Show me your knob.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Nw_nomad, Sep 11, 2019.
  1. Apr 19, 2023 at 12:37 PM
    #681
    InfernoTacoCO
    InfernoTacoCO Well-Known Member
    Hannah
    Denver, CO
    2017 Inferno Orange Toyota Tacoma TRD Offroad
    Westcott Design 0° Sliders, Falken Wildpeak AT3’s, OTT Tune, Interior/Exterior LED lighting, Raptor Lights, WeBoost 4G-M Signal Boost Amp, Trail Grid Pro Front/Rear Anytime Camera, OEM Tailgate Actuator & Wiring, 20% Ceramic Tint.
    I got the TRD Pro shift knob for mine but I’m having trouble getting the collar to lock onto the knob base. It has the same base as the stock knob. Is there a how to? Or a video? All I see on youtube are automatic shifter knob videos.
    edit: never mind! I finally got it.
  2. Apr 19, 2023 at 8:35 PM
    #682
    808stateofmind
    808stateofmind Well-Known Member
    Kona
    '22 Lunar Rock TRD OR 4x4 DCSB 6MT
    Eibach pro truck 2.0/2R lift kit 1.5" AAL OME/ARB UCA BFG KO2, 285/70-17 SCS Blaze 10, 17-8.5, -10 offset ECGS bushing needle bearing replacement Clutch accumulator disk delete Poor mans TRD intake, K&N 57 series intake tube, K&N high flow filter, TRD flow accelerator
    Put an fj trd knob in my lunar rock dcsb. Used one of the chrome boot collar covers and20230411_145153.jpg two rubber grommets to keep the boot up in place and stop it from rattling
  3. Jul 1, 2023 at 11:01 AM
    #683
    Spadi_5
    Spadi_5 Well-Known Member
    Wisconsin
    2019 DCSB TRD OR
  4. Jul 2, 2023 at 2:59 PM
    #684
    7mMike
    7mMike Well-Known Member
    Nh/vt
  5. Jan 11, 2024 at 12:08 PM
    #685
    Vinchez78
    Vinchez78 Well-Known Member
    Alvin
    Black Taco TRD sport
    So my OCD is getting to me because my shift diagram is not centered, I don't want to use a jam nut, but I'm considering locktite blue, however I don't want to damage the threads or have to forcefully untwist it if I need to take off my shifter knob, is there anything kind of like locktite not as hard to remove or should I just go with LT blue?
  6. Jan 11, 2024 at 1:05 PM
    #686
    808stateofmind
    Kona
    Dont think you'll get around the issue without a jam nut
  7. Jan 11, 2024 at 1:25 PM
    #687
    shaggy135
    shaggy135 Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    You could try some small plastic shims on the top of the threaded section. That's how the knobs from @7r41lbr34k3r came. Maybe he can shed some additional light?
    fatboyfirebass likes this.
  8. Jan 11, 2024 at 1:40 PM
    #688
    MacGyver2394
    MacGyver2394 Active Member
    Connor
    2020 MGM DCSB TRD OR
    Definitely in the Tinkerer Ranger Series Club. Love mine. Feels unique and can change over time with being able to change out the patches. IMG_5035.jpgIMG_5034.jpg
  9. Jan 11, 2024 at 3:39 PM
    #689
    Rednecktacoma22
    Rednecktacoma22 Well-Known Member
    Logan, UT
    22 TRD OR 6MT
    Installed yesterday
  10. Jan 11, 2024 at 3:57 PM
    #690
    TacoTrigger16
    TacoTrigger16 Well-Known Member
    Central Valley California
    2022 TRD OR 4x4 DCSB Super White
    Armor: RCI Plated 20 Degree Sliders RCI Full Skid Plates Steel RCI Fuel Skid RCI Rear Diff Skid SNS Designs ABS Guards Front Bumper: C4 Overlander with Full Hoops C4 Front Bumper Frame Support Brackets Bed: Total Chaos Bed Stiffeners Cali Raised Bed Light Kit Toyota Bed Mat Alu-Cab Contour Canopy Blue Sea 5025ST Fuse Block Blue Sea 4363 Switch Panel Victory 4x4 Front Bed Molle Panel Mountain Hatch Tailgate Table 3.0 Fire Extinguisher Shovel Axe Fatmax Extreme Lighting and Electrical: PowerTrays Essentially BantamX Spod Bantam X w/ Touchscreen Baja Designs 30” S8 Light Bar Driving Combo Baja Design Squadron Sport Diving Combo Baja Design Squadron SAE Fleece All Lights On Engine: K&N Drop In Air Filter Mishimoto Intake Hose Toyota Air Accelerator Toyota TRD Oil Cap Toyota TRD Radiator Cap ECGS Bushing SDHQ Terminal Kit Fumoto Engine Oil Drain Valve AC Drain Mod Exterior: De-Badged Black Tacoma Tailgate Letters Heritage Badge In Black/Grey/White AVS Rain Guards AVS Aeroskin Hood Protector Lftd Customs Taco Sauce Gas Cap Holder Tacoma License Plate Frame Black Sylvania License Plate LED Lights R4T Bumper Caps Meso Customs Headlight Trim Plate Meso Customs V5 Ultimate Turn Signals SDHQ Ditch Light Mount Rago Fab Antenna Mount Interior: Desert Does It Seat Jackers & MMP K&N In Cabin Air Filter Matte Black Steering Wheel Emblem Meso Customs Red Push To Start Meso Customs Vent Rings SW Meso Customs Climate Control Rings SW Meso Customs Interior Chrome Delete SW Meso Custom Minimalist Key Fob V2 SW Meso Customs Extended Fuse Cover AJT Designs Door Handle Covers Z Precisions Cup Holder Midland MXT275VP4 Yodaverse Interior LED Kit Yodaverse Center Console Organizer TacoMods Radio Knobs w/ Backlighting Headrest Paracord Grab Handles SOG Rapid Rescue Dongar Technology Mirror Adapter Garmin Dash Cam Mini 2 Baby Toyoda Square Center Console Insert WeatherTech FloorLiner HP Grey Expedition Essentials 3TPAM Ram Mount Accessories GoGettaGrip Shifter Knob Magnetic Mic Patches Suspension Lift: DuroBumps Front Bump Stops Icon Billet UCA’s Delta Joint All-Pro Sway Bar End Links Marlin Crawler HD LCA Frame Brace Bison Offroad Cam Stop Kit Total Chaos Cam Tab Gussets Total Chaos Cab Mount Chop Plates Total Chaos Spindle Gussets W/ Sway Bar Accutune Fox 2.5 DSC Front Shocks Accutune Fox Tundra 2.5 DSC Rear Shocks Accutune 2.5” Bump Stop & U Bolt Flip Deavers U402 Stage 1 Yota Mafia Rear Extended Brake Lines 24” ARB Carrier Bearing Drop Kit FK29 Archive Garage Hammer Hangers Archive Garage 3.6 Shackles Archive Garage High Clearance Cross Tube Wheels and Tires: SCS F5 16x8 -25 Offset 3.5 BS Gunmetal Mickey Thompson Baja Boss M/T 285/75R16 Gorilla M12x1.5 Lug Nuts ET Liftd Customs Leashed Valve Stem Caps Winch: Warn VR Evo 10-S Warn Wireless Hub Factor 55 1” Fairlead Factor 55 Rope Guard Factor 55 UltraHook Gray Tandem Offroad Control Box Mount LambTek Innovation Switch Bracket Kit Blue Sea Switch Recovery: Factory 55 HitchLink 2.0 Warn Epic Shackle x2 ARB Tree Saver 16’ Special Thanks to: Sibi Built for the lift installation. Tiny Rig Co for the Alu-Cab and installation. Accutune for the Fox Shocks with Adventure Tune. Baja Designs for lighting. C4 Fab for the front bumper. RCI for sliders and skids.
    Go Getta Grip
    mtip, Malvolio, vicali and 3 others like this.
  11. Feb 13, 2024 at 7:38 PM
    #691
    s0dhi
    s0dhi Well-Known Member
    Kev
    GTA, ON, Canada
    2022 TRD Pro 6M - Electric Lime
  12. Feb 13, 2024 at 7:41 PM
    #692
    Out2gtcha
    Out2gtcha Well-Known Member
    Brian
    Omaha, NE
    2020 Quicksand Off Road DCLB 4x4
    Spooky
  13. Feb 25, 2024 at 9:28 PM
    #693
    e6rock
    e6rock New Member
    2017 TRD Sport 4x4 6MT MGM
    Added a gr86 knob. I removed the inner plastic sleeve from a trd pro knob with a rip I bought on ebay, trimmed it to size, and jb welded it to the inside of the gr86 knob in order to attach it to the shift boot ring.
  14. Feb 25, 2024 at 10:50 PM
    #694
    Southwest Tacoma
    Southwest Tacoma Well-Known Member
    Southwest
    2020 Super White SR DCSB
  15. Feb 25, 2024 at 11:02 PM
    #695
    PooTaco
    PooTaco Well-Known Member
    Utah
    2020 Tacoma Access SX 4x4
  16. Feb 26, 2024 at 12:57 AM
    #696
    STEELeR43
    STEELeR43 Well-Known Member
    Hawaii
    2023 Tacoma TRD 4x4 6MT
    3" Icon Lift, SPC UCA, B&M Sport Shifter, OTT Tune
    This is my shifter knob. Part of B&M Sport Shifter Kit
    SilverBulletII and Speedbird like this.
  17. Feb 27, 2024 at 3:44 AM
    #697
    BernsTaco
    BernsTaco Well-Known Member
    21 Cement Tacoma TRD OR 6MT
    Do you have a link to where you got this knob or a part number? I like this exact look.
  18. Feb 27, 2024 at 7:37 AM
    #698
    e6rock
    e6rock New Member
    Part number SU003-08873. I think I have a picture of the inner sleeve from the trd pro knob. on my computer, ill try and post it when I get home.
    BernsTaco[QUOTED] likes this.
  19. Apr 11, 2024 at 5:02 PM
    #699
    s0n
    s0n Member
    Son
    Bay Area, CA
    2022 Tacoma TRD OR
    Battlecraft Tear Drop Shift knob
    devinzz1, geobontaco, mtip and 4 others like this.
  20. Apr 24, 2024 at 12:07 PM
    #700
    Magiriano
    Magiriano Underdog by Doekter TUNED
    Alex
    Calgary, Alberta
    2022 4Runner TRD PRO 2023 Tacoma TRD PRO MT
    Westcott Front lift with Eibach Pro Coils, Icon AAL rear, 17" Rims on 285/70/17 Toyo Open Country AT3 Load Range E, Full PPF Clear Wrap, Diff breater relocation, Greenlane Offroad Stump Bumper, Greenlane Offroad full engine skidplate, Greenlane Offroad Transmission Skidplate, RA Motorsports Gas Tank Skidplate, DEFA Trickle Charger with Cab Heater, CBI DOM 120 Rock Sliders, Greenland Offroad cab height Box Rack, Sherpa Roof Rack with Baja Designs S8 Lightbar, Tailgate lock, Underdog Tune by Doekter TUNED
    SilverBulletII and Spadi_5 like this.
