Show me your shell!
Discussion in 'Tonneau Covers, Caps and Shells' started by Oscar 319, Aug 28, 2008.
  1. Apr 17, 2020 at 2:44 PM
    #8061
    TheCatGent
    TheCatGent Member
    JD
    Washington State
    2013 Tacoma DCLB TRD Sport
    ARB Deluxe Front Bumper All-Pro Pack Rack
    Really digging that canopy. I'm probably a year from getting one, but now I have to add that to the list of prospects. I didn't know Canopy World did their own canopies like that. Not that I ever thought to look into them for something like this. Enjoy your new setup!!
  2. Apr 17, 2020 at 3:10 PM
    #8062
    DustyT22
    DustyT22 Well-Known Member
    Lucas
    Shelton, WA
    2000 Tacoma SR5 V6 Xtra Cab All-Black. 203,000 and counting
    Custom RoyEl Canopy and Homemade Bed Drawer for camping sh!t. Improved Cab roof racks. OME Suspension
    Thanks, It's a pretty good option! They pretty much base all their options off of the Leer Catalogue, and have all the same stuff, just a bit cheaper! Good luck!
  3. Apr 18, 2020 at 4:21 PM
    #8063
    ready6delta
    ready6delta REGULAR GUY
    JACOB
    Still in PNW but moved to Boise.
    Black pinstriped 2014 DCSB 4x4
    IT NEVER ENDS..........
    Did you get this used or new and how much did it set you back?
  4. Apr 19, 2020 at 5:57 AM
    #8064
    littlefish
    littlefish Buzz, your girlfriend...
    Hudson Valley NY
    2016 TRD Off-Road DCSB
    The one who dies with the most stuff wins.
    After over a year of looking for a used one, I gave up and ordered a new ARE Evolve and picked it up Friday. First job was to install the Prinsu, then the RTT on that.
  5. Apr 20, 2020 at 1:55 AM
    #8065
    PeteDX
    PeteDX Member
    Pete
    Portland, OR
    2017 TRD Sport
    Well suck me sideways that’s amazing. With the full, big platform set up it does look a bit tall; almost flush with the top of the bed. My current setup is maybe 4” lower..precious headroom. Otherwise I’d order one of those yesterday. (Edit: watched vid again and actually doesn’t look too bad. Those slim side rails on the very edge threw me off)
    Do you know how wide the middle channel is by chance?
    Furcata[QUOTED] likes this.
  6. Apr 20, 2020 at 3:31 AM
    #8066
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    Has anybody mounted a fishing rod holder on the inside top of their shell? If so, what did you use?
    ready6delta likes this.
  7. Apr 20, 2020 at 3:44 AM
    #8067
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    I have seen these, they usually come installed from the cap manufacturer as an option. Never ordered them, seemed to short for me, 6’ cap. All my rods are 2pc or 4pc, and are kept in the rod tubes. I have seen people use gun racks as rod holders and mount them on the side in front of the windows.
  8. Apr 23, 2020 at 6:34 PM
    #8068
    trip-n
    trip-n Member
    2019 trd pro - white
  9. Apr 24, 2020 at 6:57 AM
    #8069
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    I would add some form of insulation between the frame square tubing. Especially if you sleep inside and it's cold outside. That bubble wrap looking kind or even some 3/8" or so sheet Styrofoam kind.
    Stick a few of these on the underside of the doors to shine down and around when they're lit: https://www.amazon.com/dp/B071PFC1H2
    I ended up bolting mine to the bed rails. Drill a hole through the topper and through the bedrail then stick a bolt in there with a nyloc nut. I was always worried the clamps would slide off.
    One thing that caught my attention is the latches on yours. If someone were to come up while you're sleeping and flip the handle into the recess then you'd be trapped in side until you could unbolt the mechanism to unlatch it.
  10. Apr 24, 2020 at 7:12 AM
    #8070
    azhiaziam
    azhiaziam Well-Known Member
    The reef ca
    White 2023 trd off-road
    What did that run you? Do your windoors have screens in them too?
  11. Apr 24, 2020 at 11:30 AM
    #8071
    DustyT22
    Lucas
    Shelton, WA
    Cabron, Thanks for the suggestions! Yeah, I was thinking some of that pink foam stuff for insulation, and covering it with a thin linoleum flooring that looks like wood, maybe it will feel like a little cabin that way. That's also a good idea for the bedrails, I'll have to see how the clamps fair through some rough roads, because if they loosen on me I'll definitely go that route.
    I was wondering about being locked in myself, so I had my girlfriend close me in. There's a tab on the inside that turns with the latch so as long as it doesn't get locked, you can still escape!! :woot:
    Brake Weight[QUOTED] likes this.
  12. Apr 24, 2020 at 11:43 AM
    #8072
    Brake Weight
    If you cover it with some sort of finishing material a sheet of 1” styrofoam may cover it all. A little 3M spray glue to hold it in place while you mounted whatever. Run any wiring beforehand.
    I was referring to the latch getting pushed flush and getting locked in. May want some sort of quick disconnect on the inside like wing nuts or something.
    You could mount something to the bottom of the roof’s bracing to hang clothes or even assist getting in and out. Or maybe something kinky.
    bryanjoh likes this.
  13. Apr 25, 2020 at 4:07 AM
    #8073
    DR_BETELGEUSE
    DR_BETELGEUSE Member
    Parker
    Central Pennsylvania
    07 Tacoma 2.7 single cab
    Same I'm interested in making mounts inside my shell too
    six5crèéd[QUOTED] likes this.
  14. Apr 25, 2020 at 2:44 PM
    #8074
    littlefish
    Hudson Valley NY
    Was under the truck today and looked at the wiring job the ARE dealer did. Seems to me the guy took the lazy route. Instead of following an existing wire loom, he took the shortest route, going through crossmembers instead of over them the way the factory wiring does. He also ran the wiring the entire length of the truck without a single zip tie. I added some where I could to stop it from getting beat up, but again seems lazy to me. Am I being too picky? Seems to me just another example of what happens when someone else does work for you.
    drvn and Amchuge like this.
  15. Apr 25, 2020 at 2:53 PM
    #8075
    jwctaco
    Jim
    SW Michigan
    23’ T4R
    Well at least they put the wire in flexible conduct, add a few zip ties and call it good. Frustrating I know.
  16. Apr 25, 2020 at 3:16 PM
    #8076
    littlefish
    Hudson Valley NY
    Oh yes, I know. It's definitely not the end of the world. Now if it was loose like that without the conduit I'd be upset. Just one of those things I guess.
    jwctaco[QUOTED] likes this.
  17. Apr 26, 2020 at 9:04 AM
    #8077
    Brake Weight
    Not picky at all. I would personally take it back and complain. They may give you that fee back at least. Then I'd cut it somewhere and rerun it. I've got mine following some the fuel lines back then following a wire loom the rest of the way. I did that when I realized they had tied into a hot wire from the taillight housing. Would've complained about that but it was years before I realized where it was tied in at.
  18. Apr 27, 2020 at 7:22 AM
    #8078
    crackils
    crackils Sith Lord Jar Jar
    Shane
    FL
    2012 TRD DCSB Off-Road - KINGS/5125s AF
    Rather than making a thread maybe someone can chime in, but I currently have a Leer 100xq and I want to buy new struts. My current ones are Suspa C16-08941 16" Gas Prop-Force 28 Lbs Per Prop and they only open the rear window about half way, I then need to raise the remainder by hand. I'm thinking of buying these: Suspa C16-09209 , 16" Gas Prop-Force 38 Lbs Per Prop.
    I'm wondering will this be to much? I just want the rear window to open without me having to lift it constantly. First time buying these so maybe this is a dumb question.
  19. Apr 27, 2020 at 8:08 AM
    #8079
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    How old is your shell? The struts definitely wear out over time. On my last shell (current one isn't old enough to need it yet), I replaced the struts twice with the same model that it came with. The new ones worked great and lifted to the full open position.
    The stronger ones you mentioned would probably work ok, since they aren't a ton stronger. The only thing I would worry about is them wearing out the hinge by opening aggressively and/or holding to much pressure on the hinge while open.
  20. Apr 27, 2020 at 10:46 AM
    #8080
    crackils
    Shane
    FL
    Thank you for the reply. I think the shell was made in 2010, I'd have to double check. Good point about the hinge tho, I may just order the 38 ibs struts and if that is too aggressive I will replace them with the original ones.
