Should I wait until after I install my add-a-leafs to do my alignment?
Discussion in 'Wheels & Tires' started by BenWA, Nov 17, 2010.
  1. Nov 17, 2010 at 10:33 PM
    BenWA
    BenWA [OP] Well-Known Member
    Boston burbs
    '06 Double Cab TRD Off Road 4X4
    I installed front 5100's set to 2.5", and have new tires waiting at the tire shop to be mounted, with an alignment included as part of the tire installation. Is it important that I do my rear AAL install before having the alignment done? They are 2" AAL's.
    In other words, if I have the alignment done first (before installing the AAL's), then lift the rear 2" later, would lifting the rear 2" mess with the front alignment in any way?
  2. Nov 17, 2010 at 10:38 PM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    no need for alignment for the rear.
  3. Nov 17, 2010 at 10:40 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    would lifting or lowering the rear significantly affect the front caster?
  4. Nov 17, 2010 at 10:43 PM
    BenWA
    Boston burbs
    Yes, this is my question/concern ^^^
  5. Nov 17, 2010 at 11:06 PM
    BrettBretterson
    BrettBretterson Wild Ginger
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    Yes. With the rear lower than the front, the caster will be more positive. With the rear higher, the front caster will be less positive. Too little positive caster is what causes wandering at high speeds.
    OP, once you install your AAL, your caster will be less positive than it is now and will need realignment. If you're only going to align it once and can afford to wait, you will want your alignment post-AAL.
  6. Nov 18, 2010 at 2:30 AM
    BenWA
    Boston burbs
    Okay, thanks for the reply Brett. That was what I suspected.
