Should I replace these coil packs?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by stevebates, Jun 22, 2020.
  1. Jun 22, 2020 at 7:54 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yep. I go to the low end of the torque range and use common sense.
    I have been torquing fasteners and sparkplugs for a really long time, even on shitty castings, and have yet to do more damage than booger up the hex on a cap screw.
    A little dab will do you, esp for a bad as they felt.
    Also, the plugs in the Taco are a long reach type with an extra long threaded section.
  2. Jun 22, 2020 at 7:58 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    No need to buy the Service Manual. Just search my posts for the shared links.
    That free version has been passed around like a . . .
  3. Jun 22, 2020 at 7:59 PM
    stevebates
    stevebates [OP] Active Member
    steve
    2017 double cab SR 4x4
    I have a base 2017 Tacoma Double Cab 4x4. Mods are as follow: FN 5 star wheels, 17x275x70 BFG's, Stage 2 Bilstein 6112 suspension kit with medium old man EMU medium leaf springs, sos concepts low profile front bumper, 9500 winch, sos concept rock sliders.
    Thanks @JasonLee and @El Latigo for the recommendation of the ohm meter. I had no idea what the coil pack did until your posted your recommendations. Many times I am disconnecting bolts and replacing parts without actually knowing what the part does or how it works. This is especially true when it comes to electrical items :) Thanks to your help I learned something today :). Much appreciated all!!!
    El Latigo likes this.
  4. Jun 22, 2020 at 8:03 PM
    stevebates
    steve
    This is the problem with recommended services. They allow you to have no clue what a part does. As long as you replace it at the recommended time is doesn’t matter :). Or at least it allows you to not have to ask waht does that item actually do :).
  5. Jun 22, 2020 at 8:06 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    They don't "allow" you to not have a clue. It's on you to learn and expand your knowledge. It's just the bare minimum, whether or not you learn why is a whole 'nother conversation.
  6. Jun 22, 2020 at 8:07 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    I cross threaded a sparkplug on my Silverado when I was like 18. I ran her up tight and never touched it again. A valuable lesson was learned that day.
    tonered[QUOTED] likes this.
  7. Jun 22, 2020 at 8:07 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    They are discolored due to the oil blowby which was allowing to rush past the loose spark plugs. Clean them up if you can/ want to and move on with life. Some carb cleaner inside the boots to ensure you wash out any oil residual and along the outside of them followed by a rag wipe down should be plenty.
    Skydvrr likes this.
  8. Jun 22, 2020 at 8:09 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I started a lug nut with a cross wrench just after my dad said not to. Got smart quick after a good laugh and a new stud.
    shakerhood and Skydvrr[QUOTED] like this.
  9. Jun 22, 2020 at 8:20 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Beating out studs is oddly satisfying
  10. Jun 22, 2020 at 8:20 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It is.
