Should I replace my water pump?
Discussion in 'Technical Chat' started by roytown, Sep 15, 2017.
  1. Sep 15, 2017 at 9:59 AM
    roytown
    roytown [OP] Well-Known Member
    2015 4x4 DCSB TRD OR
    King 2.5s, Total Chaos UCA, OME springs, BAMF sliders, C4 rear bumper, Pelfreybilt IFS skids and front bumper, Baja pro and sport lights, teq custom headlights, Katzkin leather seats.
    2009 v6 with 108,xxx miles. I'm planning on a coolant flush very soon and I have already went and purchased new hoses and the 170 degree thermostat to replace both while I'm changing the coolant.
    I've heard many people talk about how their water pump went out close to 100k miles. Since I'm already over that marker I'm wondering if I should go ahead and replace the pump too since I'm gonna be in there??
    I have no reason to think my pump is failing due to there not being any leaks or high pitch noises. There is a kinda strange rattling noise at low (and I mean low) RPM; its during almost all operating conditions: in park, neutral, reverse or drive with a load and no load. It seems when the AC is on it's slightly louder for sure but idk what to think really.
    So the question stands, do I go ahead and replace the pump since I'm in there?
    Thanks yall!
    Aeduck likes this.
  2. Sep 15, 2017 at 1:16 PM
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Certainly not going to hurt, good preventative maintenance.
    gearcruncher likes this.
  3. Sep 15, 2017 at 8:37 PM
    roytown
    OK so any TW preferences on a manufacturer, should I go ahead and do the belt too, it looks like it's actually in good shape.
    Maybe it was changed, not on the service history though, seems either last two owners were DIYers or just went to shops that didn't report.
  4. Sep 15, 2017 at 8:41 PM
    Bishop84
    Bishop84 Well-Known Member
    I always suggest a new belt with a new water pump. It doesn't get removed as often as the older timing belt engines did.
    Also inspect the idler pulleys carefully while doing the pump, they have a higher rate of failure than the accesories. 3 Idlers, 1 tensioner bearing.
    MotoEd and theredofshaw like this.
  5. Sep 15, 2017 at 8:50 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Replace the belt. Put the "old" one in the storage compartment as a spare.
    HisDad, toyodajeff and MotoEd like this.
  6. Sep 15, 2017 at 8:53 PM
    MotoEd
    MotoEd Ed-MotoEd
    Ed
    Northern NV
    2005 Silver DCLB 4x4
    ARE Shell. Pelfreybilt front bumper. hi-clearance rear bumper w/swing out. Rigid light bar/fog lights/reverse lights. Pelfreybilt front skid. Home/hand made slidders. DR front coilovers. Camburg UCA. AllPro Expedition leaf pack w/u-bolt flip and Timbren bump stops. 285 70-17 on stock rims with Spider Trax wheel spacers. EBC slotted/drilled rotors with green pads.
    When you change the water pump, be very careful of the o-ring on the top. It is very easy to pinch or tear when installing. Also buy a new gasket.
    Not the right water pump gasket
    This is the right water pump and gasket.
    The blue circle is where the o-rings goes.
  7. Sep 15, 2017 at 8:56 PM
    MotoEd
    MotoEd Ed-MotoEd
    Ed
    Northern NV
    Belt is coming off anyways when you do the water pump. Might as well just through a new one on for peace of mind and keep the old one for an emergency spare like mentioned above. Pull the fan shroud for more access and to get the fan and fan clutch out.
    Lord Helmet likes this.
  8. Sep 16, 2017 at 12:01 PM
    roytown
    Okay, thanks y'all this is good stuff to know.
    So go for OEM water pump then?
    And for the idler pulley, what is the correct way to inspect them, is it just visual; am I looking for free play; are they going to be loose or slipping?
    MotoEd likes this.
  9. Sep 27, 2017 at 1:01 AM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    Water pumps are cheap. Well mine was less than 100 bucks. Anything you can replace while in the area is a good idea. Pulleys, pumps, seals, gaskets, hoses, belts. One swoop and you should be good to go for 100k more miles. I did all of that stuff at 170K miles/13 years. Everything looked good but, you never know. I went all OEM. Parts and labor I was at $1000 from the dealer. I sourced my parts...
  10. Sep 28, 2017 at 9:31 AM
    roytown
    Well I'll certainly go for the Aisin water pump since it seems its the part Toyota uses, just without their name on it.
    Any comments on the Gates ACK070834 Belt Drive Kit, I found it on Amazon and it seems like its a good price. Anyone have some experience with Gates and its quality?
  11. Sep 28, 2017 at 9:56 AM
    JJ04TACO
    Jim
    Dallas
    04 White DC/TRD
    On eBay, there is a guy (Aircabinman) who buys OEM parts in bulk. His prices are very good and he has a few “kits” available for Tacos. You can check him out and see if he has what you need. Lots of guys, including myself, are very happy with him.
  12. Oct 15, 2019 at 11:19 AM
    Aeduck
    Aeduck New Member
    Abe
    Toyota Tacoma SR5 v6
    Roytown.... So I’m experiencing the same issue as far as that rattle noise at low idle. The noise gets louder when the AC clutch is engaged, but is also there only not as loud When the compressor clutch disengages. I can’t figure out if the rattling is coming from the air conditioner, AC pulley, Belt tensioner, Fan clutch or water Pump. My taco is a 2005 with 148k, So it’s probably ready to replace these items anyways. So I was wondering if changing the water pump made that noise go away?
  13. Mar 9, 2021 at 8:06 AM
    chip_byrne
    chip_byrne New Member
    Check the idlers first. I just replaced all of mine including the belt tensioner idler (reverse thread). Later models you can press out the bearings and press in new ones. For my 2006 4.0L I could only rebuild the belt tensioner idler bearings. The rest had some oddball bearings. This is a great way to locate the noises. I had to use a broom handle: https://www.youtube.com/watch?v=fHtLH_m9gN4&t=1s
  14. Mar 10, 2021 at 5:55 AM
    Homiec
    Homiec Well-Known Member
    2020 TRD Sport Access Cab 4X4 MT
    There's a great YouTube channel called Toyota Maintenance. Peter (the mechanic) has a video that gives great detail on that o-ring and how easy it is to damage and gives tips on how avoid that.
    ibbones likes this.
