Show me ur 2nd gens w/2in lift on 265/75/16
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Airforce131, Sep 4, 2013.
  1. Oct 1, 2013 at 11:36 AM
    #61
    stanhope
    stanhope Well-Known Member
    Chattanooga, TN
    12 DCSB O/R
    Toytec Alum 2.5”, OEM roof rack, OEM skid plate, Leer shell
    Billy's up front, AAL in rear. Revo 2s on stock rims. I got 2" up front and almost 1 1/2" in rear with the shell on. image.jpg
  2. Jan 7, 2014 at 12:17 PM
    #62
    littlemrnofear
    littlemrnofear Member
    kathy
    norcal
    white 07 prerunner 5100's leer supersport
    bilstein 5100 set at 2.5 inches, AAL in rear, leer supersport shell
    Ostrichsak, are those fj Team trail wheels? you said OEM wheels, I just wanted to clarify? I want those FJ wheels with 265s. I have billys on the front set at 2.5 and a short AAL in the back. That looks great on your truck. What sz and model tires are those and how much lift? looks awewome!
  3. Jan 8, 2014 at 4:53 PM
    #63
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    Yes, OEM FJ Team Trail wheels with 265/65r16 Duratracs. My 5100's are set to the 2nd setting (1.75"?) and then TSB rear. I would like to go a little taller some day maybe but I'm really happy with my setup. BTW, if you want those wheels read this thread before you buy anyway. When you see the price you'll probably pull the trigger immediately if not sooner like I did.
  4. Jan 8, 2014 at 5:21 PM
    #64
    Taco trd
    Taco trd Member
    Shannon
    Winnipeg
    13 Tacoma Double Cab 4x4 TRD Sport
  5. Jan 8, 2014 at 5:23 PM
    #65
    Taco trd
    Taco trd Member
    Shannon
    Winnipeg
  6. Nov 22, 2015 at 6:11 PM
    #66
    @Bnavillus
    @Bnavillus Well-Known Member
    brendan
    2015 4 door TRD sport Long bed
    weather techs, Leer 100xq, tints
    hows the daily driving ride quality of this set up compaired to ur stock?
  7. Dec 12, 2015 at 12:49 AM
    #67
    Djboi808
    Djboi808 Well-Known Member
    2015 white Tacoma 4x4 Trd Off Road
    Here's mine 2.5 lift in the front , 2.25 in the rear billys all 4 corners with eibach springs set at sec setting in the fronts , rear has toytec 3 leaf progressive add a leaf with overload . Just got the bfg at ko2 265/70/16 on fj wheels. The tires was supposed to be 265/75/16 but the tire shop made a mistake and installed the stock size long story short I got a free alignment , free mount and balance and paid total of 487 bucks so I'm happy with that I'll just rock this till they wear out.
  8. Dec 12, 2015 at 3:45 AM
    #68
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    blackmountain10-24-15 001.jpg blackmountain10-24-15 010.jpg redriver907 001.jpg
    Currently I have what measures up to be a 2-1/4" front lift, via a spacer, and 1" rear via a block. At one point, I had a 3" lift (measured 2-5/8) via a Toytech coilover. They were used when I got them and they both blew out soon after. Personally, I like the RIDE and HANDLING better now than with the coilovers. Much smoother ride and off road performance is unchanged. Wheels are stock TRD Off Road. Tires are Goodyear Duratrac 265/75/r16, load range C. BTW, run them at 40psi minimum if you don't want the vibration (feels like they're out of balance) you'll hear people complaning about. They ride smooth as a babies butt with sufficient pressure. If I decide later to change tire sizes, it'll just be a DIFFERENT size Duratrac. I've owned 17 different 4wds over the past 42 years. With that, just about every description of A/T or M/T tire I can think of. The Duratracs are my new favorites.
    But, as they say, all good things must come to an end. Stock TRD Billies are getting tired. (80,000+ miles) Very soon will be installing 5100's with 884's (no spacer, just trim packer) on the front and 5100's on the rear. I'll be having a set of rear leafs made at a suspension shop I do bsiness with. Essentially just building a stouter version of what Toyota started with. I'm keeping the 1" block just to irritate those who think "cheap lift kits" won't work. It's all about creating a balance....Shocks, coils/leafs, wheels and tires. There is no point in going overkill on $2500 shocks whan you run a lighter wheel/tire combo. That's sorta like pissing in the ocean. One of the biggest, if not THE biggest issue with matching shocks with coils is staying within the limitations of the shocks REBOUND dampening. Stiffer springs or more preload will help (somewhat) with compression and compression dampening, but that higher spring rate or additional preload HURTS the shocks ability to dampen rebound. That can give your truck's suspension a "jackhammer" effect....When you hit a bump and it compresses the spring/shock, there will be a faster, more violent rebound. Some shocks are adjustable, but in just about every case I know of, the adjustment effects compression primarily. So....It's best to avoid overly stiff springs and/or severe preload of a spring if/when you can. Long story short....No more spring than you need. And I prefer a longer coil for lift as opposed to preloading to get the same lift.
    My truck get's it's fair share of off roading. It gets a lot of interstate highway driving too. Does well at both. Nothing exceptional, but more than satisfactory.
    I've recently worked on a Landcruiser that had over $4000 in suspension mods and it rode aweful. I'd match my "$80 lift kit" against it for quality of ride any day.
  9. Dec 12, 2015 at 5:14 AM
    #69
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    Do you have a preferred spacer and a link?
  10. Dec 12, 2015 at 3:28 PM
    #70
    Bluegrass Taco
    Bill
    Mt Washington Ky
    The one I used was an $80 Ebay no name spacer.....
    #70
  11. Dec 12, 2015 at 4:05 PM
    #71
    gatty
    gatty saltyyota
    andrew
    Texas
    15 4Dr 4x4 black
    Fog light mod, volant cold air intake, uws tool box, 3 inch ready lift, 285 60 r 18 nitto terragrapplers 18x9 Ballistic jester wheels, grille craft front grill insert, strobes n more floodlight, cool white led bed lights, blue seas fuse box, soon SOS Concepts front bumper
  12. Dec 12, 2015 at 4:32 PM
    #72
    Mjordan
    Mjordan Well-Known Member
    Michael
    Denver, Colorado
    2015 Super White DCSB 4WD TRD Offroad
    TRD Beadlock Wheels, Bilstein 5100s all around, BFG K02 265/75R16, 20% tint, WeatherTech Floormats, LED Interior Lights, Tailgate lock, Salex Organizers, Shorty 5" Antenna, LED license plate lights
  13. Jan 27, 2016 at 5:53 AM
    #73
    Jakef98
    Jakef98 Mud Bogger
    Jake
    Winnsboro, South Carolina
    2013 Black Tacoma 4x4
    those bad boys are awesome in the snow i plow through everything and they always pull through
  14. Jan 27, 2016 at 6:01 AM
    #74
    NMW 4x4
    NMW 4x4 Wheels With Moose.
    Walt
    T8 R11 WELS, Maine
    '14 DCLB SR5 4x4
    5100's @ 1.75", Wheeler's 3-leaf Progressive AAL.
    D6BA3E8F-B7AB-46C9-8E53-AD9179BC0D2A_zps_121a45438a5997ab9a6a257469e5df395dadece8.jpg
    B739B101-635D-424B-8191-B359A59D48BA_zps_009e3d077c49bf9b40c296d55007833c0765e339.jpg
    C785DBDB-7B36-4FB6-9D41-0EE72550C3AD_zps_a62994b21d8039c89636e63c48d382520349aa56.jpg
    TRDPro4x4 likes this.
  15. Jan 27, 2016 at 4:31 PM
    #75
    MidnightRebel07
    MidnightRebel07 If you're gonna be a bear, Be a Grizzly !
    Jerry
    Northside of Pittsburgh, Pa.
    2013 Tacoma BAJA T/X dcsb
    Ironman Foam Cell Pro suspension, Anso black headlight housings, l.e.d. headlights, black taillights, Demello steel front bumper with highlight 7" l.e.d. round lights, Diode Dynamics Amber SS3 Pro lights, Hooke Road steel rear bumper with Nighlight reverse lights, Hooke Road roof rack, Ultima Aluminum toolbox, Weathertech floor mats, EGR in channel ventshades, Snorkel, K&N air filter and cabin air filter, 265/75/16 Cooper ST Maxx, Firestone ride rite airbags, Bentrodders bed reinforcements, too many other things to remember.
    Anyone switch to a load range C tire from the factory load range D? I'm looking at getting a 265/75/16 DuraTrac in a C rating because they don't offer them in D's, most tires are E's with limited C's in this size.
    What were the differences in handling, towing/ hauling, etc...???
    Bluegrass Taco likes this.
  16. Jan 27, 2016 at 6:57 PM
    #76
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Factory tires are P rated
  17. Jan 27, 2016 at 7:28 PM
    #77
    MidnightRebel07
    Jerry
    The BAJA's come with load range D BFG TA KO's.
  18. Jan 27, 2016 at 7:30 PM
    #78
    OZ-T
    Peter North
    British Columbia
    Huh , interesting , this I did not know
  19. Jan 27, 2016 at 7:44 PM
    #79
    MidnightRebel07
    Jerry
    What load rating tires do you guys have on your 265/75's ?
  20. Jan 27, 2016 at 7:49 PM
    #80
    OZ-T
    Peter North
    British Columbia
    P rated like I said
    Andrew47c likes this.
