Show me your shell!
Discussion in 'Tonneau Covers, Caps and Shells' started by Oscar 319, Aug 28, 2008.
  1. Jan 10, 2017 at 7:29 AM
    #5281
    The_Black_Pearl
    The_Black_Pearl IG: the_black_pearl_tacoma
    Colorado Springs, CO
    2013 All Black Tacoma Double Cab Long Bed
    What cap model is this?
  2. Jan 10, 2017 at 4:46 PM
    #5282
    2Toyotas
    2Toyotas Well-Known Member
    Ken
    Western NC
    '13 Taco SR5 AC
    @G.T.
    I took your advice, did some searching and got Trim Lok.
    https://smile.amazon.com/gp/product/B00NL4BG0A
    3/4 wide 9/16 high and a hundred ft will keep me in spares.
    If, not buying McMaster Carr suggestion seemed rude, my apologies. I do appreciate the info on multiple rows.
    Thank you,
    Ken in NC
    G.T. likes this.
  3. Jan 10, 2017 at 9:24 PM
    #5283
    fyrfighter
    fyrfighter Active Member
    Devin
    Nebraska
    15 off road
    Is the ARE CX model compareable to the Leer 100R I really can't make up my mind which model/brand that I want
  4. Jan 11, 2017 at 4:56 AM
    #5284
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    My shell dealer called yesterday and said my 100XQ came in. Hopefully I can make it over there this afternoon or tomorrow to get it. :fingerscrossed:
    DC-USAF likes this.
  5. Jan 12, 2017 at 4:05 PM
    #5285
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Its a little dirty but the shell is on. Looks pretty good. 100XQ, removable front window and Thule tracks.
    bigth26, philwill, Jeremy M. and 9 others like this.
  6. Jan 12, 2017 at 4:45 PM
    #5286
    2Toyotas
    Ken
    Western NC
    '13 Taco SR5 AC
    I bought (2) 2x8 x 57" and (2) 3/4" plywood 57 1/4" x 67 1/2" for the sleeper. (Cut to length at Lowes, as it saved me time at home.)
    I have to notch the 2x8 to fit in the 7" slots and cut a slight angle on each of the plywood pieces to fit on the tailgate end of the bed.
    One step closer to a sleeper unit in the cap that is still 'on its way' ARE MX Walk-In.
    I have pondered the thought of adding a spacer to raise the 2x8s a bit higher so I can have more storage height. That would require the same spacer on the sides, too.
    May not do it, because that will reduce head room. I will decide when I have the cap.
    Waterproof carpeting, too.
    Ken in NC
    loginfailed likes this.
  7. Jan 12, 2017 at 5:05 PM
    #5287
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Cool post some pics of your handy work. :thumbsup:
    JPinFL likes this.
  8. Jan 12, 2017 at 5:12 PM
    #5288
    2Toyotas
    Ken
    Western NC
    '13 Taco SR5 AC
    What? You like pictures?
    You do?
    Edit:
    Ha, we'll see, then.
    Ken in NC
    JPinFL and loginfailed[QUOTED] like this.
  9. Jan 12, 2017 at 7:04 PM
    #5289
    mrbedgood
    mrbedgood Isaiah 6:8
    North Carolina
    '11 MGM DCSB TRD Off Road 4x4
    Total Chaos +2" Long Travel Kit; King/TC 2.5 LT C/O w/ 16"x600; TC/CVJ Extended Axles; TC Spindle Gussets; King 2.5 RR shocks; All-Pro Expendition Leaf Pack; Pelfreybilt Sliders; Anti-Dark LED Hood Light mod; LED map and dome light mod; Bed lights; TRD Cold Air Intake; KB Voodoo Tailgate cap system; HomerTaco Thin Lip "Raptor" grille; sPod SE System w/ LCD Touchscreen; Baja Design OnX6 40"; Baja Design S2; Rigid Industries LED Rock Lights; Front Runner Slimline II Roof Rack; A.R.E. Z Series Camper Shell Projector BHLM Headlights (with custom wiring); Method Racing NVs 17"x 8.5; and Nitto Terra Grappers 265/60/17
    Just getting started with this little chime.
  10. Jan 12, 2017 at 7:09 PM
    #5290
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    Here's mine with the shell
  11. Jan 13, 2017 at 6:23 AM
    #5291
    ready6delta
    ready6delta REGULAR GUY
    JACOB
    Still in PNW but moved to Boise.
    Black pinstriped 2014 DCSB 4x4
    IT NEVER ENDS..........
    Looks good man!
  12. Jan 14, 2017 at 9:37 AM
    #5292
    2Toyotas
    Ken
    Western NC
    '13 Taco SR5 AC
    First:
    When Lowe's cuts the wood, bring a tape measure and check before you leave.
    I added the spacer below the cross members and got a bit more than 9 5/8" for storage. The plywood is 3/4".
    I plan to shape the sides better and cut the sides to place a full 48" wide piece instead of the split in the middle. LATER, not yet.
    Ken in NC
    @loginfailed
    ready6delta, dirtnsmores and DC-USAF like this.
  13. Jan 14, 2017 at 2:42 PM
    #5293
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Considering you're going with the taller shell, I like how you spaced it up for more storage. :thumbsup:
    ready6delta and 2Toyotas[QUOTED] like this.
  14. Jan 15, 2017 at 6:39 AM
    #5294
    Sudsman44
    Sudsman44 Well-Known Member
    Abington PA
    2012 Tacoma Access 4x4
    Ranch cap w/ rhinorack bars, 5100s, Deaver AAL, 2” front receiver, Matt Gecko bedlights, yadda yadda…
    Doing a one-piece platform can make it difficult to remove, if you plan to.
  15. Jan 15, 2017 at 6:58 AM
    #5295
    2Toyotas
    Ken
    Western NC
    '13 Taco SR5 AC
    It's not a one piece. In the one shown I have 2 halves of plywood. 4 ft wide plywood won't cover the whole bed.
    The cross members pull out easily.
    My improvement will be one 4 ft wide sheet with the side pieces (left and right) to fill. Should be easy to pull the 4 ft piece less the 'lids' for storage access.
    Sudsman44[QUOTED] likes this.
  16. Jan 15, 2017 at 8:59 PM
    #5296
    rprieto05
    rprieto05 Well-Known Member
    Ralph
    2016 Super White Tacoma TRD 4X4 Off Road
    Here is my shell and rack.
  17. Jan 16, 2017 at 8:18 AM
    #5297
    rprieto05
    Ralph
    Where is this
  18. Jan 17, 2017 at 10:10 AM
    #5298
    hungrycoyotes
    hungrycoyotes Active Member
    Tyler
    Vancouver, WA
    2010 Taco 4x4 Dblcb
    Flowmaster 40 muffler, LED Bed Lights, AFE Drop In Filter, BFG KO2 265/70/17
    Here is my new ARE CX shell. (Truck has layer of dirt, hence the slight color difference)
    ready6delta, TRlPPlN and DC-USAF like this.
  19. Jan 17, 2017 at 12:12 PM
    #5299
    timestwenty
    timestwenty Member
    Peter
    Newport Beach, CA
    2006 Silver Access Cab 2.7
    5100 Bilsteins, Snug top shell
    This is in Big Sur near Andrew Molera state park. About 3 miles up old coast road.
  20. Jan 18, 2017 at 9:48 AM
    #5300
    2Toyotas
    Ken
    Western NC
    '13 Taco SR5 AC
    Update, the middle piece will be about 40" wide to allow (edit to 1 x 12) 2 x 12 supports fore/aft and a 40" wide, hinged lid, box at the forward end.
    It will be 3 weeks friday since I ordered the A.R.E. cap. I haven't heard yet. Getting excited though.
    @areaccessories
    I am poised to buy the Total Chaos bed stiffeners, too. But, TC is not sure they will fit with this cap/door, so I will get the cap first, then see.
    Ken in NC
