Show me your shell!
Discussion in 'Tonneau Covers, Caps and Shells' started by Oscar 319, Aug 28, 2008.
  1. Dec 18, 2015 at 8:37 PM
    #3801
    stbear
    stbear Well-Known Member
    SE PA
    2015 DCSB TRD Sport MGM
    I had to take mine back once to get the latches fixed. Coming from an ARE with rod latches, I'm not a fan either. Now if they could only get the leak fixed. 3 times and still water inside
  2. Dec 18, 2015 at 8:44 PM
    #3802
    scocar
    scocar hypotenoper
    Which model? Is it framed, or frameless? I've recently tuned up the used 100XQ I bought. Mine wasn't popping open, but it wasn't latching shut without me putting pressure at each side. If they aren't solving it, there's probably some simple stuff you can do your self.
    I think one of the issues is the the cap doors are straight, and the Tacoma tailgate has a very subtle curve to it. I solved that by installing a Relentless tailgate reinforcement plate. :cool:
    14489 likes this.
  3. Dec 18, 2015 at 8:56 PM
    #3803
    SC2SC
    SC2SC Likes Pineapple on Pizza
    Jonathan
    South of Charlotte
    2014 DCSB MGM TRD OR 4X4
    Icon Custom Build Custom Exhaust • SOS Sliders• RokBlokz
    Snugtop looks great! Like the set up on your rig. Wish we could get Snugtop out here.
  4. Dec 18, 2015 at 9:13 PM
    #3804
    altataco
    altataco Active Member
    erich
    calgary canada
    '13longbed4door4wd
    3'' front suspension lift 1.5"body lift in rear + pro comp add a leaf 18 black iron rims 28 65 r 18 nito tera rubber
  5. Dec 19, 2015 at 10:55 PM
    #3805
    scocar
    scocar hypotenoper
    One more thing worth noting on those cables. When I tuned mine trying to just tighten everything up, I took the slack out of the cables, thinking that would help. Wrong. It actually prevented the latches from fully closing on the strikes. If your cables are tight, that could be a culprit, so put a little slack into them. That may do it. The hex set screw in this pic is where you can adjust it.
    I also added a couple of small pieces of polyvinyl tubing cut to fit onto my latch strikes. My strikes were a little worn on this used unit, and I wanted to take out play between the latches and strikes. These work great, and now it shuts with a satisfying thud. I think it would improve a new unit, too. You need to place the zip ties precisely so they don't interfere, and place the seam of of the polyvinyl tubing toward the outboard side.
    fredgoodsell likes this.
  6. Dec 20, 2015 at 11:49 AM
    #3806
    Geoff
    Geoff Well-Known Member
    Adirondack Mountains
    2023 TRD OR
    I got a set of Ikea Dioder LED lights, which run on 12v DC. I rewired them, and put them in my shell. There are 4 strips, 2 in the front and 2 in the back. I ran two power cables and put each set on it's own switch. Everything is mounted with velcro, so they can be moved around pretty easily.
    I also threw together a bed divider with some plywood and lumber that I had lying around. I added a couple of coat hooks so that bags can be hung on it as well.
    ready6delta, Livinserene and scocar like this.
  7. Dec 20, 2015 at 12:21 PM
    #3807
    Wolftaco0503
    Wolftaco0503 Well-Known Member
    Adam
    Chicago
    2013 Super White LONG BED TRD SPORT 4x4
    Maglite mod Bottle Opener in bed Weathertech Mats Front & Back
    Anyone have a Snugtop Outback? That's what I'm planning on when I get my truck. Obviously I didn't read all 193 pages.
  8. Dec 20, 2015 at 2:07 PM
    #3808
    23Skidoo
    23Skidoo A thirsty fish
    Paul
    https://youtu.be/xvFZjo5PgG0
    meme
  9. Dec 20, 2015 at 2:38 PM
    #3809
    Wolftaco0503
    Adam
    Chicago
  10. Dec 23, 2015 at 8:59 PM
    #3810
    Holloman
    Holloman Well-Known Member
    chris
    nor cal Cloverdale
    2016 dcsbTRD OR
    Things and stuff
    i like that rack is it one piece from front to back?
    ragincajun35[QUOTED] likes this.
  11. Dec 23, 2015 at 9:05 PM
    #3811
    KaptainH
    KaptainH Well-Known Member
    Kris
    Gainesville, GA
    Black 2013 DCLB Sport
    Looks like a Front Runner
    ragincajun35 likes this.
  12. Dec 23, 2015 at 9:05 PM
    #3812
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Two pieces; one on the cab one on the shell
  13. Dec 23, 2015 at 9:44 PM
    #3813
    Holloman
    chris
    nor cal Cloverdale
    2016 dcsbTRD OR
    Things and stuff
    [​IMG]I've been wanting a rack like that for my rig
    Livinserene and Wild Crow like this.
  14. Dec 23, 2015 at 10:06 PM
    #3814
    Holloman
    chris
    nor cal Cloverdale
    2016 dcsbTRD OR
    Things and stuff
    i actually like the old aluminum shells they are light weight and look cool/funky
  15. Dec 24, 2015 at 6:57 AM
    #3815
    camiliosalomanda
    camiliosalomanda Well-Known Member
    McKinney, Texas
    Super White
    Grill Craft Hella 500 Bed Aux Wet Okole Wet Okole Arm Rests Weather Tech Magnaflow OS Ram Night Breakers Rocky Mounts Custom IPOD Dock Pioneer AVH P4100 Relentless Sliders AnBCustomFab Bed Rack 3 Inch Icon Lift with leaf pack
    What fender flares are those? Been thinking of doing that for mine.
  16. Dec 24, 2015 at 7:11 AM
    #3816
    Holloman
    chris
    nor cal Cloverdale
    2016 dcsbTRD OR
    Things and stuff
    The black along the bottom and around the flares is Line-x the flares themselves are Pacer brand flexy flares
  17. Dec 24, 2015 at 9:25 AM
    #3817
    camiliosalomanda
    McKinney, Texas
    Super White
    Thanks, pacer flex flares is what I want.
  18. Dec 24, 2015 at 9:28 AM
    #3818
    Holloman
    chris
    nor cal Cloverdale
    2016 dcsbTRD OR
    Things and stuff
    yea it was the only thing i could find that worked after i cut 1.5 inches out of all the fenders. they seem to work good so far.
  19. Dec 24, 2015 at 9:30 AM
    #3819
    camiliosalomanda
    McKinney, Texas
    Super White
    Are they the universal ones? I am looking for some that are almost flat coming off the existing flare. Hate to say it but something like what jeep guys do.
  20. Dec 24, 2015 at 9:32 AM
    #3820
    Holloman
    chris
    nor cal Cloverdale
    2016 dcsbTRD OR
    Things and stuff
    Mine are the no lip style so they bolt to the side of your fender but if you get the style with the lip it should bolt right to the bottom of your existing fender flares. I had to get the no lip style because I pulled my fender flares off
