Should i off road?
Discussion in 'Off-Roading & Trails' started by acejack, Oct 29, 2013.
  1. Oct 29, 2013 at 5:27 PM
    acejack
    acejack [OP] Active Member
    I have a 2013 2WD V6 Double cab. I am wondering if i should be scared to go off-roading/mudding. It has a 3 inch leveling kit and all terrain tires. I guess my main question is, what is the likelihood i get stuck?
  2. Oct 29, 2013 at 5:28 PM
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    Be afraid, be very afraid :p
    Edit: You'll never know 'til you try. Ain't no sense in wondering, just have a buddy ready to pull you out when you do.
  3. Oct 29, 2013 at 5:34 PM
    Ghost848
    Ghost848 Well-Known Member
    Tony
    Alberta,Canada
    09 V6 TRD OR Silver M6
    OME + Dakers, 285/75R16 Nitto Trail Grapplers, ARB Bumper, Columbia overland Dual battery, Super winch,CC stage 4 clutch, bestop supertop, URD TO bearing, BHLM headlights, Cruisin offroad rear bumper, Harrop front E-locker.
    Go have fun whats the point of owning a truck if you dont go crazy once in a while ;) take it and use it. Just remember play hard fix hard
  4. Oct 29, 2013 at 5:34 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Be smart, dont get overly excited and do something stupid, and no what the obstacle is. That means know the depth of mud holes and water crossings. Be ready to wrench cause stuff is gonna break and go bad, diff and transfer case fluids will need changing, bearings will need changing and such. Never go alone!
  5. Oct 29, 2013 at 5:36 PM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    I did in my 2 wheel drive. Make sure you have a rope and someone with 4wd.
  6. Oct 29, 2013 at 5:55 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Until you actually get stuck, the likelihood of getting stuck is 0%. :cool:
    I think, to an extent, it's great to know the truck's limits.
  7. Oct 29, 2013 at 6:07 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    I would consider replacing the spacers with 5100 shocks. The spacers are known to blow shocks when offroading. Otherwise have fun. I was alittle worried the first time too.
  8. Oct 29, 2013 at 6:22 PM
    Canazes9
    Canazes9 Well-Known Member
    David
    Texas
    '07 Dbl Cab TRD Sport / '12 Dbl Cab Offroad
    This ^^
    And drop you air pressure to about 15-20psi to maximize traction. This is about the cheapest air pump to refill tires that's worth having:
    http://www.amazon.com/Industries-MV...ressor/dp/B000BM8RT8/ref=cm_cr_pr_product_top
    It is sold under a lot of different names at various auto parts stores, just look for the MV-50...
    David
  9. Oct 29, 2013 at 6:31 PM
    richardbui23
    richardbui23 That guy
    Richard
    Arlington Texas
    Stacy
    I do it and I'm open diff 2WD if you do it be careful and don't attempt anything that looks too sketchy unless you have a buddy
  10. Oct 30, 2013 at 12:45 PM
    VanCity4x
    VanCity4x Well-Known Member
    AB
    05 Tacoma
    3link on tons
    Offroading yes, I'd stay away from mud tho. When mine was 2wd I got stuck in mud and on really steep inclines. Struggled with some mild rock crawling but made it through. Anything wet is going to limit your traction. Going through some puddles is going to be fine but I wouldn't try any deep sticky mudding, just going to get stuck. I scratched the shit out of my rims being stupid in mud.
    You'll be totally fine with dry gravel and dirt trails even with a little steepness to it. Get out and try it, offroading is a blast.
  11. Oct 30, 2013 at 12:57 PM
    richardbui23
    Richard
    Arlington Texas
    Stacy
    i've been in mud in the rain in my 2WD as long as you dont go into deep stuff and have good tires with decent tread left you should be ok. these trucks are surprisingly capable in 2wd
  12. Oct 30, 2013 at 1:32 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Right....
  13. Nov 5, 2013 at 3:19 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Stay away from both mud and sand, unless you bring a buddy with a winch.
  14. Nov 12, 2013 at 10:51 PM
    gospurs21
    gospurs21 Well-Known Member
    Brownsville, Texas
    05 x2 Cab Texas Edition V6 prerunner, TRD
    i have a tacoma prerunner and i get stuck often. got new all terrains and it does wonders but still never underestimate the obstacle.
  15. Nov 12, 2013 at 11:12 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    This.
    My dad had a '74 K5 Blazer and we had a blast with that truck.
    Went on a few Terra-Del-Sol runs in Ocotillo, he never did more than replace a flat (and mod).
    The guy he sold it to when he was getting ready to retire ended up breaking shit every time he took it out.
  16. Nov 13, 2013 at 5:55 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    First off - if you've never gone mudding or offroading....some rules of thumb.
    #1) Never go off roading alone. Have another vehicle with you. You need that extra vehicle to get you 'unstuck' if needed. You also need that extra vehicle in case your vehicle breaks down. You also need that extra vehicle in case you have a medical emergency and someone can drive your ass home or to an emergency room.
    #2) Tread Lightly. Do not blaze your own (or new) trails. WHY? Protect our environment and only go on existing trails. Existing trails are safer. Less likely to get stuck or lost. Promote the hobby in a positive manner.
    #3) Since you asked and are obviously concerned.....Find a buddy who's experienced in off roading. Have him/her take you out and teach you the ropes. There are lots of DO's and DON'T's and DRIVER SKILL places a huge importance to not getting stuck AND preventing damage to your truck.
    #4) Go prepared. Again....this is where an experienced 'buddy' can help you.
  17. Nov 13, 2013 at 7:11 AM
    tan4x4
    Rick
    Folsom, CA
    One trick to try, when one wheel is spinning and the other doesn't spin at all, is to put on the e-brake part way. This will cause the spinning wheel to stop spinning, and send some torque to the other side. Helps with posi AND open rear ends.
    Adding a TAD (Traction Aiding Differential) will greatly reduce the likelihood of getting stuck. Cost from $300 to $1600 depending on the unit and your mechanical ability. Lots of choices: posi or locker, automatic or selectable.
  18. Nov 13, 2013 at 5:06 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    And be aware of your grip on the steering wheel.
    KEEP YOUR THUMBS ON THE SURFACE OF THE WHEEL, NOT INSIDE.
    This is not a normal driving grip, so it takes awareness.
    Hitting a rock or a rut at the wrong angle can yank the wheel out of your hands and the spokes will whip around and snap your thumb.
  19. Nov 13, 2013 at 5:12 PM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    Do this: take your truck on the easy trails and get experience Aldo a rear locker might help out but what I really suggest is get a 4x4
  20. Nov 20, 2013 at 1:44 AM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    Or just get an ATV and call it a day.
