Should I have the dealer replace my rear LSD?
Discussion in 'Off-Topic Discussion' started by Tacoma 2, Jul 25, 2011.
  1. Jul 25, 2011 at 8:35 PM
    Tacoma 2
    Tacoma 2 [OP] New Member
    Bay Area, CA
    07 PreRunner TRD Sport
    Rear limited slip differential is causing rubbing/vibrations when turning left or right at slow speeds. I'm sure there is damage to the gears because of this. Has anyone ever experienced the same problem and if so what did you do? Have the rear limited slip differential replaced or continue to change "LSD fluids" until the vibrations/rubbing sounds go away? Any input would be appreciated.
