Show me your aftermarket valve stem caps
Discussion in 'Wheels & Tires' started by Oreo Cat, Oct 9, 2017.
  1. Oct 9, 2017 at 9:20 PM
    Oreo Cat
    Oreo Cat [OP] Worst Member
    Coeur d’Alene, Idaho
    It's the small things that make the biggest difference, thinking about getting these
    Show me yours! Not the plain plastic black ones don't count, we've all seen those before
    riprater likes this.
  2. Oct 10, 2017 at 1:47 PM
    bludweiaer
    bludweiaer Well-Known Member
    pa
    2017 Pro DBL Cab,,2020 F3L Spyder...Polaris 800..
    avs rain guards,,,tyger auto tubesteps... stealth SR8's.265/70/17,ridge grapplers..shiftsense pro...
    those are valve stem caps.. not valve stems... and if you use alot of the aftermarket valve stem caps,, they can anodize and be hard to unscrew, because they are mostly make of aluminum..
  3. Oct 10, 2017 at 2:11 PM
    Oreo Cat
    Title fixed, 2 of my valve stems are messed up from off-roading, would it be worse to leave them exposed or potentially have the caps get stuck?
