Show me your shell!
Discussion in 'Tonneau Covers, Caps and Shells' started by Oscar 319, Aug 28, 2008.
  1. Sep 19, 2011 at 6:34 PM
    #741
    cms
    cms Active Member
    Sweet ride!!
  2. Sep 30, 2011 at 5:27 PM
    #742
    aar0n897
    aar0n897 Member
    Aaron
    Cape Cod, MA
    09 reg cab 5 speed on floor
  3. Sep 30, 2011 at 5:44 PM
    #743
    LJD
    LJD Well-Known Member
    Here is my set up, I decided to get the upgrade package cause I could afford it at the time. It has the rifle box (I don't hunt) I just keep sleeping bags in there for when I go camping and sleeping in the box. I just installed a 1500 watt inverter a while back for boiling water, etc. Feel free to ask any questions in your interested in the set up, it's simple but it works for a weekend of surfing or snowboarding. It's tight but once your asleep your out so it doesn't matter.
  4. Sep 30, 2011 at 9:14 PM
    #744
    thegoldrun
    thegoldrun Member
    Boulder, Colorado
    no badges, 265/70R17 BFG
    What kind of platform is that? Did you custom build it? More pics please.
  5. Sep 30, 2011 at 10:34 PM
    #745
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Nice set up , where on Van Isle are you ?
  6. Sep 30, 2011 at 11:29 PM
    #746
    MrGrimm
    MrGrimm Mall Crawler
    Dean
    Wisconsin
    2006 Toyota Tacoma 4WD w/TRD Sport Package
    See build page
    Does anybody have pics of a commercial shell or contractor cap on a newer tacoma?
  7. Sep 30, 2011 at 11:35 PM
    #747
    OZ-T
    Peter North
    British Columbia
    Dean ,
    my shell is the Leer 100 RCC , which is the commercial version of the 100R . The roof is reinforced and the DeWalt contractor rack system can take 400 lbs
  8. Oct 1, 2011 at 12:01 AM
    #748
    hoosiertaco
    hoosiertaco Well-Known Member
    ^Oh wow OZ, that DeWalt system is sweet!
  9. Oct 1, 2011 at 12:04 AM
    #749
    OZ-T
    Peter North
    British Columbia
    Thanks , I like it . Loaded it up pretty good quite a few times now , the longer boards in the picture above are 16'
  10. Oct 1, 2011 at 12:11 AM
    #750
    hoosiertaco
    If I would have know of that option, I would of got it. I don't work construction per se, but functionality wise to be able to handle 400lbs, that's what a rack should be able to do in my opinion.
  11. Oct 1, 2011 at 12:11 AM
    #751
    OZ-T
    Peter North
    British Columbia
    I agree
  12. Oct 1, 2011 at 3:30 AM
    #752
    TRDsport253
    TRDsport253 Well-Known Member
    Edgewood, Wa
    2021 TRD sport 4x4
    TRD Wheels TRD Skid plate
    Nice truck and nice cap. How do you like the 100XL. I'm still stuck deciding between 100XR.
  13. Oct 1, 2011 at 7:09 AM
    #753
    MrGrimm
    Dean
    Wisconsin
    See build page
    400 pounds is great. It's no the rack I am worried about, its the cap itself. I am looking to put a roof top tent up there and would like the topper to be able to handle the weight without worrying if it will crack.
  14. Oct 1, 2011 at 9:22 AM
    #754
    OZ-T
    Peter North
    British Columbia
    The roof is reinforced , so if your mounting feet for your roof tent were roughly in the same spot as the rack mounts I have , the rating would still apply
  15. Oct 1, 2011 at 5:53 PM
    #755
    LJD
    The bed frame is made out of aluminum and was custom made, I inserted two pieces of pre sanded plywood and painted the wood afterwards. I also had a custom made mattress made that folds up when not in use. I wanted a bed that had removable legs to save space with storage. It's pretty solid. The measurements of the platform are Length 69'' x width 53'' and the thickness is 1.1/4''. The legs are 12'' x 4 legs and 2.5'' x 2 for the smaller legs that rest on the wheel wells for a total of six legs. To keep things simple i just use a couple bungee cords to keep it in place because I take it out to save on gas when not in use and wanted it to be a simple way of keeping the bed secure without it sliding around. Originally I almost went 69 x 54 but changed my mind at the last minute and went 69 x 53 which is tight enough, I probably could have had it a couple inches longer in length but wanted to leave a couple inches to reach under the bed while lying on it, etc. I numbered all the legs to each spot on the platform after drilling so they would fit with ease afterwards and i also used washers on the top of the platform to avoid the bolts splitting the wood. I put small little circular sticky pads on the bottom of the legs to avoid wear and tear on the plastic bed of the truck. I have the toyota rubber matt in there too to avoid gear sliding around while the truck is in motion and took a couple inches off each corner of the matt so it can be removed to clean while the bed is still in there. I have 13'' for storage under the bed and the bed with mattress takes up about 5'' and leaves about 20'' for sleeping. It's comfortable for me, I'm 180 lbs and about 5'9''. Probably a little tight for a bigger guy.
    I'll post some more photos and hopefully that helps. I'd put up a build thread but have no idea how to ha ha.
    I'm pretty happy with the leer 100 xl canopy the height of the glass flows nice with the height of the glass on the doors of the truck unlike some other models that have really narrow glass heights. I went with some upgrades, it has two lights inside, the rifle box in the ceiling, keyless entry, the sports thule roof rack, a plastic hangar bracket which was useless, a 1500 watt inverter charged by two extra batteries, the secondary is in the engine compartment and the third deep cycle battery is in the back corner of the box, a lockable tail gate handle, I replaced the cheap plastic handle inside the canopy with a small piece of thin climbing rope. And that's about it for now. Anyway I'll throw up some more photo's and let me know if you have any more questions. Man, I didn't mean to write that much....
    The_Black_Pearl and RudyD15 like this.
  16. Oct 1, 2011 at 6:02 PM
    #756
    LJD
    I love the 100 xl, I think it looks more proportional with the truck instead of the 100 xr, all the leers are attractive looking and it all comes down to personal preference and budget I guess. I'd go with 100 xl though. How the hell do you make photos bigger on here?
  17. Oct 1, 2011 at 6:05 PM
    #757
    LJD
    I currently live in Cumberland which is in the Comox valley, BC. How about yourself? Nice set up too.
  18. Oct 1, 2011 at 6:16 PM
    #758
    NFK
    NFK Death Technician
    Nick
    Canada, BC, Vancouver Island, Victoria
    BLACK THUNDER
    Tiers 33/11.5 tiers Mickey Thompson,Wheels Mickey T Side Bitters 17” 3” Rev Tech Lift,Added Leaf Spring,Black Projector Headlights CCFL Halo’s / HID’S Blacked out tail light Mod,Grill craft Grill Top and Bottom Hella 500 Behind Gril,FJ40 1986 Toyota Land Cruiser Emblem Front Grill K&N Air Filter,TRD Emblem Lower Grill Bottom Right,Toyota Bug & Stone Deflector Toyota Skid Plate Rhino Lined,WeatherTech Window Visors AVID Step Up Sliders,Bushwhacker Pocket Style Fender Flares Key Hole Plugs Colour Matching,Tacoma Bed MattRear,Tailgate Anti-Theft Mod ( Key Hose Clamp) Leer 100XQ Canopy,Semi De-BadgedPainted Remaining Badges (black) FA-series Short Stubby Antenna Length: 8" TRex Eyelids,Wet Okole TRD Seat Covers Charcoal And Black With Center Console And Rear Pockets With TRD Emblem logo WeatherTech Floor Mats,48 LED Blue Dome Light
    heres mine
    301828_10150291580363431_504258430_77366_5beb4b0928811a67361473b6f16854059865469e.jpg
    318316_10150320943023431_504258430_79544_6be0c379b68abe4075c51d548ca257a1c26134b2.jpg
  19. Oct 1, 2011 at 8:22 PM
    #759
    TRDsport253
    Edgewood, Wa
    2021 TRD sport 4x4
    I agree. How's the quality fit and finish on the 100XL. I was quoted $1879 installed. That's including black headlliner and removeable front slider.
  20. Oct 1, 2011 at 8:27 PM
    #760
    Ivan
    Ivan Well-Known Member
    Ivan
    Western Mass
    06 Tacoma, 4x4 + SR5
    I dig this pic, cause of your snowboarding truck :)
