Should I replace my MT fill/drain gaskets?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by adamr94, Jan 16, 2015.
  1. Jan 16, 2015 at 5:41 PM
    adamr94
    adamr94 [OP] Well-Known Member
    Adam
    NC
    06 Regular Cab 4x4
    So, I got a few bottles of redline today and wanted to drain my MT(r155) and my t-case... should I replace the gaskets while I'm at it? I really don't feel like going to a Toyota dealer for a small gasket. It's got about 80k miles on it, and the trans is starting to clunk.
  2. Jan 16, 2015 at 5:50 PM
    Alloutdrs1
    Alloutdrs1 Well-Known Member
    Andrew
    Virginia Beach, VA
    12' Mag gray Doublecab 4x4
    Distinct Offroad light bar, Rigid E-series and amber duallys, Leer 100xq, Oem roof rack, Oem bed mat, Bullculla trailer plug relocate bracket, Rear diff vent mod, front mud flap chop, Color matched Grille w/Andres devil horns, Wet okoles and weathertechs
    I would, piece of mind and they are cheap. You will probably be ok if you don't but if you do get a leak at the plug then the gasket was cheaper then the Fluid you will loose while it leaked and when you have to change it.
  3. Jan 16, 2015 at 5:54 PM
    adamr94
    Adam
    NC
    06 Regular Cab 4x4
    i'll check out the shape of the fill plug gasket tomorrow and make up my mind depending what kind of shape it is in.
  4. Jan 16, 2015 at 8:25 PM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    When I did the gear oil my truck last week, I planned on replacing both plugs and gaskets, but ended up not doing it because they were still in good shape. I just cleaned em and they they were fine.
  5. Jan 16, 2015 at 8:32 PM
    adamr94
    Adam
    NC
    06 Regular Cab 4x4
    Yeah, unless they look cracked/smashed up I don't think I'll be replacing them
  6. Jan 16, 2015 at 11:59 PM
    racer1x
    racer1x Well-Known Member
    campbell ca
    05 Taco
    Too many
    I haven't changed mine and replaced the fluid about four times, just flip the gaskets around and you'll be fine.
