Should I use Rustoleum to prevent my roof from getting worse?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bloggerstomper, Jan 31, 2020.
Rustoleum or cryoleum
  1. Rustoleum
    16 vote(s)
    55.2%
  2. Don't fucking touch it and sell your tears to get money
    13 vote(s)
    44.8%
  1. Jan 31, 2020 at 1:42 PM
    redtaco2007
    redtaco2007 Well-Known Member
    2007 Red Tacoma - TRD Off Road DCSB
    not much yet!
    Not sure if they all do it or not, but the Sherwin Williams stores in my area carry and can mix automotive paint into a spray can. I believe some Car Quests and Napa stores can do it as well. I would just call around a bit and ask.
  2. Jan 31, 2020 at 1:47 PM
    Muddycoinwash
    Muddycoinwash Well-Known Member
    2015 TRD OR access, 2000 4x4 reg
    Torspd likes this.
  3. Jan 31, 2020 at 10:45 PM
    bloggerstomper
    bloggerstomper [OP] Well-Known Member
    CA
    Crumpy
    I called my sherwin williams store and they said they can make the paint but they can’t put it in aerosol, so no luck in that department since I really don’t want to roller paint my truck.
    redtaco2007[QUOTED] likes this.
  4. Feb 1, 2020 at 5:36 AM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    Automotivetouchup.com sells them if you can't find it local
    will.i.was and Kolunatic like this.
  5. Feb 1, 2020 at 5:39 AM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    I got superwhite in a can years ago.
    Do a search
  6. Feb 1, 2020 at 7:29 AM
    magneticwhite88
    magneticwhite88 Well-Known Member
    Brandon
    OC, CA
    15' MGM Trd Off-Road
    If it was mine to deal with I would probably sand the rust off, and smooth out any peeling paint, hit the area that has exposed metal with a can of primer and wrap the roof with a black 3m wrap of your choice.
    Edit: Clear out of a can will fade fast especially being on the roof and will just leave you in a similar position in a few years. Wrap is easy to install, wouldn't take more than an hour to do the roof and also cheaper in the long run, even if you rewrap it every 2-3 years
  7. Feb 1, 2020 at 7:33 AM
    Ccrames2018
    Ccrames2018 Jack of some trades.
    Caden
    Nor Cal
    07 AC 4x4 V6 6MT
    -Bilstein 5100s @1.75" -16x8 SCS Ray10s with 305/70R16 General Grabber AT -CMC -URD Short Throw Shifter -Bed stiffeners -Bed mat -Aftermarket head unit -AFE Rebel exhaust -ME-SO Customs dome/map lights -Window tint with eyebrow -OEM LED 2015 tail lights -GTR Lighting headlight bulbs -Husky floor liners -Camper shell -Sumo Springs -Air intake -Aftermarket Volkswagen key fob -Aftermarket A/C knobs -Aftermarket LED license plate lights -Console organizer -JBA High Caster UCAs
    Torspd likes this.
  8. Feb 1, 2020 at 7:34 AM
    Ccrames2018
    Caden
    Nor Cal
    07 AC 4x4 V6 6MT
  9. Feb 1, 2020 at 7:37 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    get one of these Money [​IMG]
    Wyle1, DG92071 and Crosis like this.
  10. Feb 1, 2020 at 7:43 AM
    hoarder23
    Shay
    NJ
    Scratches
    Wraps don't stick to rust very well. I had my roof done to prevent this exact thing from happening and it seemed about half the install time was them just cleaning the roof really good.
  11. Feb 1, 2020 at 7:54 AM
    Greeny
    Greeny Well-Known Member
    Martin
    Rexburg, ID
    bone stock 2001 Taco 4x4 TRD
    I am not sure about the paint type, but sanding and rattle-caning is a quick, cheap and viable option for a couple years until you can get it properly fixed.
    Gen3TacomaOBX and BillsSR5 like this.
  12. Feb 1, 2020 at 10:20 AM
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    http://www.ospho.com/ This works good .But don't let it get wet before it dries . Will stain area .Also if using duplicolor touch up paint might want to clear with 2K clear in aerosol you can pick up from auto paint supply stores .Way more durable and more gloss .If going to do all that labor that extra money on that clear would be worth it .
    Torspd likes this.
  13. Feb 1, 2020 at 12:45 PM
    trdtacojef
    trdtacojef Well-Known Member
    Jeremy
    Alabama
    2007 DCSB TRD Sport
    OME Dakar Medium duty rear leafs Total Choas UCAs Elka 2.5” Extended Travel CO and Rear Shocks w/ RR and DC FN FX Pro 17” Silver Rims Nitto Ridge Grapplers 285/70R17
    Man you can do it. I painted my rear bumper with no prior experience. Do you have somewhere to store the truck out of the weather ? You can at least get it primed and the rust off and sealed.
  14. Feb 1, 2020 at 2:06 PM
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    it doesn't sound like you are worried about being perfect, so i would just sand, clean, mask off the roof and spray away with duplicolor and not worry about blending the masking lines.
  15. Feb 1, 2020 at 9:25 PM
    #35
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    Automotive touch up sells a great oem color matched paint in a can. Use spraymax 2k clear and it will look brand new. If you're going to go through the trouble of prep work, might as well use high quality materials for a perfect finish. It'll probably run you around $80 for the aforementioned primer, base coat and clear.
    YouTube is also your friend. Great technique can make average paint look good and great paint look fantastic.
  16. Feb 1, 2020 at 9:29 PM
    #36
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Roller and rustoleaum black really isn't a bad option but you will have to colorsand the hell out of it then polish.
  17. Feb 2, 2020 at 2:26 AM
    #37
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    I’ve found SEM rattlecan paints to be some of the easiest to spray. With only a bit of care you’ll have it looking fine.
    But do something — that roof panel needs to be protected!
    cruxofthebisquit likes this.
  18. Feb 2, 2020 at 6:20 AM
    #38
    ctcz28
    ctcz28 Well-Known Member
    Texas
    2015 Blue Ribbon Metalic DCSB Prerunner
    I'd take the truck to a couple of paint shops and tell them you'll be looking for a shop to paint it in the near future and ask what they recommend you do in the interim to stop more rust forming, but not create more problems for a future paint job. With hope of getting the future paint job they will hopefully be willing to give you some professional tips.
    In my opinion, at a bare minimum you need to neutralize the existing rust or it will get worse. I probably would not sand it off now as you'll just expose more bare metal to the elements. Get a solution from an auto paint store to do the neutralization, they should have a good product (perhaps the auto paint shops can make a recommendation). After you neutralize the rust spray it with a primer/sealer (again, ask the auto body shop/auto paint store if you need a self etching primer or what would be best). The primer/sealer will not be a permanent fix so ask about something to cover that as well until you can get it painted. I'd use what the professionals suggest as the best interim solution to stop the problem getting worse.
    bloggerstomper[OP] and dtaco10 like this.
  19. Feb 2, 2020 at 8:06 AM
    #39
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Have it Rinolined in the same color,or have it painted by a shop.Nothing says CHEAP like painting your truck with a rattlecan.
  20. Feb 2, 2020 at 8:09 AM
    #40
    surfandturf
    surfandturf Well-Known Member
    CT
    2014 TRD DCLB
    Light sand, prime, clear coat then plasti dip it flat black. That's what I would do. Or spend the $ on a respray
