Should I order top plate spacers with ome and 5100
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bone Buster, May 26, 2011.
  1. Jun 3, 2011 at 2:45 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    So , what I am getting at is you could still get the longer top bolts which will be under $20 and use them when you put in the 885's , then you are covered if you want to add the top spacers down the road .
    pm TW member Oswego , he has had some issues with his uni-balls , he is in NJ , and an extra on the smash hit show ' Jersey Shore '
  2. Jun 3, 2011 at 2:52 PM
    TheHansen
    TheHansen Well-Known Member
    Mattapoisett, MA
    05 DC Sport
    dtrl mod Fog light mod Bed lights Under hood lights Rear window decals tint matched front windows Rear dif breather mod weathertech floor mats Bed mat Scan gauge 5100's and 885's lean spacer 1.5 in aal, 1" block and OME rear shocks Dynomax muffler (weld in) Truxedo lo pro qt bed cover Devil horn Emblem Plasti dip badges plasti dip radio plasti dip ac control all pro rear bumper with side pieces All pro front bumper All pro bolt on sliders illuminated 4x4 switch JBA long tube headers URD o2 Sim
    I have no problem pulling it apart a seccond time, and if i decide not to add the spacer, i spent the money on longer studs for nothing. Its all good, i'm not worried about it.
    Didn't really think to PM him but i saw his thread where the chorme uni-balls were all pitted. If i recall the date of the thread though he has only had the stainless uni-balls in for a couple months so its not really enough time to tell. Ill double check and probably send him a message anyways.
    sorry for hijacking your thread Bone Buster, but it was kind of on topic.
  3. Jun 3, 2011 at 2:58 PM
    OZ-T
    Peter North
    British Columbia
    Sorry for the thread jack OP , some of that info applies to your situation as well .
  4. Jun 4, 2011 at 7:14 AM
    Bone Buster
    Bone Buster [OP] Active Member
    Josh
    South GA
    06 Tacoma TRD
    Tinted tail lights, 3in lift ome with bill.5100, Ranch hand brush guard, motometal wheels with 33x12x16 mudd grallers, K&N cold air intake
    Here' s pic of the cv axles.
  5. Jun 5, 2011 at 9:19 AM
    sledneck
    sledneck Active Member
    Northern Maine
    2011 TRD Sport DC
    MBRP Stainless Duels, AFE CAI Stafe 2, lBilstein 5100's, 886's, smittybuilt Nerf Bars, UWS box, 6000K HID's, Grillcraft grille, Switchback LED signals and DTRL's, 20% tint,
    How are the 885 on Billies set @ .85? Would you recommend this or have the Billies @ 0? Any pros and cons so far?
  6. Jun 5, 2011 at 9:23 AM
    OZ-T
    Peter North
    British Columbia
    Those don't look too bad although you can't really see the inner one
  7. Jun 7, 2011 at 9:22 AM
    TheHansen
    Mattapoisett, MA
    05 DC Sport
    Can you take a better pic of the inner cv boot? it looks like their touching in that pic...
    im installing my 885's in a few hours
  8. Jun 8, 2011 at 9:17 AM
    TheHansen
    Mattapoisett, MA
    05 DC Sport
    FWIW i installed mine yesterday. 885's and left the 5100's at 0 and 1/4" spacer on driver side. I also removed my sway bar while i had it apart. There is no way i was going to be able to compress that spring enough to get it on at .85 . My current measurements are right around 23" (hub to fender) +.2 on pass side - .2 driver side. and my inner cv boots are verrrry close to touching.
    I got a lot of taco lean...
    ps. the ride is softer than stock coils at 1.75 ( although this is partly due to removing the sway bar i think)
