Should I replace JUST the fuel pump or the whole assembly, too? (P1605)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by aspxuyg, May 15, 2025.
  1. May 15, 2025 at 9:30 AM
    aspxuyg
    aspxuyg [OP] New Member
    I have error code P1605 and had a mechanic test that my fuel pressure was lower than normal. He said it was because my fuel pump was getting clogged, which I believe considering my Tacoma was shipped from an island with presumably mid fuel quality.
    My question is: do I need to buy just the DENSO fuel pump off RockAuto, or do I need to buy the whole assembly?
    Open to other perspectives as I'll likely have a mechanic do this for me and would like to keep cost at a minimum.
    Thank you TW!
    2014 Tacoma Single Cab 2.7L 4x4 (stock) 120k miles
  2. May 15, 2025 at 11:37 AM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    If the fuel pump is the issue, just replace the pump.
    Since you're in there, it would be best to install an external fuel filter. URD has a kit that replaced both.
    aspxuyg[OP] and lowmower like this.
  3. May 15, 2025 at 12:32 PM
    aappss01
    aappss01 Active Member
    Andrew
    2005 Radiant Red DCSB
    This is the route I went, URD kit with the external filter means you don't have to drop the tank to replace a filter in the future. Kit comes with everything and the instructions are well done.
    davidstacoma and aspxuyg[OP] like this.
  4. May 25, 2025 at 10:35 PM
    aspxuyg
    Thanks. That answers that!
