Should I remove my diff drop?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ETaco23, Dec 25, 2010.
  1. Dec 25, 2010 at 1:39 PM
    ETaco23
    ETaco23 [OP] Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Just my lift a couple days ago and now I have a groaning/slight vibe coming from the front.
    Ive read some guys dont even bother with the diff drop bc it doesnt do much, and even have caused vibes.
    So not sure If its a good idea or not to remove it? :confused:
    any down sides?
  2. Dec 25, 2010 at 1:41 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    2nd gen? Yeah, I'd get it out of there, although it probably won't solve the diff groan.
  3. Dec 25, 2010 at 2:04 PM
    ETaco23
    Evan
    PNW
    Yeah, I think its a inner bearing or something. not too worried about it yet. But I will see what happens when I take out my D/D.
    there shouldnt be any negative effects right?
  4. Dec 25, 2010 at 2:14 PM
    jandrews
    Diff drops in 2nd gens have been determined to be mostly aesthetic.
  5. Dec 25, 2010 at 2:32 PM
    ETaco23
    Evan
    PNW
    ok, well maybe I will pull it out today or tomarrow. Thanks!
    my measurements show that im sitting just under a 3" lift.
  6. Dec 25, 2010 at 2:45 PM
    Duff Man
    Duff Man Well-Known Member
    Sean
    North Carolina
    09 TRD Off Road
    AEM CAI, Magnaflow exhaust, DT headers, all speakers replaced with (2) 10's and amp behind rear seats, color matched grill, grillcraft, projector headlights, 8000k HID's, DC Torque wheels, 3" Toytec lift, Bilstein 5100 shocks.
    Well a diff drop might do you some good if your CV joints ever go out. I was told by the dealer that they wont replace them under warranty unless the truck has a diff drop on it.
  7. Dec 25, 2010 at 2:47 PM
    jandrews
    That dealer is BS'ing you, unless you bought it from them lifted.
  8. Dec 25, 2010 at 2:50 PM
    Duff Man
    Sean
    North Carolina
    09 TRD Off Road
    The dealer installed my lift, maybe that's why.
  9. Dec 25, 2010 at 2:52 PM
    ETaco23
    Evan
    PNW
    well my cv's arent at a bad angle, and I just want to see if my vibe in the floor board will go away if I remove the diff drop. I will do it tomarrow and post what I find. I may just lower my lift to 2.5 until I get my tires in a couple weeks...
  10. Dec 25, 2010 at 2:56 PM
    jandrews
    Probably. When you buy lifted from the dealer, they stipulate their own warranty stuff on those components.
  11. Dec 25, 2010 at 2:59 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    Do the ribs of the cv boots have clearance right now? Let us know how they compare after removing the drop spacers...
  12. Dec 25, 2010 at 3:02 PM
    ETaco23
    Evan
    PNW
    I will. Yeah there is space inbetween the ribs on the cv boots. (barely)
  13. Dec 25, 2010 at 3:05 PM
    spamy
    spamy Truck guy
    NorCal
    07 4X4 Tacoma Sport SR5 Access Cab
    I put one in and took it out. It didnt make any difference except that when it was in the truck would make a clunk noise going from 4wd to 2wd.
  14. Dec 25, 2010 at 3:06 PM
    ETaco23
    Evan
    PNW
    so taking it out helped?
  15. Dec 25, 2010 at 3:41 PM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    Have a diff drop in my truck. (2.5" lift via coil-overs). No Issues. Very Slight decrease in cv angle compared to no diff drop. I decided to leave them in - every little bit helps.
  16. Dec 25, 2010 at 3:49 PM
    ETaco23
    Evan
    PNW
    thats what I think to, but some have taken out the diff drop and it got rid of there vibe. But when I take mine out and nothing has changed, then I will most likely leave it out. (maybe) :)
    Do you guys think I should wait till I get my tires and allignment done? or just do it now?
  17. Dec 25, 2010 at 4:03 PM
    OffroadToy
    4X4 Offroad
    The only time I've experienced the clunk noise going from 4wd back to 2wd was when shifting with a load on the drive line. I now shift back into 2wd with my foot off the gas while coasting and it disengages smooth as silk...no clunk noise what so ever (even with a diff drop.)
  18. Dec 25, 2010 at 5:01 PM
    meafordmike
    meafordmike Well-Known Member
    New Brunswick Canada
    08 Tacoma 4X4/ 4Dr 6 speed, Sport/ Towing
    Devil Horns, Wet Okoles, WeatherTechs, Radflo Coilovers, OME Dakar's, FJC Gun metal rims, 265/75/16 BFG All Terrain TA/KO, Rear Diff breather Mod,
    I just put a Diff drop in lately; I had a 2 1/2" lift and blew my front diff after 8 months lifted. I finally found a good dealer that would cover the diff under warranty, and had them install the diff drop when they replaced the diff. I am not sure if it helps, but I was told at full droop, that the drive shaft can try to pull out of the diff causing the excessive play in front drive shaft many complain about. When you install the diff drop it shortens the distance to diff on full droop of the wheel???
    I really don't know but if it made the great dealer that finally replaced my diff happy, it’s ok by me.
  19. Dec 25, 2010 at 5:13 PM
    ETaco23
    Evan
    PNW
    ok maybe I should just leave it in....ha. thanks for the info mike!
  20. Dec 25, 2010 at 9:27 PM
    beartrack
    beartrack Well-Known Member
    Nova Scotia
    SR5
    toytec coilovers, 2"aal's, LR UCA's hood struts, weather tech mats
