Should I road balance new tires?
Discussion in 'Wheels & Tires' started by Islandchanel, Aug 25, 2017.
  1. Aug 25, 2017 at 8:33 AM
    Islandchanel
    Islandchanel [OP] Well-Known Member
    My pro comp xtreme MT2 285/70/17 have pretty much worn out and it's a pretty shaky drive and the tires have cupped.I ordered some dick cepek funcountry tires in the same size and pick them up today. My plan is to go and have them mounted and get an alignment. One of the shops asked if I wanted them road forced balanced. I've read up ia little bit on the issue and am not too sure if I should do it.
    Americas tires wants 170 to mount 5 tires and road force balance. If I do the regular way it's 17 bucks a tire.
  2. Aug 25, 2017 at 8:41 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    I would let them do a standard mount/balance and only if there is a balance issue down the road then do the roadforce
  3. Aug 25, 2017 at 8:42 AM
    JAMES399
    JAMES399 EL CAPO
    JAMES
    Alejandria Antioquia Colombia S.A.
    White 2003 Hilux DCSB 4x4 HI-RIDER +. 2.4L I-4, 5 spd.
    275/70R16 tires, gasolina or CNG fuel, Konig shox, Energy Suspension poly bushings,
    I read up on it too. What they say sounds good, but is it worth the extra $$$ ??
  4. Aug 25, 2017 at 8:42 AM
    Toyko Joe
    Toyko Joe Here for the pictures
    I have always thought that you get a better ride with road force balancing, there is a reason it is on the market, especially with 285/70's I would think it would be very beneficial for such an oversized tire!
  5. Aug 25, 2017 at 9:13 AM
    RelentlessFab
    Eric
    Sparks, NV
    Its really only necessary on some tires, not all. I've only had 1 set of tires that needed road force balancing, and it turned out there was 1 defective tire causing the issues. All my others (6+ sets of 35" tires) have had a standard balance job and been fine
    Toyko Joe likes this.
  6. Aug 25, 2017 at 9:14 AM
    3coma
    3coma my kid says my truck is "Boss"
    rob
    19 dcsb sport cement 4x4
    Try the standard balancing first. Once you rf balance them you'll have to do it every time. I paid $100 to have it done once and they need it again. K bro 2's
  7. Aug 25, 2017 at 9:33 AM
    Islandchanel
    Thanks for all the input guys. Looks like standard balance it is
  8. Aug 25, 2017 at 8:00 PM
    JAMES399
    JAMES399 EL CAPO
    JAMES
    Good choice.
  9. Aug 25, 2017 at 8:03 PM
    Islandchanel
    Just picked it up and smooth so far !
