should I switch to synthetic atf?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kristi with a K, Mar 18, 2022.
  1. Apr 29, 2022 at 1:58 PM
    crazytacoman
    crazytacoman Well-Known Member
    Tacoman
    Taco World
    02 2.7 doublecab & 07 4.0 doublecab
    Color Wheels
    No it would just blend and keep diluting as you drain/fill more in the later future
  2. Apr 29, 2022 at 2:28 PM
    MalinoisDad
    MalinoisDad Misanthropic dog person
    Michael
    01 TRD PreRunner 5VZ
    5100s w/ 881s, JBA UCAs, J59s, other stuff and things
    Agreed. I'm sure that when I switched to synthetic there was still a good amount of the non synthetic fluid in the system. Has not been an issue and I switched years ago. A few drain and refills since then too.
  3. Apr 29, 2022 at 8:15 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Yeah for a complete switch......I bought one of those $18 12v hydraulic/diesel oil transfer pumps off amozon....
    pulled the cooler lines, dumped one side while pumping fresh right back in other line - while running....
    I ran twenty qts of max life($130)......for a 9.5 qt system with torque convert.
    That's the definition of OCD.
    GilbertOz likes this.
  4. Apr 29, 2022 at 8:20 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    At first twenty qts sounds extremely excessive, but that's more or less 4 drain and fills.. which is only 1 more than I would think necessary... I'm going to do two and see how it goes. Nothing wrong with the transmission, and I want to keep it that way.
  5. Apr 29, 2022 at 8:26 PM
    O'Silver_Taco
    MD
    Same with my differential, switched to valoline synthetic, ran it for 5 or 6 mo and then flushed again....
    I think your math is off, your tranny has about 5.5 qts in it....
    however there is another 4 in the torque converter.....which wont drain out...
    it has to be pushed out.
    MalinoisDad likes this.
  6. Apr 29, 2022 at 9:32 PM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    drain and fill = 4.5 - 5.5qts (5qt average).
    20 (quarts total) / 5 (quarts average drain and fill) = 4 (drain and fill cycles).
    I'm not a math major... but that checks out.
    I understand that a drain and fill does not replace all the fluid in the transmission system (pan, torque converter, carrier lines, and trans radiator). Which is why I was asking those that have come before me if they experienced an issue running part non-synthetic and fully-synthetic fluid.
    Anyway. I got the answer I needed. Drain, fill, and send it.
  7. Apr 29, 2022 at 9:42 PM
    O'Silver_Taco
    MD
