Should rear leaf shackles move freely?
Discussion in '1st Gen. Tacomas (1995-2004)' started by sk8louisville, Aug 8, 2022.
  1. Aug 8, 2022 at 4:36 AM
    sk8louisville
    sk8louisville [OP] Active Member
    louisville
    So, I'm almost finished with my suspension refresh, I got aftermarket shackles with my new leaf springs, shocks, etc. Specs call for 89ftlbs on the bolts. I ran them down pretty tight with an impact gun.
    Wondering if they should move freely or just run 'em how it is? The Internet is all over the place. Some say loose to move with the leafs, other's say not so much.
    In my head I can see it both ways. I'm wondering if they'll naturally just move on their own just with the weight of the truck bed etc?
  2. Aug 8, 2022 at 4:39 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Use a torque wrench. Torque the bolts as specified by Toyota with the weight of the truck on the springs. Yes the springs will move around to a degree.
    SR-71A likes this.
  3. Aug 8, 2022 at 4:53 AM
    Clearwater Bill
    Billy
    Largo Florida
    Did you use a torque stick?
    I'm guessing not.
    So back them off, use a torque wrench and set them right.
    BTW. All your suspension mounting points that are in bushings should be done with a torque wrench, and that suspension piece should be in full compression at the time (not full droop). Otherwise you'll be twisting out bushings way before you want to.
  4. Aug 8, 2022 at 6:56 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Torque to spec only once the vehicle is on its own weight, not on a jack or jackstands.
  5. Aug 8, 2022 at 9:26 AM
    sk8louisville
    louisville
    Thanks guys. Gonna reinstall the bed, drive around the block and let things settle, then check the rear bolts with a torque wrench.
