Show gauges
Discussion in '4th Gen. Tacomas (2024+)' started by Andygears, Oct 31, 2024.
  1. Oct 31, 2024 at 1:59 PM
    Andygears
    Andygears [OP] Member
    Andy
    New 2024 Tacoma
    On pages 102 and 103 of the Tacoma manual, there shows a voltmeter, an oil pressure gauge, an engine temp. gauge and transmission temp. gauge (if equipped) and a boost gauge.
    Where the hell are they? I’ve been through menus, and screens and cannot reveal these? Probably burned an hour or more of gas sitting at idle in the driveway.
    Thanks to anyone who can help. 2024 Tacoma SR5 2 wheel drive.
    Andygears
  2. Oct 31, 2024 at 2:07 PM
    soupy1234
    soupy1234 Well-Known Member
    2024 Celestial Silver TRD OR LB
    See page 635.
    Here's a video but it's for the 12"-gauge cluster and you probably have the 7".
    https://www.youtube.com/watch?v=P-uw5GzhOOw
  3. Oct 31, 2024 at 2:10 PM
    cvillechopper
    cvillechopper Jackass to the masses
    Charlottesville, VA
    '24 DCSB TRD Off-Rd, Premium Package
    Console lock-box, Studly Driver
    Also, if you want ro avoid burning gas while figuring out the tech stuff, just hit the start button twice with you foot OFF of the brake. Turn your headlights to off to save the battery.
    Stevie17 likes this.
  4. Oct 31, 2024 at 2:26 PM
    BaconPanda14
    BaconPanda14 Member
    Does the SR5 come with the secret storage on the drivers side that gives you discounts on accessories?
  5. Oct 31, 2024 at 2:44 PM
    Andygears
    Andy
    New 2024 Tacoma
    Thanks, soupy1234, but yes I have the 7 inch display and one large gauge centered. It is a very late constructed 2024, September ‘24, so maybe the manual is incorrect, but it does have pages 114-115 which show the same gauges for the 12 inch display. Still can’t find oil pressure or voltmeter.
    Thanks
    Andygears
  6. Nov 2, 2024 at 4:51 AM
    Andygears
    Andy
    New 2024 Tacoma
    Found them! Curious how that menu is listed as a left handed horizontal listing while all the other listings are vertical choices which roll thru top to bottom and top again. Those gauges appear in one direction only and dead end to the left. Not intuitive.
    Andygears
  7. Nov 2, 2024 at 8:25 AM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    On the sr5 you will eventually experience your current gauge display will change many times & getting it back to where you had it will be second nature to you....
    In the short period I had mine, my turbo gauge kept changing to something-else about a dozen times or so...
    Somehow I must bump the steering wheel controls, cant see how but thats the only explanation.
