Should I lift my taco?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gun guy, Dec 2, 2016.
  1. Dec 2, 2016 at 8:16 PM
    Gun guy
    Gun guy [OP] Tacoma Fanboy
    05 Trd Off road AC MT & 08 Tacoma 2.7 AC MT
    If I do will it worsen my gas mileage if I keep the same tires on it?
    It came with some pretty nice tires, and they are a bit knobby.
    What kind of lift should I get for about a 3" lift?
    What kind of price would be fair?
    Will a 3" lift cause any reliability issues?
    It's a four banger manual transmission.
    If never done a lift on any of my vehicles before so I'm a noob to the subject. Although I do understand sag ratios and whatnot because I downhill mountain bike.
    Thanks in advance for any input!
  2. Dec 2, 2016 at 8:19 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    You can spend from a few hundred $$$ to a few thousand $$$$ on a 3" lift. You pay for the quality.
    I would say it could effect reliability long term cause it does wear out components a tad faster.
    2.5-3" requires UCAs. Which adds a lot of $$$
    Gas mileage will worsen due to increased drag.
    Don't even look at spacers and blocks.
    TacomaEd15 and ZachMX like this.
  3. Dec 2, 2016 at 8:23 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    3" lift with stock sized tires? :puke:
    ChemDawg likes this.
  4. Dec 2, 2016 at 8:25 PM
    ZachMX
    ZachMX Well-Known Member
    00 AC, 08 DCSB, 11 AC,15 DCLB, 16 DCLB,17 DCSB
    Question is why do you want to lift? For looks? Cause everyone else and soccer mom drives a lifted truck? Or for increased clearance and off road capability...
    Silverspool likes this.
  5. Dec 2, 2016 at 8:37 PM
    Silverspool
    Silverspool Come at me Bro!
    Frank
    DFW
    18T4RORP 17GT350
    Anyone seen my wallet?
    Why you want a lift is a good question, but not to determine if you should lift or not, to determine how much youre going to spend if you do it.
    If you want to lift it for looks, go for it, its your truck. Its why i lifted mine, but i didnt go for icons or kings on a pavement queen prerunner. I went cheap blocks and spacers then those came out after a week for bilsteins,ome,deaver.. much better ride.
    Im at 3 inches with stock UCAs.
  6. Dec 2, 2016 at 8:41 PM
    Gun guy
    Clearance, I drive on some pretty ridiculous place to hunt and shoot.
    Would be nice to not worry as much about scraping the bottom of my truck.
    ZachMX[QUOTED] likes this.
  7. Dec 2, 2016 at 8:42 PM
    Silverspool
    Frank
    DFW
    18T4RORP 17GT350
    What are you looking to spend?
  8. Dec 2, 2016 at 8:43 PM
    ZachMX
    Cool, as someone else mentioned, I would recommend a 5100/coil setup or OME, both are good middle of the line type lifts that won't break the bank and are way better than a spacer/block lift.
  9. Dec 2, 2016 at 9:10 PM
    Gun guy
    1-2k
    Whatever would allow me to keep the least amount of wear on parts.
  10. Dec 2, 2016 at 9:18 PM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    Here's a tread I started when I was looking for a lift.
    https://www.tacomaworld.com/threads/lift-options-seeking-opinions-and-options.461274/
    The ToyTec might be a good option for the $$'s or OME
    I ended up purchasing components from several differnt shops on BF to save some $$
    I went with LR UCA's with ICON 2.5 Coilovers up front and Dakar LP with FOX 2.0's in the rear. I spent about $2,700 for everything. Once I get it installed it should be pretty awesome!
  11. Dec 2, 2016 at 9:18 PM
    10trdtaco
    10trdtaco American Infidel *DON'T TREAD ON ME*
    Shayne
    Lynchburg, VA
    2010 Tacoma TRD Sport DCSB
    4" lift 33-12.50-17 Atturo Trail Blade M/T 17" HELO TRD Satoshi Blackout Grill Tinted headlights with caliraised led headlights ... More to come
    Bilstien lift from toytec would be a good coilover suspension lift for the money!
  12. Dec 2, 2016 at 9:21 PM
    Silverspool
    Frank
    DFW
    18T4RORP 17GT350
    You can easily get a nice lift for 1-2k, does that include labor or are you doing it yourself? Do you have your bed loaded or tow often?
    Send @HeadStrong Off-Road a message with the details and Marie can quote you a nice kit that will get you exactly what you need/want.
    My guess would be bilstein 5100 with ome 887 up front assembled, LR UCAs, lean spacer up front. 5100 with dakars on the rear since if you hunt im assuming your bed is sometimes loaded, deaver single aal if not.
  13. Dec 2, 2016 at 9:22 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    OP.....your rig looks great. Don't touch it. :thumbsup:
    Mike B. likes this.
  14. Dec 2, 2016 at 9:54 PM
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    I personally think the stock wheel and tire size can look pretty good with a 2-3" lift but a lot of people say otherwise, so you could save some money and keep your current wheels and tires and go with a decent but cheap 5100 setup in the mean time. Something else to think about since you have the 4 cylinder, if you did go with bigger tires it might be more of an issue as far as losing more of the trucks original get up and go. Plus it usually requires trimming.
  15. Dec 2, 2016 at 10:01 PM
    soljah111
    soljah111 Well-Known Member
    Jon
    Denver
    11 supah white OR
    None yet
    Go with billistein adjustable and some spacers on your wheels/tires and set at 2.5", wheelers 1.5 progressive add a leaf and you should be able to get away with no aftermarket uca and be close to 1k. You will prob lose about 2-3 mpg.
  16. Dec 3, 2016 at 4:40 AM
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    You could buy a 16 or 17 take off and get an inch.
