SHOULD I INSTALL A TURBOCHARGER
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Danelson, Jan 21, 2013.
  1. Jan 21, 2013 at 4:32 PM
    Danelson
    Danelson [OP] Member
    David
    IDAHO
    05 SR5
    I have a 2005 tacoma, its 4 wheel drive and its a 4 cylinder. i am very happy with my truck but recently heard that a turbo charger would give me much more power is this true? i am wondering if it would be worth installing one or a wast of my time. also is there any long term effects i dont want to do it if it will effect the longevity of my truck. Thanks
  2. Jan 21, 2013 at 4:37 PM
    ToyotaTacoma4Ever
    ToyotaTacoma4Ever Get Boosted
    Eric
    Alberta
    Supercharged Tacoma Sport
    Check Out The S/C Build
    A turbo would be all custom and being boosted is the fun part. With everything done right you could make some good power way better then stock but I've never seen it done on a 4 cylinder tacoma? always seen them on the 6 cylinders lol
  3. Jan 21, 2013 at 4:41 PM
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
  4. Jan 21, 2013 at 4:42 PM
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
  5. Jan 21, 2013 at 4:51 PM
    ToyotaTacoma4Ever
    Eric
    Alberta
  6. Jan 21, 2013 at 4:52 PM
    nj636
    Kev
    Jersey
    just giving the OP some incentive :rolleyes:
  7. Jan 21, 2013 at 4:56 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    there's a lot of tech knowledge needed to get a good turbo setup without your engine exploding
    since the OP's asking if a turbo will "add power" i'd assume he doesnt have the technical knowledge to set it up himself
    having a shop set up a good turbo will be a custom $$$$$$$$$$$$$$$$$$$$$$ job
    if you have the $$ go for it
    otherwise, I'd save my money for a supercharged v6
  8. Jan 21, 2013 at 4:58 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Calgary
    2006 Campster Mobile
    My truck is MAGIC
    ONLY IF YOU WANT TO CAUSE PREMATURE WEAR TO INERNAL ENGINE PARTS
    Boost on a naturally aspirated engine: recipe for failure.
  9. Jan 21, 2013 at 5:06 PM
    Fractured
    Fractured FPS-a-holic
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    TRD wheels, TRD cat back exhaust, ScanGauge 2, Debadged, Avid sliders, UWS bed box w/automatic LED light, Led Interior/Reverse/Lic. Plate lights, Yellow Fogs, Flyzeye Light, Color matched grill, Rearview mirror relocate bracket, Power Sliding rear window, Plasti-dipped bumper/"T" emblem
    If you have to ask "if it will do any damage", then no. Unless like someone else said, you want to pay a shop a TON of $$ to do it. It will involve a full engine rebuild to lower the compression if you want it to last.
  10. Jan 21, 2013 at 5:20 PM
    tacokid09
    tacokid09 it's about the off-road miles
    Brian aka B-Lang
    San Luis Obispo, CA
    1997 White AC 5-Lug
    you should so i know how to build a better one ;)
  11. Jan 21, 2013 at 5:31 PM
    Millertime187
    Millertime187 I'll be your huckleberry!
    David
    Clay City, KY
    1995 Taco
    Just a few little things. It's my DD
    HELL YEA DO IT!!!
  12. Jan 21, 2013 at 5:31 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Camburgs, Methods, Vision X, BFG
    Why's that?
  13. Jan 21, 2013 at 5:47 PM
    Spoonman
    Jamie
    Calgary
    My truck is MAGIC
    Well you see, forced induction engines are built stronger. From the rods to the crank to the pistons themselves. Think about it. Forcing air into the engine, using the heat of the combustion gasses. There's a ton more force on the bottom and and top end.
  14. Jan 21, 2013 at 5:48 PM
    PLC721
    Patrick
    Chandler, Az
    i would say if you stayed in a low boost range 6-7psi, you would be fine. I know people who have well over 100k on Trd Supercharged v6's. Now if he thinks he can run 14psi on stock internals than that would be a bad recipe there :thumbsup:
  15. Jan 21, 2013 at 6:15 PM
    Fractured
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    Superchargers generally run less boost than turbos too.
  16. Jan 21, 2013 at 6:47 PM
    seric007
    seric007 Well-Known Member
    just my 0.02... no
  17. Feb 12, 2013 at 7:59 PM
    frrodriguez08
    frrodriguez08 Active Member
    FR
    San Antonio
    2006, 4 cyl, 4x4, Access Cab SR5
    Truck still 1400 miles away
    SUPERCHARGER instead of turbocharger? This will sound ignorant , for all you experts, but I'll appreciate your opinions, my truck is an '06 access cab 4x4 4cyl, manual Taco. 96k miles, runs smooth, up to 23 m/gl!. But I'm also doing research for headers and supercharger or headers and turbocharger? What do you recommend?
  18. Feb 12, 2013 at 8:01 PM
    169.254.255.201
    169.254.255.201 Well-Known Member
    Interwebs
    For most trucks, putting diesel in your tank will achieve the turbocharger effect.
    To answer your question, I would say DON'T install a turbocharger. But hey thats me.
  19. Feb 12, 2013 at 8:36 PM
    Mark350
    Mark350 Well-Known Member
    I wouldn't, it might be fun in the short term but i'd bet it'll be more of a hassle in the long run when it comes to repairs and whatnot.
  20. Feb 12, 2013 at 8:38 PM
    Drummer0247
    Drummer0247 International Jewel Thief
    Michael
    Suprise, Arizona
    2012 MG Tacoma 4X4
