My wife's Accord uses 0w 20. :eek:
    But it is a synthetic blend. Freaked me out when I first head this. But that's what Honda calls for, at least in her V6 Accord.
  11. Jan 30, 2013 at 6:51 PM
    dmaxryan10
    dmaxryan10 TACAMO
    western nc
    02 tacoma "tacamo"
    that's that energy conserving crap haha.
  12. Jan 30, 2013 at 10:20 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    our manual recommends the same.
  13. Jan 31, 2013 at 7:06 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Stick with the same weight oil but def switch to synthetic.
  14. Jan 31, 2013 at 12:05 PM
    WVTacoma08
    WVTacoma08 Well-Known Member
    West Virginia
    '20 TRD PRO Super White
    Just traded off a '10 T4R on my '11 Taco & the 4Runner called for 0W20
  15. Mar 15, 2013 at 11:29 AM
    pjs42
    pjs42 Well-Known Member
    Penna
    Red,off road,4x4,auto
    Conventional for me, just make you change it every 4 to 5 K, u won't go wrong
  16. Mar 15, 2013 at 11:40 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    sure, if you want to. Not gonna hurt it.
  17. Mar 15, 2013 at 12:22 PM
    Raddbus
    Raddbus Well-Known Member
    Russell
    Santa Maria
    TRUE BLU TACO
    Illuminated 4X4 switch, 3" lift,
    I would, and I have, this first thing I did when I got home after buying my truck used, was to change to Mobil 1. IMO, the GREATTEST Synthetic oil out there.
    My experiance with Mobil 1, the very frist time I changed to it, I was doing to many things at once and forgot to tighten the drain plug...I know, rookie mistake, but anyway, the drain plug came out while I was traveling and it was quit a way from my destination but I didn't relize it was gone till I got to my destination and it was only after I tried to restart my car the the engine light came on, or I didn't see it before. Well I thought I FRIED the engine but I replaced the plug, bought 5 more qts of Mobil 1 and NEVER had a single problem with my engine, put 110,000 miles since that time. DO IT!!!
  18. Mar 15, 2013 at 2:29 PM
    DirtEater
    DirtEater Well-Known Member
    Surprise, AZ
    I have a hard time believing that your oil broke down due to a turbocharger, unless you had some kind of faulty turbo....
  19. Mar 15, 2013 at 3:43 PM
    marchev90
    marchev90 Well-Known Member
    Tony
    05 SR5 TRD 4x4 6spd
    I just switched my tacoma to Mobil 1 as well... 136k on speedo
  20. Mar 15, 2013 at 8:45 PM
    Raceline08
    Raceline08 Well-Known Member
    Brett
    Santa Rosa, ca
    Silver 08 DBC SB 4x4 TRD Offroad
    front Billies, 885x coils, taco lean spacer, TC UCA'S, Magnaflow 22" OME Dakars, Billy 110 rear's, B.A.M.F CMC, custom made E-locker guard
    Bought my truck used at 65,000. I don't know the history of the oil/ changes but I'm just running toyota oil and filters. The oil is changed every 3000 miles ( by me ) or how many months its been sence changed last. I don't put a lot of mile on my rig and I won't let the same oil sit in the engine for a year cause that's about the mileage I do about 5,000.
    I'm prob wasting money changing it every 6 months or around there but with only 2,500 miles. To me oil gets contaminated etc. I don't do a lot of commute traffic but stop and go sucks on your engine.
    In my case the toyota oil is cheaper for my application. Synthetic is a great oil lots of people swear by it.
    Thanks
    Brett
