Should I sell my stock wheels and tires mounted or separately?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PapaGrizz, May 31, 2019.
  1. May 31, 2019 at 8:19 PM
    PapaGrizz
    PapaGrizz [OP] Active Member
    2010 DCSB 4X2 On Road
    3" front 1" rear. Method NV 17s
    I plan on getting new wheels and tires and sell the stock sport alloys and duelers. Should I have them dismounted, put the pressure sensors on the new wheels and sell the old stuff separate, or keep them mounted and get new sensors? What would get me the most money?
  2. Jun 1, 2019 at 4:38 AM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    You could sell wheels and tires together and offer to buy back the wheels and sensors, kinda like a core charge for the buyer.
    Unless the buyer has a tacoma, they will not need the wheels anyways. Sensors are not cheap.
  3. Jun 1, 2019 at 5:50 AM
    Muddinfun
    Muddinfun Well-Known Member
    A lot of people have the outer bead broke loose and sensors removed and sell them with tires mounted but no valve stems. If I were in your shoes, I would have the outer bead broke loose, sensors removed, rubber valve stems installed, and aired up. Then tell the buyer they need to be balanced since the rubber valve stem weighs less than the sensor.
  4. Jun 1, 2019 at 6:30 AM
    Gopher TRD
    Gopher TRD Well-Known Member
    Justin
    New Jersey
    2014 TRD Sport
    i think separate would be better
  5. Jun 1, 2019 at 6:40 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Post 2 ads, one together one split and see what sells first.
  6. Jun 1, 2019 at 8:20 AM
    Taco One
    Taco One Well-Known Member
    Bone Stock 2011 TRD Sport
    I've done it both ways. Sets seem to move quicker, most people are looking for the set for a direct install.
    ChemDawg and Muddinfun like this.
