Should I run AMS Dominator 10-w30 racing oil in my stock Tacoma?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Cement Taco WA, Feb 6, 2023.
  1. Feb 6, 2023 at 12:29 PM
    Cement Taco WA
    Cement Taco WA [OP] New Member
    2021 Cement TRD OR Premium
  2. Feb 6, 2023 at 12:33 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I would not run that. Stick with your favorite 0w-20. If you really need to do something different, then 5w-20, but I wouldn't recommend that.
    See @Woodrow F Call 's UOA thread. There's a lot of good info in the 1st Post.
  3. Feb 6, 2023 at 12:34 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    i use 5w20....0w20 is recommended
    kahanabob likes this.
  4. Feb 6, 2023 at 12:35 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    I run Costco 5w-30 synthetic (in a 2014 - 2nd Gen).
    JJ Diablo and TWJLee like this.
  5. Feb 6, 2023 at 12:35 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Squirt, TS4x4, Delta09 and 16 others like this.
  6. Feb 6, 2023 at 12:35 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Why. Oil changes are what is important, not super special oil, especially one that is outside manufacturer's specs.
  7. Feb 6, 2023 at 12:36 PM
    eurowner
    eurowner Duke Sky
    Scoty
  8. Feb 6, 2023 at 12:36 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Thanks for visiting. Different requirements for us 3rd Gens.
  9. Feb 6, 2023 at 12:36 PM
    rnish
    Tacoma 2nd gen
    ‘It’s Monday, first oil post I’ve seen this week.
    Chew, 22Coma6MT and HondaGM like this.
  10. Feb 6, 2023 at 12:37 PM
    Horseshoez
    Horseshoez Well-Known Member
    Dale
    Maryland
    Ummm, that would be a hell no, not only hell no to the 10W-30, but also hell no to the Scamzoil.
    BC Hunter, HondaGM and Chew like this.
  11. Feb 6, 2023 at 12:41 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    Squirt, essjay, ToyoTaco25 and 4 others like this.
  12. Feb 6, 2023 at 12:49 PM
    dnlskier
    dnlskier Well-Known Member
    17' TRD SPORT MT
    I assume you used toyota care for the first ~20k miles?
    My opinion if ya want it, I am not a oil expert and do care to be one, but I do not understand why one would use different oil weights than what is stated in the manual and on the oil cap
  13. Feb 6, 2023 at 12:53 PM
    2Shoes
    2Shoes Well-Known Member
    2021 TRD Off-Road
    How much racing do you plan on doing, and do you plan on changing the oil after every race... from one stop light to the next?
    Go with the recommended 0W-20 Synthetic recommended by Toyota, choose your brand, they are mostly all the same, or very close to each other. You do not need high end racing oil, in your daily driven Tacoma. Nothing about that race oil, will extend the life of your engine.
  14. Feb 6, 2023 at 12:54 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    You are doing your first oil change at 23k miles? Or did I read it wrong
    HondaGM, CaptainBart45 and Chew like this.
  15. Feb 6, 2023 at 12:59 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    if you do you will need to keep a written log of the oil changes you do and keep the receipts for the oil and filter. if you have a warranty issue and the dealer discovers that oil you will be SOL.
    HondaGM likes this.
  16. Feb 6, 2023 at 1:13 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    SuperTech. It even has more detergent than the beloved Mobil1
    HondaGM and Tacospike like this.
  17. Feb 6, 2023 at 1:22 PM
    Tacospike
    Two Trucks
  18. Feb 6, 2023 at 1:24 PM
    Wulf
    rock raisin
    It's a clean wet
  19. Feb 6, 2023 at 1:44 PM
    Kabogski
    Kabogski Sport Rally Five
    Bote
    Los Angeles
    17' MGM - Anim na Piston.. Sport Rally Five
    Hi tuck Exhaust FalkenWildPeaks Blackout Badge
    Happy Monday!... Tacoma World :broccoli:
    HondaGM and tonered like this.
  20. Feb 6, 2023 at 3:49 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I've been running 5w-30 synthetic in my tacoma the last 2 months, or so but now having some doubts after this last -15 degree cold snap we had. I started my truck one morning, and it didn't sound happy making a loud grunt as it first started. This is the only time it's ever done this. Today it was normal. I'm thinking it's back to 0w-20 for the next change.
    BC Hunter, HondaGM and eurowner like this.
