Should I ReGear?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacoma1997White4x4, Sep 2, 2020.
  1. Sep 2, 2020 at 7:27 PM
    Tacoma1997White4x4
    Tacoma1997White4x4 [OP] America First
    West Covina, California
    1997 white 4x4 auto 4cylinder Singlecab, 2001 auto rwd 2.4l single cab flatbed
    Km3’s 31’s,Lift,Sliders,rear ARB air locker,on board air, armor, hi shell
    Gonna install an ARB locker in the rear, while I’m ther should I regear? I have a 97 tAcoma 2.7L 4x4 auto single cab on 31 km3’s on a 2” lift, feels good in the city, but when I’m on the hills Im really breaking out the powerband, I have 4.10 gearing atm, will regearing give me more power? Better mpg? Was looking at the 4.56 or 4.88, I habe no experience in gearing, would like some input, thx
  2. Sep 2, 2020 at 7:33 PM
    Tacoma1997White4x4
  3. Sep 2, 2020 at 7:36 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Is that the stock gearing, and stock tire size?
    If so, no, you won't get more power, or better mpgs.
    That lack of power you're feeling is the fact that you have a 4cyl...
    whatstcp likes this.
  4. Sep 2, 2020 at 7:37 PM
    Tacoma1997White4x4
    Yeah thats the stock gearing, stock tire size on the door says 28” tires, so regearing wouldnt help my hill problem
  5. Sep 2, 2020 at 7:49 PM
    jbrandt
    Justin
    Which sticker? I got curious and just looked at mine, and it has a sticker that says 235/70r15, which I know for a fact it came with 265/70r16 (it's a v6 trd 4x4).
    EDIT: I should also say that same sticker says 265/77r16 as well.
    So if they were in fact 28's, then a regear might actually help, but keep in mind you gotta do both diffs, though.
    You might try playing around on this website and plugging in your gearing and tire size and stuff and see what it calculates your RPMs should be.
    http://www.grimmjeeper.com/gears.html
    Yetimetchkangmi likes this.
  6. Sep 2, 2020 at 8:39 PM
    Pj40
    Pj40 Well-Known Member
    Washington
    Dang I'm about to regear and I will have 4.30s for sale soon that would be a nice little bump for ya
  7. Sep 2, 2020 at 9:08 PM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    You in WA state? I've been looking for a set of 4.30s to put in my rig, I like running the 31s but I've got 3.56 gears and it's a total slug off the line.
    4.30s would be perfect cause it'll make my Odometer actually read correctly :rofl:
  8. Sep 2, 2020 at 9:21 PM
    Pj40
    Washington
    Yeah man in washington near seattle/tacoma
  9. Sep 2, 2020 at 9:23 PM
    Tacoma1997White4x4
    Im good, ima just stick to 31’s its not bad I have 4.10
  10. Sep 2, 2020 at 11:02 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    6 lug autos were 4.10 - I thought they were 4.56
  11. Sep 2, 2020 at 11:26 PM
    Tacoscar-the-grouch
    Tacoscar-the-grouch Well-Known Member
    Josh
    North Idaho
    2001 Reg. Cab Tacoma
    OME kit 4.56's 235/85/16
    Pretty sure 4.56 only came stock on 2.7l auto 4x4 models. However, I do not know if ALL 2.7 autos had that ratio. Probably depends on stock tire size.
  12. Sep 2, 2020 at 11:32 PM
    Texas T
    Texas T Well-Known Member
    TX
    '14 T Force
    Maybe try turning off overdrive if you can. Won’t be the same as regear but will help with the transmission searching. I used to drive that way in my Jeep it was much better than with overdrive engaged.
  13. Sep 3, 2020 at 4:33 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    OP has 2.7 4x4 auto
  14. Sep 3, 2020 at 6:34 AM
    Tacoscar-the-grouch
    Josh
    North Idaho
    Yep and claims 4.10. Did every 2.7 auto come with 4.56? Probably not, if I had to guess.
  15. Sep 3, 2020 at 8:15 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    I thought the 4.56 was for manual? I know many 2.7L auto came with 4.30 (PreRunner?) as well
  16. Sep 3, 2020 at 8:36 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I can confirm at least one auto 4x4 2.7 came with 4.56. No manual came with 4.56 irrc.
    @BartMaster1234
  17. Sep 3, 2020 at 8:57 AM
    Tacoscar-the-grouch
    Josh
    North Idaho
    Dalandser is right auto trans has higher gears than mt hence the 4.56.
    my mt 2.7 has 3.91’s.... :( but I just sourced some stock 4.56 and the only models that came with these were 4cyl auto
    Dalandser likes this.
  18. Sep 3, 2020 at 9:08 AM
    Abeyancer
    Jimmie
    PNW
    My stock 2.7 MT only has 3.56 :(:mad: it's the worst off the line ... completely useless
    I cruise 60 on the highway at only 2100-2200 rpm at least:rofl:
    Kwikvette and Dalandser like this.
  19. Sep 3, 2020 at 9:31 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    As others mentioned, its your 4 cylinder.
    Better mpg? Its a 4 cylinder...and you've got a lot of stuff your carrying, so throw mileage concern out the window unless your truck has a legitimate issue or lack of maintenance IE plugs, fuel filter, air filter, etc.
    Gearing to something like 4.56 or higher will only result in even worse mpgs, but you'll feel the power come on sooner at lower speeds.
    Let's not forget, you'll need to match the front...may as we put a locker up front while you're in there.
    jbrandt likes this.
  20. Sep 3, 2020 at 9:32 AM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    Dude ur gearing is the same as my 3.58s? What tires u got on 31s?
    Abeyancer[QUOTED] likes this.
