Should I use Rustoleum to prevent my roof from getting worse?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bloggerstomper, Jan 31, 2020.
Rustoleum or cryoleum
  1. Rustoleum
    16 vote(s)
    55.2%
  2. Don't fucking touch it and sell your tears to get money
    13 vote(s)
    44.8%
  1. Jan 31, 2020 at 11:10 AM
    bloggerstomper
    bloggerstomper [OP] Well-Known Member
    CA
    Crumpy
    I bought my dear Taco merely three weeks ago and it came with this beautiful roof and hood.
    The previous owner stated that he babied the truck (but hadn´t engaged the 4wd in about 7 months) and I sincerely doubt it, but here we are. The truck has no mechanical problems, but this eye sore is killing me.
    I currently have no money to pay for a 4-panel paint job, and I was just thinking about using some Rustoleum to paint over it and preventing it to get any worse.
    What do you guys think? Should I just leave it as is until I can afford to paint it or what can I do?
    Thank you in advance!
  2. Jan 31, 2020 at 11:31 AM
    IL Capo
    IL Capo Well-Known Member
    Sidney BC Canada
    My 0.02 cent....
    Don't leave it...it will become worse and more difficult repairs will be required moving forward. You probable already know this...I would want to make sure whatever you use that it will be compatible with anything you do when you restore it to it original glory!
    With that being said, you have picked up a automotive paint so it should be OK to use....
    Good Luck and keep us posted....
    bloggerstomper[OP] likes this.
  3. Jan 31, 2020 at 11:35 AM
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    Would a "rust converter" be a better option?
  4. Jan 31, 2020 at 11:40 AM
    IL Capo
    Sidney BC Canada
    Can I offer a suggestion....
    I know often High Schools offer autobody mechanics in school and often they will do small jobs like this at a huge cost savings. Why don't you call your local High School to see if they are interested and if so how much....
  5. Jan 31, 2020 at 11:44 AM
    IL Capo
    Sidney BC Canada
    Never a fan of products that substitute for the real thing...re. bodywork. This will be better than nothing...but will only provide minimum protection until you can have bodywork (glaze) paint and topcoat applied...
  6. Jan 31, 2020 at 11:45 AM
    TuRDLYFE
    TuRDLYFE Well-Known Member
    An over-taxed town, county, and state
    2020 AG TRD Pro 6MT
    That roof needs to be repainted. If you don't do something to seal out the moisture, that oxidation will get ugly fast. If your goal is just an interim solution, sand it and rattle can it. If you want something permanent, that will likely run you $500-$600 for a respray.
    michael roberts likes this.
  7. Jan 31, 2020 at 11:47 AM
    Itchyfeet
    Itchyfeet Well-Known Member
    If it was my truck. I rather rattle can it myself that let high schoolers dick around with it.
  8. Jan 31, 2020 at 11:47 AM
    jtaco11
    jtaco11 Well-Known Member
    that's what I was think would this stuff making it any better. vinyl wrap for time being?
    20somethingwidataco likes this.
  9. Jan 31, 2020 at 11:49 AM
    Muddycoinwash
    Muddycoinwash Well-Known Member
    2015 TRD OR access, 2000 4x4 reg
    Torspd likes this.
  10. Jan 31, 2020 at 11:49 AM
    Fulton246
    Fulton246 Well-Known Member
    NC
    2019 TRD Sport 4x4 DCLB
    Either wrap it with vinyl or spray it with 4-5 coats of plasti-dip while you save up the money to have it professional painted. Both are easily removable.
  11. Jan 31, 2020 at 11:51 AM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    Remove that surface rust then give it a few coats of rattle can paint then 8 coats of plastidip to seal the roof from future moisture until you can do a body shop repaint.
  12. Jan 31, 2020 at 11:52 AM
    Marek71
    Marek71 Well-Known Member
    2019 TRD Sport DCSB
    Like the other guys said, sand it and at least prime it to seal the moisture out.
    cruxofthebisquit likes this.
  13. Jan 31, 2020 at 11:53 AM
    bloggerstomper
    CA
    Crumpy
    I will look into it a bit more, and definitely call my local High School and see if they can replicate "Black Sand Pearl"
    Thank you!
    I think that's what it is..? It says rust reformer, so maybe it just gives the rust a stern talking to!
  14. Jan 31, 2020 at 11:57 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    You need to sand it, prime, then paint
  15. Jan 31, 2020 at 12:02 PM
    bloggerstomper
    CA
    Crumpy
    Thank you! That quote is a little bit low or socal. I got quoted 3k, 2k and 1,5k. For wrapping I did get a 600$ quote.
    I think the consensus is to sand it and cover it until I can have it professionally painted. I will definitely keep you posted!
    Thank you all!
  16. Jan 31, 2020 at 12:54 PM
    redtaco2007
    redtaco2007 Well-Known Member
    2007 Red Tacoma - TRD Off Road DCSB
    not much yet!
    DO NOT USE RUSTOLEUM ON IT! The thing about rustoleum....is that rustoleum likes rustoleum and hates everything else. If you paint it with rustoleum, you're going to have to completely strip it if you end up wanting to repaint it in the future. Rustoleum will reject other paints (bubble, fisheye, flake etc). If you're going to rattle can it, use duplicolor or go to an automotive paint store and have them mix you the correct paint code in a rattle can. Sand, Seal, Prime, Paint, Clear.
  17. Jan 31, 2020 at 12:57 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    You should also try to refinish your headlights. With lenses faded like that, you're gonna have shit output.
    theolee and 12TRDTacoma like this.
  18. Jan 31, 2020 at 12:59 PM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    ryanbitt and bloggerstomper[OP] like this.
  19. Jan 31, 2020 at 1:38 PM
    bloggerstomper
    CA
    Crumpy
    Oh I did do that. It's one of the first things I did!
  20. Jan 31, 2020 at 1:39 PM
    bloggerstomper
    CA
    Crumpy
    Good to know! Thank you!
    Now I just need to investigate on how to sand the top and how to get black sand pearl on a can!
    redtaco2007[QUOTED] likes this.
