Should I run AMS Dominator 10-w30 racing oil in my stock Tacoma?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Cement Taco WA, Feb 6, 2023.
  1. Feb 6, 2023 at 4:00 PM
    22Coma6MT
    22Coma6MT Well-Known Member
    2022 TRD Sport AC 6MT
    back in the day, i would use it just cause the name sounds cool. :bananadance:
    DOMINATOR® 10W-30 Racing Oil
    :mudding:
    i'd still consider it if it came with a sticker i could put in the back window. :burnrubber:
    seriously, no. use 0w-20.
    BC Hunter and davidstacoma like this.
  2. Feb 6, 2023 at 4:08 PM
    petethemeat
    petethemeat Well-Known Member
    Pete
    Ontario
    2023 TRD OR AC MT
    Race oils usually have excessive zddp or zinc in them for flat tappet camshafts. Zddp and zinc is hard on the catalytic converters. Probably not a good idea to use race oil in your street vehicle
  3. Feb 6, 2023 at 4:15 PM
    Firn
    Firn Well-Known Member
    White OR
    Switched to 5-30 in the wife's highlander (same 3.5), immediately dropped 4-5 mpg.
    Back on topic
    Just grabbed Costco 0-20 for the truck, looked like an ok deal at $30 for the box. Open it to realize it's TWO 5 quart jugs for $30, fricking steel!
    To really anger the masses I also run a Fram filter.
    Meets the specs and proven quality all the way around. Spending more money is the same as buying some rich guy a steak dinner, you get the same benefit.
    Fram Ultra fwiw, the orange cans are garbage
    Gen2 Man, 22Coma6MT and petethemeat like this.
  4. Feb 6, 2023 at 5:51 PM
    AM6217
    AM6217 Well-Known Member
    2021 SR-5 DCSB Silver metallic
    5w-30 Kirkland in my Taco. It loves it.
  5. Feb 6, 2023 at 8:13 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Correct :thumbsup:
    From the Amsoil spec page:
    "Heavily fortified with zinc and phosphorus additives to protect critical surfaces in extreme conditions."
    OP - Use what the manual calls for.
    BC Hunter likes this.
  6. Feb 6, 2023 at 8:30 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  7. Feb 6, 2023 at 8:52 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    The super tech gets em wet
  8. Feb 6, 2023 at 9:15 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    These threads are always hilarious. No, you don’t need 10W-30, and no, 10W-30 will absolutely not hurt anything. Folks don’t understand oil. There are very minute differences between 0W-20 and even 10W-30. Yeah, the numbers sound way far apart but it isn’t like that in the real world.
    Even 20W-50 could be used with no differences. 0W-20 is about 4-5x thicker when cold than warmed up 20W-50 is. But the numbers sound scary so folks tend to recommend against it.
    Do whatever you feel like. It’ll be fine either way.
  9. Feb 6, 2023 at 9:17 PM
    Wulf
    rock raisin
    TireFire likes this.
  10. Feb 6, 2023 at 9:31 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
  11. Feb 6, 2023 at 10:26 PM
    erok81
    erok81 Well-Known Member
    Imposter
    eurowner likes this.
  12. Feb 7, 2023 at 4:30 AM
    BillyE
    BillyE Well-Known Member
    You know this is a minivan engine, right?
    TS4x4 likes this.
  13. Feb 7, 2023 at 5:29 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    ToyoTaco25 likes this.
  14. Feb 7, 2023 at 5:40 AM
    ToyoTaco25
    ToyoTaco25 Well-Known Member
    North Carolina
    09 Super-White DCSB 6-Speed
    ProComp 4" D-Bag, I mean Drop Bracket Lift, AMP Research Powersteps, 285/70-R17’s, Magnaflow, AFE CAI, Dipped Badges
    But it's racing oil. It's gotta be better, right?
    OP never said it was the first oil change. Just the first oil change he's doing himself.
    hiPSI[QUOTED] likes this.
  15. Feb 7, 2023 at 5:42 AM
    #35
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    Delta09, Wulf[QUOTED] and BillyE like this.
  16. Feb 7, 2023 at 6:28 AM
    #36
    BillyE
    It's what engines crave
    Sharpish, Wulf and golfindia[QUOTED] like this.
  17. Feb 7, 2023 at 6:56 AM
    #37
    JJ Diablo
    JJ Diablo Well-known member.
    JJ.
    CT
    2021 Cement TRD Sport Premium
    BOSS HTX Snowplow, Bilstein 5100s, Vled reverse light kit, Vled interior lighting, FitCamX dashcam, Timbren SES
    Or he can just self report it in the owners section on Toyota.com or on the Toyota app. It will populate any service work done in between any dealer or independent work attached to his vin. I log my oil changes and rotations when I do them myself and it shows up in my vin history.
    blu92in99 and CaptainBart45 like this.
  18. Feb 7, 2023 at 7:11 AM
    #38
    dangeroso
    dangeroso Just float along and fill your lungs
    Jon
    Dallas, TX
    2018 Tacoma TRD Sport 4x4
    Classic troll post formula:
    The engineer and/or manufacturer says to do X, should I do Y instead?
    BC Hunter and ToyoTaco25 like this.
  19. Feb 7, 2023 at 7:23 AM
    #39
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    By using racing oil, @Cement Taco WA 's engine will become a racing engine - it'll take two engineers and a laptop to start every morning and idle like shit.
  20. Feb 7, 2023 at 7:40 AM
    #40
    eurowner
    eurowner Duke Sky
    Scoty
    You know there are people racing minivans on tracks, right?
    CaptainBart45 and BillyE[QUOTED] like this.
