Should I replace this winch line? ….hawse cause this?
Discussion in 'Recovery' started by helix66, Feb 7, 2025.
  1. Apr 5, 2025 at 3:21 PM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    Driveway is about 150' (so 100' of line means about a 7-8 foot rise as the truck is pulled up the hill)
    I've done it alone before, but normally I suggest have someone in the driver seat just to stab the brake if something goes wrong while doing it.
    The way I do it is walking alongside / in front of the truck as needed as it's spooling in. When the cable gets to one end of the drum, I'll steer the vehicle the opposite way so as to encourage the rope to start winding toward the other end of the drum.
    There's a method to it for sure... But after having done it dozens of times, it's become almost second nature. Coordinating everything becomes easier the more times you do it.
    helix66[QUOTED][OP] likes this.
  2. Apr 5, 2025 at 5:01 PM
    helix66
    helix66 [OP] Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    That’s similar to what I did the first time.
    I didn’t feel comfortable doing it all outside with no one behind the wheel!
  3. Apr 5, 2025 at 5:06 PM
    MARSHBUSTER
    MARSHBUSTER Well-Known Member
    Jim
    Alamogordo NM
    2005 SR5 4X4 Tacoma TRD
    Grill Gaurd/ Winch Bumper, Mile Marker 9000 LBS Winch, Custom Head Ache Rack, Custom Rear Bumper, Marathon Camo Max 4 Seat Covers
    When I put my new line on, I installed it on the drum, Attached my Tree Saver Strap and Winch Rope to my Kioti Tractor and had the Truck pointed in a straight line, I had the Truck Running and in Neutral, I walked in front of the Truck spooling the line on. It was a slight slope to the tractor.
  4. Apr 5, 2025 at 5:27 PM
    helix66
    DPRC
    2017 DclB TRDor MgM
    I did similar but not outside when pulling and to a large transmission tower footing.
    Next time I’ll find more of a slope.
    MARSHBUSTER likes this.
  5. Jun 30, 2025 at 9:29 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    This is a bit of an old thread, but somehow, I came across it.
    Your final picture in the first post clearly shows where the initial spooling was not under enough load - the force of the pull pulled the rope down into the lower layers of the spooled rope. Happens all the time, to some.
    I attach my rope end to something that is not going to move and put the parking brake on moderately hard, just enough for the tires to still turn, if I were on sand, I would probably put the brake on all the way and drag the vehicle.
    I do mine on level ground and solo with my remote control.
  6. Jul 1, 2025 at 6:02 AM
    helix66
    DPRC
    2017 DclB TRDor MgM
    Thanks for that info, appreciate it!
    To me old is a few years or more, and honestly if it’s pertinent info then that’s ideal.
    I never had a winch before and figured someone could benefit from my mistakes! When I respooled it this time I made it a point to go further.
    As usual there’s so much incorrect information online; one guy was dragging his spare tire! I knew that wasn’t enough weight but underestimated how much load it needed.
    Living in a residential area it’s tough to find something to tie off to that isn’t going to cause an issue let alone have 80 odd feet to work safely with (where someone won’t drive through the line).
    The transmission towers out in the desert are ideal for this.
  7. Jul 1, 2025 at 11:40 AM
    Toycoma2021
    The load that is ideal is the capacity of the winch/line. You’ll know it is correct when your line comes off the drum square, not round. This is assuming you are running synthetic line. The subsequent layers compact the layers underneath.
    Don’t want to hear of you bringing down any towers.
  8. Jul 1, 2025 at 11:48 AM
    helix66
    DPRC
    2017 DclB TRDor MgM
    Ha, 500kv towers are pretty large and the cages for each leg are really deep…..also only pulling horizontally at bumper level!
    I’m curious what kind of load is on it, those load indicators are probably pretty expensive.
    Toycoma2021 likes this.
  9. Jul 1, 2025 at 4:14 PM
    Toycoma2021
    Don't know I once had a conversation with a power companies engineer regarding the use of mixed-use poles for distribution. He inferred the telephone cables at the lower height did not provide much stress, only his higher up power lines were the stress producers. I'll have to take his word for it.
  10. Jul 1, 2025 at 4:54 PM
    helix66
    DPRC
    2017 DclB TRDor MgM
    I work in the industry so I’m familiar enough to know it’s fine.
    Distribution lines are a whole different animal. The wood power poles are only set about 8’ deep….seems odd to me.
