Shovel and axe mount?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Chriswhite421, Apr 10, 2024.
  1. Apr 10, 2024 at 11:03 PM
    Chriswhite421
    Chriswhite421 [OP] Well-Known Member
    2004 Tacoma
    I want to mount my shovel and axe to the inside of my bedsides. Curious if anyone has done this, I don’t have the factory liner, and my bed is line x’d. Should I just buy some quick fists and run some self tappers thru?
  2. Apr 11, 2024 at 1:25 PM
    PathFinder1776
    PathFinder1776 Well-Known Member
    Colorado Front Range
    2003 DCSB TRD OR 4WD
    TRD S/C & TRD Boost Gauge Snugtop Topper Chevy 63 Swap, Gen 1 Raptor Shocks Boxed rear frame Aluminum F/R bumpers, sliders AEM 340 Fuel Pump Odyssey 27F Battery Shifted LCAs UCAs Icon 2.5 Ext. Coilovers
    I would think that self tappers would eventually vibrate their way out of the sheet metal of the bed. Lots of guys put a 2nd/3rd gen style rail in, this distributes the weight better. Most seem to use unistrut or rail sections for a 2nd/3rd gen. There are also some aftermarket tie down rails that work well. I'm thinking about using a single side 80/20 profile on mine. Best to bolt through to the back side, even better to use a backing plate to bolt through. A full length rail will distribute the forces better and allow for more mounting options.
