Should I replace the coil springs-getting new shocks
Discussion in '1st Gen. Tacomas (1995-2004)' started by trdracing5, Sep 16, 2010.
  1. May 6, 2011 at 9:39 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I paid 179 for my eibachs from Eastside custom trucks. Haven't shipped yet, they are on backorder i believe.. :(
  2. May 6, 2011 at 10:50 PM
    gofas
    gofas Well-Known Member
    Russell
    Ukiah
    4x4 Timberland Mica Access
    ImMrYo review mirror bracket.
    i miss my 5100 and ome combo.
    kyb monomax suck with Ome coil!
    ordering now ome shock and making mechanic replace em. He talked me to the idea he could match a shock up with my 881. with kyb the dash gets slapped pretty hard with large bumps. And at speed on on rough hwys i consider this pairing dangerous with all the bounce and crazy rebound.
    not sure how long the 5100's will hold up with Ome coil. The ride seemed kinda stiff at first but after awhile they loosened up with out bottom out jarring which I'M Getting now with monomax. Monomax is cool at slow speeds grandpa style and that is about it. and i'm sure they will be toast within 6 months.
  3. May 7, 2011 at 3:32 PM
    ranmec
    ranmec I'm not crazy
    Clearwater, FL. June-> Texas
    1st Gen V6 4X4
    Before June- ZUK springs in rear and 5100s up front.
    So I called both the East and West divisons of Bilstein. East said stock springs. West said either eibach or hypercoils. He said those two because that is what most of the employees run with their Bilstein shocks. I think a comprehensive comparison should be done. If one has already been done then someone please post a link as my google-Fu seems to be failing me.
  4. May 7, 2011 at 4:13 PM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    I paid 175 shipped for my eibachs from toytech :confused: Where did OP get 195 from, my shipping was 40 as well but i used the discount code and saved like $16
  5. May 7, 2011 at 4:59 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I know not were that number came from:notsure:
  6. Apr 29, 2015 at 5:56 PM
    Charlot
    Charlot Well-Known Member
    Ontario, Canada
    Tacoma TRD 2018 Upgraded
    I will probably buy next week Bilstein 5100 for my Tacoma.
    It has 95 thousand kilometers.( Around 64,000 miles)
    Do i really need new coil for my from strut shocks?
    Thanks
    Charly
  7. May 1, 2015 at 6:41 AM
    copacetic1
    copacetic1 Don't get stuck on stupid.
    Colorado
    03 SR5 4X4 Dbl Cab
    Front: Bilstien 5100 / OME 880 Rear: Bilstein 5125 / Wheeler 5-leaf
    Same same. Well worth the investment in time and money. I've seen the comment that OMEs aren't recommended with 5100s quite a few times, but it's worked fine for me so far.
  8. May 1, 2015 at 6:29 PM
    copacetic1
    Colorado
    03 SR5 4X4 Dbl Cab
    Didn't realize how old the rest of the thread was on my earlier response and that you have a 2d gen, so disregard that nugget (still true though).
    To your question Charly I wouldn't think you "need" it at your mileage, and I'd be surprised if your stock struts are totally shot at this point as well. Struts/springs are a pretty easy DIY, so I'd start with new struts for a while and then add springs if new struts alone don't give you the ride you want. If your paying someone to do the work it is probably 1 or 1.5hrs labor at a shop (my guess) if you do struts/springs at same time. Will take basically same time to do struts and then again to do springs if you have them done separately (2-3 hours labor total.)
    I did my new struts/springs at 150K miles and it was a definite improvement but the stock suspension was tired at that point.
  9. May 2, 2015 at 5:29 AM
    Charlot
    Ontario, Canada
    Thanks again for your reply.
    So i will definitely start with just the four shocks first.
    I still don t know again which brand that i will go for.
    Here in my area i can get either the same originals one at my dealer of course,and at other places they sell Napa stuff,so Monroes,or KYB which i definitely will not go for.
    The Monroes are more expensive then Bilstein 5100 stangely,but have a life time warenty,while the Bilstein 5100 only a three year time warenty.
    So i am still undecided,,lololo
    Two days ago,i had to changed my batterie,Man, evrything together..lololo
    Well at least it is in great order,except for my shocks that are due!
    All the best
    Charly
  10. Aug 26, 2015 at 9:08 AM
    Curtmagurt
    Curtmagurt Death from Above!
    Curt
    Colorado
    17 Tacoma TRD OR DC
    LEER topper, Thule roof rack, predator steps, LineX sprayed grill and bumper caps, debadged, tinted windows.
    Guess I'll throw in on this thread aswell. Been creeping around the forum for awhile. I'm getting a frame replacement on my 2002 XCab 2.7l and I need to do new shocks and springs. Definitely sold on the bilistien 5100s up front and the 5125s in the rear but I need to replace my coil spring not trying to lift the front anything over 2 inches "level" it out if anything. Thoughts? Input would be welcomed.
  11. Aug 27, 2015 at 6:48 AM
    copacetic1
    Colorado
    03 SR5 4X4 Dbl Cab
    Same - I've had no issues with 5100s and 880s, much better than old stock setup. '03 4x4 DBL.
  12. Aug 27, 2015 at 6:53 AM
    copacetic1
    Colorado
    03 SR5 4X4 Dbl Cab
    I did the 5125s and Wheelers 5-leaf for the back, along w/5100s and OME 880s in front. Maybe 1/2" to 1" lift overall from stock and sits fairly level with just a slight forward rake. I do have a shell on back so without it rake might be a bit more pronounced.
    Curtmagurt[QUOTED] likes this.
  13. Aug 27, 2015 at 7:25 AM
    Curtmagurt
    Curt
    Colorado
    17 Tacoma TRD OR DC
    Cope, what do you have your 5100's set at?
  14. Sep 7, 2015 at 9:49 AM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    All good here with Bilstein adjustables in the front and 3" Eibach coils and Camburg UCA's. Then in the back normal 5100's and a 1.5" Pro comp AAL
    Livinserene likes this.
  15. Sep 7, 2015 at 4:53 PM
    #35
    Curtmagurt
    Curt
    Colorado
    17 Tacoma TRD OR DC
    What motor do you have?
  16. Sep 8, 2015 at 9:30 AM
    #36
    Sicyota04
    Morgan
    California
    04 DC 4x4
    You talking to me? If so 3.4 V6 4x4
  17. Sep 8, 2015 at 11:14 PM
    #37
    Cruzintaco
    Cruzintaco Well-Known Member
    Sanjose
    2001 PreRunner TRD
    K&N drop in filter EGR Silencer Delete More MODS soon to come!
    I dont mean to Thread Jack here but..
    Im about to order the 5100's all around with the AAL and Eibach springs as well since everyone recommends it for a "entry level" lift.. but just curious about the brake lines.. did any of yall get new brake lines?? Cause isnt it when you lift the truck you need longer brake lines?
  18. Sep 9, 2015 at 7:19 AM
    #38
    Sicyota04
    Morgan
    California
    04 DC 4x4
    I didn't and I have the same set up you are getting. But you do need longer shocks in the rear if you are going to add an AAL
  19. Sep 9, 2015 at 7:19 AM
    #39
    Sicyota04
    Morgan
    California
    04 DC 4x4
    NVM. I see you are getting longer ones
    Cruzintaco likes this.
  20. Sep 9, 2015 at 1:16 PM
    #40
    Cruzintaco
    Sanjose
    2001 PreRunner TRD
    Cool cool. Alright Thanks for the info!
