Show me how you carry your toys
Discussion in '3rd Gen. Tacomas (2016-2023)' started by themadtaco, Dec 17, 2015.
  1. Mar 7, 2016 at 6:31 AM
    #141
    Toynado
    Toynado Well-Known Member
    SF Bay Area
    2016 TRD OR DCSB Quicksand
    EXTERIOR: Toytec Boss 2.0 Dakar CS047R Leaf Springs Tailpipe chopped Pelfreybilt Front full hoop front bumper w/ Pelfrey fairlead Pelfreybilt Rear standard bumper Pelfreybilt Aluminum IFS, Mid, Rear (exhaust reroute) & Gas tank skids Pelfreybilt Fuseplate w/ 12 circuit fuse block All-Pro Apex Sliders ProComp 7036 17"x9" -6 offset BFG 275/70R/17 KO2's Warn VR10000-S winch Baja Designs S8 light bar & Squadron sports amber pods in front bumper Baja Designs S2 flush pods in rear bumper Baja Designs Squadron Pro amber pods on Caliraised ditch light brackets @rrentrop reflective black tailgate inserts RSI LED's for regular & high beams Prinsu Cabrac Custom Tradesman Truck Top by Access Manufacturing w/ Powertank 8"propane tank mount & Yakima tracks on the roof INTERIOR: Warrior Products door sill protectors Husky Weather Beater floor mats front & rear Coverking arid multicam seat covers in the front Midland 75-822 CB w/ 4' Firestick antenna on C4 Fabrication tailgate mount Consolevault Hondo Garage iPhone mount
    Nice tandem!
  2. Mar 7, 2016 at 8:20 AM
    #142
    whopper
    whopper 2016 MGM 4x4 double cab
    wayne
    north carolina
    2016 tacoma double cab 4x4 MGM
    On going
  3. Mar 9, 2016 at 5:56 PM
    #143
    dman100
    dman100 Well-Known Member
    Central Coast, California
    2016 TRD OR DCSB
    Hi - update on 29-er mountain bike fit in a DCSB (wheel off, fork mount to floor, bike facing backwards) from my recent post. I looked at a used Gen 2 with a Tradesman aluminum shell (really nice shell) and I test fitted both bikes. A tight squeeze compared to my FlipPac and 6' T100 bed, but totally workable. I then found a used Gen 3 with a sleek ARE shell, I think a Z series which has a fairly sloping rear lift gate that really eats into the space. I didn't test both bikes but my bike fit, very tight but feasible, and probably room for the second slightly smaller bike (mine is a Large, my wife's is a Medium). I also tried it facing forwards with the fork up against the front bedwall, and that was better, though its hard to crawl in and attach the fork to the thru-axle mount. Dropper seat post definitely had to be down all the way. Anyway, the conclusion is that a DCSB is suitablele for hauling bikes, though not much room for other stuff ... in the bed.
    MiBlancoTaco likes this.
  4. Mar 10, 2016 at 4:05 AM
    #144
    Para8291
    Para8291 Well-Known Member
    Rob
    San Antonio
    2016 Tacoma TRD Sport
    Bilstein 5100s all around, Toyo All Terrain AT II 285/70/17, Custom Car Grill, front windows tinted at 35%, door still protectors, bed Matt, tail gate lettering, center console organizer and detailed with Adam's Polishes products
    I had to buy it from the dealer. I believe it was less then $50
  5. Mar 10, 2016 at 6:54 AM
    #145
    Tacoma16bvilletx
    Tacoma16bvilletx Active Member
    Isaac
    Deep South Texas "Brownsville"
    2016 Tacoma Texas Edition V6 4WD
    Leveling kit, 285/70/17 Hankook Dynapro Mt.
    damn a bobcat!! how was the towing power?? i know those prety damn heavy
  6. Mar 10, 2016 at 7:35 AM
    #146
    andyr562
    andyr562 Well-Known Member
    Andy
    Long Beach Ca
    About 4800 pounds, pulled great locally, didn't go on any steep hills or anything like that
  7. Mar 10, 2016 at 7:42 AM
    #147
    Tacoma16bvilletx
    Isaac
    badass, what about expressway???
  8. Mar 10, 2016 at 7:45 AM
    #148
    andyr562
    Andy
    Long Beach Ca
    I was on the freeway for about 7 miles and it did great as well, used the ect to merge onto the freeway
  9. Mar 10, 2016 at 7:48 AM
    #149
    Tacoma16bvilletx
    Isaac
    :bowdown:
    andyr562[QUOTED] likes this.
  10. Mar 14, 2016 at 6:17 AM
    #150
    JWhitmer
    JWhitmer Active Member
    State College, PA
    2016 Tacoma DCSB TRD OR 4X4 BBP
    Pretty easy and basic DIY bike mount for a Thru Axle. Credit below for the instructable. I added the PVC in the sleeve to protect the axle so the galvanized pipe should be 3/4" and the PVC 1/2". Tight fit on the PVC but it works perfectly. No wobble with the rear tire nicely held by the tailgate. Just getting through until the Head rail gets here and I can mount up a Rocky Mount.
    http://www.instructables.com/id/Mountain-Bike-Fork-Truck-Mount/
    [​IMG][​IMG]
  11. Mar 14, 2016 at 7:52 AM
    #151
    Danielnc06
    Danielnc06 Well-Known Member
    NC
    2016 TRD DCLB
    Added the front bed rail and Yakima locking fork mounts with t-blocks.
    JWhitmer likes this.
  12. Mar 15, 2016 at 4:23 PM
    #152
    dman100
    2016 TRD OR DCSB
    Regarding the DIY thru-axle mount, another non-DIY option is Kuat mounts. I have a pair, they work well and are MUCH cheaper than Thule's or Yakima's adapters. Also, for those with a DCSB and cab-high shell, or considering them, here's my final update on fitting two 29-ers inside. I ended up with one fork mount on a board, like JWhitmer showed earlier, at the front of the bed, for my bike. It was just too big to fit backwards and clear the rear window, hinges and gas struts on my shell, as it could do in my previous 6' long, and wider T100 bed. So I'll just crawl in and attach it up front. I added a second, reversed setup for my wife's slightly smaller bike behind the driver's side. That way, if she's alone she can just wheel her bike in backwards and attach it to the Kuat mount right at the tailgate. And with the two bikes facing opposite directions, there's much more room and access for other stuff. In conclusion, I'm glad we went for the short bed instead of long bed - at least for bike hauling - with the goal of having a shorter truck for city and offroad use, not to mention slightly lighter. My bike location even allows room if I ever get a 140mm fork ...
  13. Mar 21, 2016 at 10:23 PM
    #153
    DjSamthrax
    DjSamthrax Master Certified Toyota Product Specialist
    Sam
    Minnesnowta
    2018 Tacoma TRD-Off Road Double Cab Long Bed Cement
    18x9 Roost w/285/65/18 BFGoodrich K02, Icon Stage 4, Rough Country 30" Light Bar, Tekonsha P3 Trailer brake controller, Viper Smart Start w/GPS, Custom Screen Off Image, DDM Tuning 55w HID Low, LED everything else, Clearshield Platinum Package, Auto Armor, Tint, Every OE Toyota cargo management accessory ;-)
  14. Mar 21, 2016 at 10:37 PM
    #154
    thinkingburrito
    thinkingburrito Well-Known Member
    Newport Beach, CA
    2016 TRD Sport 4x4. Icon\Total Chaos\Baja Designs
    The some of the setups I have so far.
    ccallen, Beta300rr, Bduda44 and 4 others like this.
  15. Mar 23, 2016 at 8:32 PM
    #155
    Stykol
    Stykol Member
    Sam
    Eugene, Oregon
    2016 TRD OR DCSB
    Did you mount the base board to the bed? I just bought a DCSB and have given this a try with the Kuat dirtbag, but I'm having issues with the board flipping over and moving around, even though it feels tight.
  16. Mar 23, 2016 at 8:41 PM
    #156
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    Some shitter bolts can do the trick... I like it!
  17. Mar 23, 2016 at 9:36 PM
    #157
    thors.hammer
    thors.hammer Well-Known Member
    What brand is the hitch motorcycle carrier?
  18. Mar 23, 2016 at 9:46 PM
    #158
    dman100
    2016 TRD OR DCSB
    For the board at the front of the bed, I didn't attach it and it seems stable. For the board at the back, for the rearward facing bike, I put the board under my bedmat and then made an angle bracket to extend over the mat and locate the Kuat mount a few inches away from the tailgate to allow closing the rear window of the camper shell. With the bedmat over the board it's very secure. I'm taking off on a trip soon but can post more detailed pics next week. Oh, one more thing: for the forward facing bike I am tying the rear wheel snugly to a tie down loop on the bed side track, with a Velcro strap. That secures it so that the bike can't move and upset the fork mount and board.
  19. Mar 24, 2016 at 6:30 AM
    #159
    dman100
    2016 TRD OR DCSB
    One more tip - although I laid the board on the bedmat, I did shim the front board under the bedmat with a piece of 1/4" X 2" stock under the mat, to compensate for the bed ribs not running all the way to the front. That helped the board sit flat and not rock. I used a piece of plywood I ripped to about 7" wide.
  20. Mar 24, 2016 at 8:15 AM
    #160
    thinkingburrito
    Newport Beach, CA
    Its a brand made by Cycle Gear. It was pretty cheap, I think $100 - $150 on sale. it works pretty good
