Should I rebuild or get a used engine, 2RZ-FE?
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacorocker, Dec 21, 2016.
  1. Dec 21, 2016 at 1:26 AM
    tacorocker
    tacorocker [OP] Member
    2000 Tacoma
    Had my truck for 16 years but I think the engine is dying with 240k miles. Hard start, rough idle, etc. Should I rebuild or get a used engine?
    Where is the best place to get a used engine in Socal area? I'm in Corona, CA. In any case, I will not be doing the work myself. Cost of rebuild? Cost of used engine?
  2. Dec 21, 2016 at 1:44 AM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    If you are doing regular maintenance, 240k is not very high mileage to need a replacement.
  3. Dec 21, 2016 at 6:05 AM
    Bxnanaz
    Bxnanaz Well-Known Member
    2021 Tacoma TRDOR 6MT
    Hard starts and rough idle don't mean the engine needs replacing...
  4. Dec 21, 2016 at 5:34 PM
    Pumpman
    Pumpman Well-Known Member
    Bert
    98 tacoma sr5
    Compression test can tell you a lot i open these engines with over 200 and they still have crosshatch marks in cylinders , could be just a headgaskets ,burnt valve or need a cam all a lot easier and cheaper than an engine
  5. Dec 21, 2016 at 7:22 PM
    Bxnanaz
    Heck it could be a bad spark plug, clogged fuel filter, weak fuel pump... it could be anything.
