Should I plasti Dip my Tacoma's front bumper?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ylua, Jan 14, 2014.
  1. Jan 14, 2014 at 8:25 PM
    ylua
    ylua [OP] Member
    Hawaii
    06 4x4
    3in Suspension lift with 32inch Firestone A/T
    Title says it all. Wondering what you guy think? Also got suggestions to do an "EVO MOD". Not quite sure what exactly that is but open to all suggestions!
  2. Jan 15, 2014 at 2:45 AM
    lyodbraun
    lyodbraun Well-Known Member
    NW Ohio
    2006 SR5 TRD Sport
    Nothing yet
    No looks fine the way it is...
  3. Jan 15, 2014 at 4:47 AM
    Phil5393
    Phil5393 Well-Known Member
    Phil
    Long Island, New York
    TRD Sport
    No leave it alone
  4. Jan 15, 2014 at 6:33 AM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Sure, go ahead. If you don't like it peel it off:rolleyes:
  5. Jan 15, 2014 at 8:11 AM
    StZu
    StZu Where the White Women At?
    Richard
    Dallas Texas
    18 Super White TRD Offroad
    Level 8 Wheels, Bilstien/Eibach lift, 2" aal, blacked out rear bumper, AC drain hose relocation, sound deadening 4 doors and back wall, amp/speaker upgrade, 10" daytona sub, LED interior lights.
    Plastidip that grill surround, maybe the bottom lip.
  6. Jan 15, 2014 at 8:33 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Agree with leaving it colormatched red but paint the chrome.
  7. Jan 15, 2014 at 1:54 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    No one likes chrome lol. I PD mine.
  8. Jan 15, 2014 at 2:00 PM
    Riverdog
    Riverdog Well-Known Member
    Collin
    Portland, OR
    '05 Double Cab PreRunner
    I added some Plasti Dip to the front of mine. I sure like it. And it has held up through a bunch of drive through car washes. If you do it and don't like it, just peel it off. Here's a picture of mine.
  9. Jan 15, 2014 at 2:26 PM
    USArchangels
    USArchangels Well-Known Member
    Max
    Houston, TX
    '12 TX Pro Baja
    Stock BAJA: bfg ta ko 16's 60mm racing Bilstein & TRD coil springs up front 50mm remote resevior race Bilsteins in back 71/21 mpg MODS: AeroTurbine 2525XL Muffler on all stainless TRD exhaust. Chopped and dumped TRD Tailpipe. Now 90 degrees. Cut just after axle. aFe ProDry S drop-in air filter Secondary (wire mesh) Filter delete Wilson 4ft Flex Silver Load CB antenna Midland 75-822 CB - hardwired Passport Escort 8500x60 & TomTom GPS unit wired to interior fuse panel with add a fuse BAMF antenna mount (front for CB) Relentless Fab antenna mount (tailgate) Fake Bead Lock delete reversed white wall tires All mudflaps delete Predator Tube Step delete TX Baja decal delete debadged Avid bars front and back SnugTop Rebel Rear Diff Breather mod to bed storage compartment STANT locking gas cap with fishing wire. Interior Map lights - Green LED Interior Dome Light - Red LED ConsoleVault
    No. Bad idea. It will peel after a few months and it will come off in pieces if you ever decide to wash your truck with a pressure washer.
  10. Jan 15, 2014 at 3:01 PM
    Riverdog
    Collin
    Portland, OR
    ^ Good point about the pressure washer.
    I've had it on my truck for about 6 months now and it hasn't come off at all. No chipping, peeling, or flaking. I've been through automatic car washes at least twice a month. Not quite as powerful as a pressure washer though. I did put on four coats so that may be part of the reason why its held up well.
    I've seen videos of people using pressure washers on plasti dipped vehicles and it doesn't harm the plasti dip. However, they weren't very powerful pressure washers. They were the small electric ones. If you go to a car wash where you wash it yourself with a pressure washer, that might take it off if you were close and blasted it. You could just step back a bit when spraying the plasti dipped part to avoid blasting it off.
    As long as you do several coats of the stuff, and don't blast it with a pressure washer it'll be fine. And if I'm wrong and it does come off, the can of plasti dip was only $5.
  11. Jan 15, 2014 at 3:06 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  12. Jan 15, 2014 at 3:12 PM
    Frkypunk
    Frkypunk "Death is what you make of it."
    Timmy
    Woods of P.A.
    2010 Tundra limited,2015 Highlander limited, Prius(commuter)
    Got the gas mileage down to 13mpg! Modification complete
    Am I the only one lost at this question. What part of the front bumper needs to be plasti dipped? Much confusion, so strange!
  13. Jan 15, 2014 at 3:15 PM
    Riverdog
    Collin
    Portland, OR
    I assumed he means just part of the front bumper. Such middle, much lower part, so wow!
  14. Jan 15, 2014 at 4:35 PM
    dilligaff82
    dilligaff82 Well-Known Member
    New Hampshire
    2014 TRD Off Road DCSB
    No evo mod. Looks ricey. Unless you're into rice, then hey it's your truck.
  15. Jan 19, 2014 at 11:52 PM
    KingofBattle
    KingofBattle SHOT OUT
    Tacoma Texas Edition
    3M 5% Window Tint, All-Weather Floor mats.
    On the subject of doing the Plasti-dip, I'm wondering if I should do it with mine? It is a silver with the Texas Edition Texas Ranger styled badges. Since the truck is a silver, I'm not sure how a dark plasti-dip would look and if it would clash with the silver, wondering if anyone has done the same? Pics below:
  16. Jan 20, 2014 at 10:52 AM
    jw1983
    Alberta
    When this project was done it doesn't seem like it was done right. It shouldn't be coming off in pieces. A pressure washer wouldn't be taking it off unless it was done incorrectly. It would only come off in pieces of it was very thin coats or there was a primer put on before the dip was applied.
    As long that you prep the area properly and use as many coats as possible(the more coats, the thicker it should be). I've had my tailgate emblems done since March 2013, Grill, lower valance, roof console and emblems done in July 2013. Back bumper, fuel door done in August 2013. Bed cubbies in August 2013. "Oh shit" handles in September 2013. Out of all those things I have done the only thing that is coming off is the passenger "oh shit" handle because it was thin and get's a lot of use.
    So it will stay on as long that it's prepared properly and there is enough coats, coverage etc. If you are using the stock nozzles that come with the can then you're going to be putting on a lot more than just 6 coats. 6 Coats with stock nozzles you can nick with your finger nail and it will come off. I've used DYC(Dip You Car) nozzles and I have never had a problem with anything that I have dipped. I make sure I'm doing mine right because I am paying $20.00(CDN) for a can of PD.
    MudFlaps-Black-Installed-08-31-13_zps3e7_c059f6923c14cc12652e51aaa0451cb382a6baf5.jpg
    GrillampValanceBlack-Installed_zps3893c5_142cb560c7e69d513301fa1acf1e1ad17e71ba33.jpg
  17. Jan 20, 2014 at 11:02 AM
    Joshua
    Joshua Well-Known Member
    Joshua
    Lafayette, LA
    06 V6 TRD off-road 4X4 Silver Doublecab
    I've done all my badges. I love how silver looks with some black accent. To hell with chrome.
    Yours has a bit more black plastic than mine...I say do it. The chrome stands out a bit from everything else. It'd compliment your truck nicely.
  18. Jan 20, 2014 at 11:07 AM
    Joshua
    Joshua
    Lafayette, LA
    I've seen it all now. The steering wheel.
    I used to have it on my tail lights...that's as crazy as I got
  19. Jan 20, 2014 at 11:16 AM
    jw1983
    Alberta
    You wanna know with the steering wheel. It took me over an hour to tape and plastic everything off. Since that I was using a stock can nozzle, it only lasted 2 weeks because of the use(plus it was very thin). Once Spring gets here then I am going to do it again and use better nozzles. I love the shit, don't get me wrong but for $20.00 a can there is only so much I can do. I am going nuts since that it's winter time and I can't really be dipping my truck in it. I am trying to find things to dip in the house. I've had Blaze Yellow for over 2 months now and I haven't gotten to use it. I just use my Macbook for testing colours, I think I am going to do that this time around and see how it looks.
  20. Jan 21, 2014 at 12:05 PM
    das2123
    das2123 New Member
    Anthony
    Spring, TX
    SR5
    At the 6:30 mark it shows the guy washing the car with a 1800 psi pressure washer.
    http://www.youtube.com/watch?v=vvkq-qyY9aY
