should I put on header wrap
Discussion in 'Performance and Tuning' started by tfeltz73, Sep 5, 2013.
  1. Sep 5, 2013 at 5:18 AM
    tfeltz73
    tfeltz73 [OP] That's greasy Ricky
    central Wisconsin
    2013 supercharged long travel thing
    I ordered Doug thorely long tube headers and was wondering if I should put header wrap on or just put them in like they are, also I have the supercharger so I don't know if that will make the headers hotter
  2. Sep 5, 2013 at 5:33 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Since they are 304 stainless headers, you can. But if they were mild steel, I wouldn't.
    Better bet would be to have a high quality ceramic coat done to the headers. Poldyn.com or Jet hot. Something like that. They won't likely be any hotter as they are, than the OEM headers. Likely a little cooler since there aren't any cats which restrict the flow and heat up for what they are designed to do.
