Should I have the Toyota Dealer do a Full Flush of my Transmission?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomawithArima, May 11, 2022.
  1. May 11, 2022 at 7:41 AM
    TacomawithArima
    TacomawithArima [OP] Active Member
    East Bay California
    2014 Tacoma TRD OR Baja Black
    I spoke with my Totoya Dealer in Oakland CA and they quoted me around 320$ for a full flush and fluid replacement using a machine for the automatic transmission on my 2014 Tacoma with 60k miles.
    I heard mixed reviews on full flushes but given this is a long standing Toyota Dealership they must know how to flush toyota trannies without damaging them.
    What are your thoughts?
  2. May 11, 2022 at 7:43 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    You "should" be fine at 60k to do a flush.
    Personally I would find a local trans shop and have them do a trans service. Drop the pan, clean the filter and magnets and then refill. I got mine done for about 180 bucks.
    usmc2msu and TacomawithArima[OP] like this.
  3. May 11, 2022 at 7:45 AM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    I did the fluid exchange at 100 000km. Shifted even smoother than before. It’s 150 000 now and not a lick of trouble from the tranny.
    TacomawithArima[OP] likes this.
  4. May 11, 2022 at 7:47 AM
    syswalla
    syswalla Knob
    5557 ft.
    2015 DCSB TRD OR
    Toyota recommends tranny flush at 100K and every 50K thereafter for normal usage. Meaning if you're towing you'll want to do it more often.
    I've been corrected on this! See below.
  5. May 11, 2022 at 7:54 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    It's more than likely a BG fluid exchange machine and they'll be using a BG transmission fluid. That's what my Toyota dealer uses and I had them do the exchange service on my old 2nd gen (the 2009). It was higher miles never been serviced at 140K, but I didn't have any immediate problems nor did it solve anything. That trans was on its way out before all that. Same dealer did two transmission fluid exchanges on my 2014 (one recently) and it shifts really well.
  6. May 11, 2022 at 8:06 AM
    Evostaco
    Evostaco Jack of some of the trades, master of maybe 2
    Nebraska
    2021 tacoma offroad, mt, superwhite
    I typically stick to just filter, and replacing lost fluid from that
  7. May 11, 2022 at 8:13 AM
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
    I only go to a Independant shop and get them to do a drain a refill. I don't go to the dealer anything.
    tacoman45 likes this.
  8. May 11, 2022 at 8:14 AM
    fourfourone
    Same. 3 local dealers told me to do the same.
  9. May 11, 2022 at 1:46 PM
    motorhead310
    motorhead310 Well-Known Member
    Pomona , Ca
    2006 Taco Pre-Runner
    I had the dealer flush mine for about the same price. As an added bonus, they replaced the clock spring under a recall which caused my SRS light to turn OFF. I then drained a quart at home and added an ATF additive that is highly recommended on here. I forgot the name . My truck Al had about 170k and the old fluid was the original stuff. I now have 196k and no problems since then.
  10. May 11, 2022 at 2:08 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Was the additive called “LubeGuard”?
  11. May 12, 2022 at 3:36 AM
    motorhead310
    Pomona , Ca
    Yes, Lube Guard
    Ricardo13x likes this.
  12. May 12, 2022 at 9:34 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Save your money and drive it. When the transmission dies somewhere north of 400,000 miles then get it rebuilt. You'll spend more paying to get it serviced every 50,000 miles than it will cost you to have it rebuilt. And it won't last any longer.
    TexasWhiteIce likes this.
  13. May 12, 2022 at 12:02 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    That’s s not in my maintenance schedule. That’s s the radiator flush schedule. Toyota recommends a flush every 60K under special operating conditions. Many of us do it as regular maintenance. Or, do the drain/refill process every 30-40K. And replace the ATF filter near 120K.
    syswalla[QUOTED] likes this.
  14. May 12, 2022 at 1:06 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Not a chance. 60k miles full 12 quart fluid change @ 10$/qt for proper toyota WS fluid = 120$ every 60k. 400k/60k * 120 = 800$. If you get a full proper transmission rebuild for 800 bucks you have either provided other services to your transmission guy or are getting shafted on a proper rebuild.
    FYI, toyotas spec is 60k mile oil change interval and sooner if its used under "severe conditions", this spec was reduced from the initial 100k mile intervals quoted in the manuals of early 2nd gen trucks.
    Needless to say OP, do it right, you can do it yourself pretty easy if you can watch a youtube video and follow easy instructions. Full system holds right at 11 quarts, get 12.
    Ricardo13x and TheDevilYouLove like this.
  15. May 12, 2022 at 1:52 PM
    Sharpish
    Brian
    Why not apply that logic to ALL maintenance?
    Kyle14Taco, b_r_o and Chuy like this.
  16. May 12, 2022 at 1:58 PM
    syswalla
    syswalla Knob
    5557 ft.
    2015 DCSB TRD OR
    Gah, you're right. I was pulling that from my head and not current spec.
  17. May 12, 2022 at 2:03 PM
    RLMoody
    RLMoody Well-Known Member
    2017 Toyota Tacoma SR
    Auto dealerships are always looking for people with stupid tattooed on their foreheads. Is that you?
    They will sell you everything else they can get away with needed or not. I worked for them and could not stand seeing them rip people off.
    You only go to a dealership when your vehicle is still under warranty. There is no difference between them and a shop down the street. Customer service is nothing but a business tool.
    eherlihy and NAAC3TACO like this.
  18. May 12, 2022 at 2:15 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    I work at a dealer and couldn’t agree with you more. Stealership is a proper discription.
    eherlihy likes this.
  19. May 12, 2022 at 11:13 PM
    TacoTuesday1
    SD CA
    DIY
  20. May 13, 2022 at 12:02 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Lots of opinions as always.
    Most of the fluid is in the torque converter so a pan drop does a couple qts only and no paper filter a screen in there.
    Dealer did mine at 115k as I tow and the trans gets well used. It's a fluid that can break down.
    After my trans had slightly better shifts and I could now feel the converter lock and unlock in 5th.
    One of the few things I let the dealer do besides AC stuff. Now at 185k and all shifts great.
