Should I upgrade my exhaust?
Discussion in 'Performance and Tuning' started by LoudDog, Jul 27, 2010.
  1. Jul 27, 2010 at 7:53 AM
    LoudDog
    LoudDog [OP] Active Member
    Washington
    2005 Tacoma 4x4 Double Cab
    K&N CAI, NWOR HD Rear Leaf Springs
    2005 4x4 tacoma, V6, stock except a K&N intake and rear springs.
    I frequently tow a travel trailer with it, about 4500 pounds.
    I put the K&N in mostly to improve fuel economy and it worked well adding almost 2 mpg. It may have added more power and more towing power, but it may be my imagination due to the increased sound.
    The kid in me would love to make my truck sound more bas @ss, but the responsible adult in me says that is really not a priority. If I were to do it, it would be for fuel economy and/or better power/towing power.
    I came across a guy at a campground recently that had a cherry bomb exhaust in his taco with stock intake. he said it made a difference in tow power and fuel economy, and it sounded bad @ss (even at idle), which is what got me interested in it.
    Thanks for any opinions, thoughts, or anything. I'm just starting my research so anything helps.
  2. Jul 27, 2010 at 8:12 AM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    I would stay away from an aftermarket exhaust if you plan on towing a lot. It won't give you more power or better fuel economy, it will just create drone while pulling on the freeway. If you want a little deeper/ louder sound, I would dump your stock exhaust over the rear axle. Just cut it with a reciprocating saw and it will only take a few minutes.
  3. Jul 27, 2010 at 2:48 PM
    Black Taco
    Black Taco Well-Known Member
    Rob
    WPB, FL
    TOYOTA
    No mods whatsoever!
    I agree! I have a Banks system on mine. It sounds great, but when you're towing in Drive for hours sometimes, it tends to be loud. I'm thinking about selling or trading for a TRD system.
  4. Jul 27, 2010 at 3:28 PM
    Tacoma3232
    Tacoma3232 Well-Known Member
    Brandon
    Hemet, CA
    Don't Do It I towed from San Diego to Sacramento to go camping worst sound. I tried everything to help turned radio up windows down it just resonates to much with a cherry bomb. But good luck which ever way you go.
  5. Jul 27, 2010 at 4:10 PM
    cantac09
    cantac09 Official TW Igloo Builder
    Hugh Jass
    Saskatchewan
    tundra
    stock
    i just put in a dynomax super turbo on mine. ive done about 7 hours of highway driving and no drone at all.
  6. Jul 27, 2010 at 4:46 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Your not gonna get any significant power from a cat back. If you want the saound, then fine. Check out Youtube for Tacoma Exhaust, and listen, and see what you like.
  7. Jul 28, 2010 at 6:46 AM
    LoudDog
    Washington
    thanks all. The K&N intake alone can be loud enough on hills when towing so good point on the sound. If it's not going to help power or economy I'm out!
  8. Jul 28, 2010 at 6:12 PM
    rectoyo
    rectoyo Well-Known Member
    Robert
    South Gate, Ca
    15' PreRunner SR5 Blk Badges
    Fogs on Anytime
    So what would be a good exhaust that isn't loud but yet sounds good and gives good performance? Thank u for any opinions.
