Should I upgrade suspension for a move?
Discussion in 'Suspension' started by HighQualityH2O, Aug 11, 2022.
  1. Aug 11, 2022 at 10:40 AM
    HighQualityH2O
    HighQualityH2O [OP] Member
    ‘16 TRD Sport with no mods to the existing suspension & planning to travel 2,300 mi. I would assume for worst case a loaded w/furniture 6x12 Uhaul cargo trailer and loaded truck. My concern is the ride for the trip and a potentially squatted truck.
    It’s likely the stock suspension would be fine, but if there’s some relatively low cost upgrade option I should consider I would like to hear about it, as I don’t have much experience with suspension upgrades. Thank you all in advance.
    Cheers
    Darksport likes this.
  2. Aug 11, 2022 at 11:15 AM
    Crikeymike
    Crikeymike ExitOffroad.com Vendor
    Jax Beach, Florida
    If the truck bed will be fully loaded as well as the trailer then a pair of airbags may not be a bad idea on the stock suspension. That will give you the added support you need for the extra weight. Otherwise the whole experience will be over in a few days and your stock suspension can probably handle it
  3. Aug 11, 2022 at 12:18 PM
    HighQualityH2O
    Thanks. Looks like a good solution - though in my research a comparable, slightly cheaper option are these sumo springs, which I may end up going with.
    Meatballica likes this.
  4. Aug 11, 2022 at 12:25 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I'd throw on Archive Garage Hammer Hangers and high clear cross tube if you can budget it.
    Took all the sway and "tail wags the dog" out of towing for me and reduced take off shudder almost completely.
    I used to keep it at 60 or below when towing and it felt vague and wondery the whole time (yes trailer was loaded properly with good tongue weight and heavier up front) and now the truck hardly knows the trailer is there at all unless I'm trying to accelerate.
  5. Aug 11, 2022 at 12:28 PM
    Primo 95
    Primo 95 Well-Known Member
    Primo!
    San Antonio, TX
    2012 DCSB 4X4
    265/75/16 S/T Maxx 16X8.5 Level 8 Trackers 5100 1.75 HID, LED interior, 3" N-Fab step bars
    These Helwig helper springs have been great for me. Cheap and easy install.
    https://www.tacomaworld.com/threads/best-leaf-spring-for-the-added-weight.768845/#post-27450292
    Crikeymike likes this.
  6. Aug 11, 2022 at 1:59 PM
    HighQualityH2O
  7. Aug 11, 2022 at 2:08 PM
    Bishop84
    Bishop84 Well-Known Member
  8. Aug 11, 2022 at 4:05 PM
    AccuTune Offroad
    AccuTune Offroad Well-Known Member Vendor
    El Cajon, CA
    Why not rent a Uhaul truck to load up with and tow the Tacoma behind it? Less work, less wear and tear on your personal vehicle also.
    HighQualityH2O[OP] and airmax233 like this.
  9. Aug 11, 2022 at 5:03 PM
    Darksport
    Darksport Well-Known Member
    Jake
    NE Ohio (Cleveland)
    2017 Black Tacoma TRD Sport 4x4
    33” BFG Ko2s,16” Method NV wheels, CMC, King 2.5 Remote Reservoir, Baja Kits UCAs
    Dude. I have a 17’ double cab with 2.5 king coilovers and smoothies in the rear. Stock leaf springs. 16” wheels on 33” tires. 2 years ago I loaded up a 6x12 uhaul trailer, packed to the brim, and hauled ass from Southern California to Ohio. 75-80 mph for 13 hours straight everyday. Sure she squatted, but who cares? The truck kicked ass and I barely felt the trailer. You’ll be fine. Load her up and truck em.
  10. Aug 11, 2022 at 7:08 PM
    HighQualityH2O
    I know the truck will be fine. I’m looking for an excuse to buy an upgrade and incrementally improve something I’ve noticed when pulling boats and wanted to address prior to a longer drive. But you’re absolutely right.
  11. Aug 11, 2022 at 7:19 PM
    Darksport
    Jake
    NE Ohio (Cleveland)
    Ahhh I see I see. Then yes! Absolutely you should upgrade! Good thing you bought those sumos :thumbsup:
  12. Aug 12, 2022 at 7:07 AM
    JFriday1
    JFriday1 Well-Known Member
    Jesse
    Lakewood, CO
    19 Taco TRD-Sport, 16 4Runner
    Mobile Mechanic in Denver Instagram - "Jfriday123"
    I would go Sumo Springs as well
