Should I lift my 2020 Tacoma Pro
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mjaramillo, Mar 25, 2020.
  1. Apr 2, 2020 at 3:48 PM
    #141
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    I would just go bigger tires since u have more clearance
  2. Apr 2, 2020 at 5:08 PM
    #142
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    None of these things are pro specific.
    Thegenerik1 and mwaterous like this.
  3. Jun 19, 2020 at 8:04 AM
    #143
    Hot Taco sauce
    Hot Taco sauce Well-Known Member
    WI
    Dclb lover
    Just starting out, give me time
    But the green is sooo good:headbang:
  4. Sep 5, 2020 at 12:11 PM
    #144
    PuyallupJon
    PuyallupJon 2020 AG Pro
    Jon
    Puyallup, WA
    2020 Tacoma
    very nice
  5. Apr 9, 2022 at 7:41 PM
    #145
    TacomaLuvn7
    TacomaLuvn7 New Member
    Earl
    Trd pro
    Westcott designs lift, 17” moto metal links, 285/75/17, Cooper set pro
    I lifted my 2020 trd pro with Westcott Designs lift myself -took me 3 days at home- google all the videos of others doing it- I love my lift- went with moto metal links wheels- 285/75/17 Cooper sst pro - stick with the 275/70/17 to stop rub I went w spydertrax 1.25 i really like.
  6. Apr 9, 2022 at 8:17 PM
    #146
    TheSortaHawaiian
    TheSortaHawaiian Well-Known Member
    21 Lunar Rock TRD Pro
    How did you get the collars onto the shocks? Just hammer directly on the collars or load it into a vise with the collar resting on it and hammer the bottom of the shock?
  7. Apr 9, 2022 at 8:34 PM
    #147
    Pwl
    Pwl Well-Known Member
    Mississippi
    2020 TRD offroad
    255 85 16 and you got 33s with no need to lift .
  8. Apr 10, 2022 at 2:28 AM
    #148
    bludweiaer
    bludweiaer Well-Known Member
    pa
    2017 Pro DBL Cab,,2020 F3L Spyder...Polaris 800..
    avs rain guards,,,tyger auto tubesteps... stealth SR8's.265/70/17,ridge grapplers..shiftsense pro...
    should have bought wheels that did not require spacers for clearance,,
  9. Apr 10, 2022 at 10:23 AM
    #149
    509 buckeye
    509 buckeye Active Member
    Phil
    Eastern, WA
    2018 PRO
    I used some 2x4's and made a ghetto jig. All u need is a rubber mallet to get it the collar started on then I switched to a 5lb sledge and block of wood. WD40 or your preferred lube to make things Slippery
  10. Apr 10, 2022 at 11:39 AM
    #150
    TheSortaHawaiian
    Oh good idea/setup. Just hammer until the perch and collar are even?
  11. Apr 10, 2022 at 12:39 PM
    #151
    509 buckeye
    Phil
    Eastern, WA
    2018 PRO
    Correct.
    Once I got them started the 5lb er got them seated easy
    TheSortaHawaiian likes this.
  12. Sep 11, 2022 at 1:40 PM
    #152
    DRob
    DRob Well-Known Member
    David
    Nor Cal
    2017 DCLB OR4X4 SW
    Fox w/DSC, Camburg UCA, SCS GEN5 17x8.5 -12,
    This looks HOT
  13. Sep 11, 2022 at 1:50 PM
    #153
    DRob
    David
    Nor Cal
    2017 DCLB OR4X4 SW
    Gawd hate seeing those predator steps
